Re: Winning Defensive Allaince?
You guys are missing the point. If one of your robots plays defense, and you picked them for the purpose of playing defense then it won't be 3 on 2, it will be 2 on 2 or even 2 on 1 depending on how good the defense is. That defense robot will prvent another robot from scoring not just sit their and let the other allaince drive all over the field. KEEP THIS IN MIND
I would agree with you except for that the layout of this game, there are a possible 6 goals that you could go for at all times and due to that fact, you will always be closer to one than the person is trying to defend you is. Any good capper should be able to cap without much of a problem if they reach the goal first, even with a little resistance. Ill agree with Paul and stick with my 3 offensive robots I am skeptical only because I have not seen it done yet, not seen a successful 2 offensive 1 defensive alliance in the elims win yet personally. |
A few more clarifications:
1. I didn't say never play defense. I said 2 offensive robots and a defensive robot will not stand a chance against 3 scorers. Some of the best defensive move I have seen are done by offensive robots. If the other team knows that one of your three robots can't score, they already have an advantage. 2. No way can even the best defensive bot shut down two good offensive robots in eliminations. The scoring possibilities are too great and the advantage goes to the offensive robot. Think of it this way: a two on one in soccer (one goal) is very hard to stop. What if both offensive players had a ball and there were 5 other goals to score into? C'mon, there is no way the best defensive bot will stop two good scorers. -Paul |
alright I'll bite Paul. I disagree I think you can have 2 offense 1 defense alliance work well in the eliminations....I have seen defensive robots shut more than one offensive team at a time. Also in a elimination round(s) I watched this exact scenario where three offensive teams were defeated handily by two offensive bots and one defensive. The key was the defensive bot knew when it would and would not get a penalty...moreover they did not have a high torque ability just the ability to cause a nuisance whenever the other alliance went to cap.
The 3rd round pick in alliance selections is usually going to get you a 1-2 tetra capper. So lets say you could instead pick a defensive player that could negate more than 2 caps from any opponents best capper. You've effectively selected a 3 tetra capper. Right?
I personally don't think the best defense will be played with a strong slow drive base. It will require a good arm that can get in the way of caps and get there fast. Shoving bots in goals only works on some designs. But swatting caps or covering goals works all the time. I haven't seen this "smart" defense played yet. |
I am done debating (not because I don't think it's fun, but because I have to get some real work done) this issue and I will see you all at The Championship. I will give an update from The MidWest Regional on how defensive strategies worked. -Paul |
#7
[quote=Swampdude]The 3rd round pick in alliance selections is usually going to get you a 1-2 tetra capper. So lets say you could instead pick a defensive player that could negate more than 2 caps from any opponents best capper. You've effectively selected a 3 tetra capper. Right?[quote]
well for one there is only 2 rounds. and for two my team (65) was a SECOND round pick at Midwest and we usually scored about 6 tetras a match. i think our highest was like 8 one time. so that SECOND round pick could get you more then 1-2 tetras. |
#8
Based on the 226 experience, I'm going to say that 3 offensive bots is the key. In the finals in Detroit, we did the best our first match when we went completely offensive, and the next two matches were progressively worse as we stepped up the defense. We won our first match by a landslide, and lost the second one by 1 point, and lost the third by a lot. I know (well, nothing is ever certatin, but I'm 95% sure) that if I had worried less about defense in the second match we would have won it.
~Allison |
#9
I say that a dream team would be two robots that have the ability to stack with a great defense robot.
In our regional in Arizona we finished third overall and eliminated the alliance made up of the 1st and 2nd place ranked teams in the first round of the finals by playing defense. Our little blue bot has a two speed transmission (fast and faster), it is two ounces less than the maximum allowed weight, our frame was made of fiber glass, it drives with four CIM motors running four 10 inch pneumatic tires, two omni wheels (All wheel drive) and a brake that totally stops the robot from being pushed around but it is small enough to fit trough the field tetras . We had no problem removing tetras from underneath them by pushing them out. We didn't have problems maneuvering or pushing other robots around. We built the robot with stability in mind and after the competition there wasn't any significant structural damage on the robot. It even kept most of its paint on. It has an arm that can place tetras underneath the field tetras or pull them out but the pwm cable kept coming off during matches. |
#10
Keep in mind that in order to score most robots require several moments of precise meneuvering. Defense does not require this precision. In Portland we were chosen for our aliance because of our defensive abilities, and we were able to do a reasonably good job preventing the other teams robots from scoring. We just hung out in the center of their side of the field and would dart in and push out of the way any robot that tried to score. The best defense (or offense.... whatever) against this was to try to send the best scoring robot to our half of the field while the other two kept our robot busy.
#11
During the qualification rounds this is a very vailid strategy, as most alliances wont have more than 1 or 2 strong offensive bots. But during the eliminations, particularly between higher seeds or at more competitive events (such as nationals) it wouldnt hold true. In the Chesepeake regional for instance, team 173 was probably the strongest force in the entire regionals. During the finals, team 122 tried to stop them, and let it more or less become a 2v2 match-up. But 173 was able to slip by the opposing defense enough to let them score enough points and to help their alliance to get solid victories on their way to winning the regional. NO defense is perfect, and any strong offensive robot can beat a defensive robot enough to allow them to score enough points to decide the match. Look at the Colorado regional for another example. Teams 118 and 233 were dominant offensive threats. Every opposing alliance would send defensive robots to try and slow them down. Slow them down they did, but not enough to make 233 and 118 lose a single match during the eliminations. 233 adn 118 would crush any opposing defense and win the regional. The example is shown again in VCU. The #8 alliance managed to advance to the finals by playing very tough defense, but they would lose to a stronger offensive alliance. During the first match of the finals, Team 401 (who was on the winning #3 seeded alliance) was knocked down early, limiting them to the 4 points they scored in auto. In the process the robot that knocked them over was disabled (but not penelized or DQed). This is exactly as if they had both just been in a shoving match for the entire match, and niether scored a point. The #3 alliance would win the match. Proving again, for the 3rd time in the 3 regionals I attended, that offense wins matches and championships.
#12
In the Waterloo regional, the winning alliance (68, 1305, 1241) was extremely defensive. 1241 actually removed their arm to play pure defense! No scoring whatsoever- simply a pure chassis with an incredible drivetrain.
Truck Town had it's arm go down in the finals at waterloo (unplugged victor... grr) and playing with 2 defensive robots for a game against an almost purely offensive alliance ended marvelously with Truck Town's defensive alliance winning not only that game, but the entire regional as well. I believe the ideal robot is one that can do both well, defense and offense. A good capper with lots of traction and not too tipsy is a scary, scary robot to play against. |
#13
The finals, 121, 126 and 350 were up against 138, 175 (562 subbed in for them in Final 2) and 58. Now all three of those robots were offensive, yet 121, 126 and 350 were victorious. Although 138, 176, 58 and 562 did extremely well and really gave 121, 126 and 350 a run for their money. a 2-offense/ 1-defense alliance can beat a 3-offense alliance. My idea of a winning alliance is 2 strong offensive bots, and a 3rd robot that can cap (although not as well as the other 2) but also has a strong enough drive to play defense. |
#14
I don't think the drive train is necassary for defense. My team lost a qualifier at BAE simply becuase 1027 laid there arm down on the top of the tetra on a goal we had to stack for a row. They just sat there with there arm. They were going to defend that goal to the end. We couldn't cap becuase of it. Becuase of the aggresive driving penalties this year its all about playing defense on the tetra not the robot.
#15
Yes, but a robot with a weak drive train defending a goal with their arm can be pushed aside.
The problem with defending, especially when your defending a particular goal instead of a robot, it ofren becomes a 2v3 (or 2 and a reduced capability robot, so like 2v2 1/2). Defense is part of the game, but to dedicate a robot to defending the entire or most of the match is usually a foolish decision. The robots who call to be defended are usually the power house teams. These are the robots can cap score 20-30 points on their own. Even when defended they will still usually score some points. Now you have to hope your other two robots can outscore their other 2 and the few points the defended robot contributes. And that is harder than it sounds, because that defended robot is a powerhouse and is probably ranked pretty high, meaning hes got good alliance partners. And beyond that defense typically will have higher penalties. Not always more penalties, but the penalty points a defensive robot accumulates will usually be higher than that of an offensive robot. They also run the risk of DQ or decapping as aggressive driving may DQ you, and if you defend goals with your arm you may accidentally knock a tetra off. And then theirs the matter of the qualifying matches. Most defensive robots arnt as flashy and dont finish as high in the standings as offenseive bots (not that they are lesser robots, but they typically wont be ranked as well), so it puts them at a disadvantage during the selection process. So some alliances will pick a defensive bot knowing their strategy ahead of time. But the problem with that is if you find yourself down in points late in a match, a defensive robot wont be able to help you gain those points back as quickly as an offensive robot would. But if you choose an offensive robot instead of the defensive one, that bot wont be as good for your defensive roll. Now if you choose to go 3 offensive, you wont have that dilemma. Plus, there are certain situations, specifically late in a match when you have a lead, that you may choose to play defense. Now you can commit 2 or even all 3 bots to that task, and in numbers they can perform better than 1 dedicated defensive bot. |
| Do defensive, low scoring tactics work? | haverfordfords | Rules/Strategy | 37 | 18-02-2005 12:25 |
| Extent on Defensive Game | Jeff K. | Rules/Strategy | 1 | 18-02-2005 00:21 |
| What will the winning robot have? | sanddrag | General Forum | 59 | 16-01-2005 14:16 |
| Winning Robot Strategy | tenfour | General Forum | 41 | 08-03-2004 21:18 |
| Was the winning alliance unbeatable? | archiver | 2001 | 9 | 24-06-2002 03:21 |
