Go to Post Use these tools as a starting point, not as an end product. - Tom Bottiglieri [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 22-03-2005, 08:30
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: No CIM Motor in 2006?
The hips are made for FIRST. They are cheap and reliable. They may change the specs a bit to keep us on our toes but they are here to stay (for now).
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 22-03-2005, 16:05
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
Personally, i love the FP's They are great for just about everything. I would like to see 12 volt FPs though. 6 volts just isn't enough.
HOWEVER. better then all of that would be a 24 volt system. current is not your friend. low heat, high torque=we all win. I would love to see somthing that deals with sand. it would be quite a challange that most teams have never seen. Perhaps we should have a year where there is alot of manuvering and not much lifting. i would LOVE to see some hovorbots.
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Unread 22-03-2005, 22:16
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Oh? You know something that the rest of us don't?
-dave
Unread 22-03-2005, 22:27
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Originally Posted by Dzdconfusd
I also doubt they would change the kitbot transmission after they already tooled up for this year. Retooling would be expensive...
Yes.
It's not as though this transmission could be quickly adapted for use with other motors...
I mean... who would ever run a FP, Globe, or Van Door through that gearbox.
2006 - The Year of the Globe Motor...
Unread 22-03-2005, 22:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We run our 6V FPs at a full 12V and have not yet had a problem (not even warm) because we use each in conjunction with two FPs. The 6V motors work just fine for us. But that's not really the point I'm going to make here.
The thing with the FPs though about being "great for just about everything" is that they aren't. The gearbox that comes with them is all plastic. While this may be good for weight, it isn't for durability. So, lets talk just about the motor. The motor packs a lot of punch in a very small size. This leads to the problem of overheating (when not used like we used them). Also, it spins at a very fast ~20,000 rpm. This requires another stage of reduction compared to match the Chiaphua. Also, the FP is fairly small and fragile. The shaft is only 1/8" where the Chia is over 5/16" Also, the power tabs bend and break off. Also, the internal fan blades are very fragile and they break off. Also, the motor can is not fully sealed so debris can fall inside.
Also, I don't think two FPs would be adequately capable of driving a robot where 2 Chias would.
Aside from weight and size, I cannot see any advantages to the FP over the Chia.
The Chia is a hefty industrial motor that serves us well. I hope it is here to stay.
Unread 22-03-2005, 22:38
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
Is their any reason to believe that we are not going to be able to use 4 cim's again? We are allowed to use 4 cim's on the base, is their reason to believe that they won't allow that anymore?
GO 1403!!!
Unread 22-03-2005, 22:47
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Maybe drill motors are gonna make a comeback. I wouldn't mind =) -- even if the cim's are less finicky, the drill motors packed a lot of power in a fairly small package and could tolerate some abuse (more than the FP's, at least).
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
New Regional in Europe in 2006 unapiedra Regional Competitions 49 26-05-2005 00:07
Allowed to use CIM motors from last year? lphan Motors 7 26-02-2005 16:49
CIM speed in reverse? colt527 Motors 41 06-12-2004 19:09
CIM Motors to pull up Robot Joe P Motors 7 11-01-2004 22:27
CIM vs. Drill motor duckshepherd Motors 3 15-02-2003 18:36
