Go to Post Uh. Oh. Wildstang is simple and has a swerve. Where have I seen that before? - EricH [more]
Unread 23-03-2005, 19:07
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
pic: Team 1341's 2005 Robot
Unread 23-03-2005, 19:09
Captain Rich's Avatar
Captain Rich Captain Rich is offline
I am 245
FRC #0245
Captain Rich is a jewel in the roughCaptain Rich is a jewel in the roughCaptain Rich is a jewel in the rough
Re: pic: Team 1341's 2005 Robot
That makes sense, it is like a small forklift on a joint! I'm just cirious as to how you raise it up, all I see is one cable going to the base.
Richtopia Prevails Again!
http://richtopia.vzz.net www.adamsrobotics.com
Unread 23-03-2005, 20:37
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
how does it work?
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Unread 23-03-2005, 20:54
CraigHickman
Posts: n/a
Methinks that can cap very, very, very high. It might have the cable on the back loop back down the arm and through all of the joints.
Unread 23-03-2005, 21:31
scott scott is offline
Free Agent
AKA: Scott Ray
scott has a spectacular aura aboutscott has a spectacular aura about
perhaps a pulley at each end of the extending arm sections. . . that would do it, 1 cable for the up/down movement. . . my thought
2015 INDY DISTRICT CHAMPIONS (1501 & 829)|2015 PURDUE DISTRICT FINALIST (1747 & 5402)|2015 IN STATE QUARTER-FINALIST (3484 & 461)|2014 IRI QUARTER-FINALIST (624, 33 & 2481)|2014 CORI CHAMPIONS|2014 QUEEN CITY REGIONAL CHAMPIONS (16 & 2665)| 2014 QUEEN CITY XEROX CREATIVITY IN DESIGN|2014 CROSSROADS QUARTER-FINALIST (3494 & 3940)|2013 CROSSROADS FINALIST (1288 & 1756)|2013 QUEEN CITY REGIONAL CHAMPIONS (379 & 1985)|2013 QUEEN CITY EXCELLENCE IN ENGINEERING AWARD|2012 QUEEN CITY QUARTER-FINALIST (379 & 1706)|2012 SMOKY MOUNTAINS QUARTER-FINALIST (1501 & 1261)|2012 SMOKY MOUNTAINS XEROX CREATIVITY IN DESIGN|2011 CAGE Match FINALIST (461 & 1760)|2009 WISCONSIN QUARTER-FINALIST (1024 & 2826)2008 BOILERMAKER QUARTER-FINALIST (1000 & 201)|2007 MIDWEST FINALIST(1000 & 648)|2007 MIDWEST XEROX CREATIVITY AWARD|2006 BOILERMAKER ENGINEERING INSPIRATION|2005 Creator of IRI Vex, "Enter-Action"|2005 CHAMPIONSHIP RADIOSHACK INNOVATION IN CONTROLS|2005 CHAMPIONSHIP GALILEO FINALIST(1108 & 492)
Unread 24-03-2005, 21:05
youaredumb youaredumb is offline
Junior Member
youaredumb is infamous around these parts
that doesnt look stable at all. Pfff
Unread 24-03-2005, 21:08
Ali Ahmed's Avatar
Ali Ahmed Ali Ahmed is offline
FRC #0004 (Team 4 ELEMENT)
Ali Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to behold
I agree. What happens if someone hits you from the back. If you guys have some sort of outriggers then that is a very good and simple design.
Student: Team 22
Mentor: Team 4
Unread 25-03-2005, 11:49
I'm baaaaaaack.
Well, it wouldn't be stable if we had it that far up while driving. It's very stable when it's retracted though.
As for how we lift it, here's an image that might help describe it a little better:
We have a FP motor attached to a spool (link [the FP motor had a shield added after that picture]), which lead the whole aluminum arm up and down with two cords, one that would retract, and a second one that was looped around all of the steps on the arm (114ManualLabor was right). The cord was nylon (I think) with a 4-5mm diameter. The assembly was attached with gas shocks to the robot base and moved along a plastic tooth track by a Nippon-Denso motor. The drive train was a 6 wheel tank-drive (using inflatable 6-inch wheels at ~30psi), controlled by 4 CIM motors and the 2 standard FIRST-supplied gear boxes. On the bottom of the back and front we had two 1-inch hard rubber brakes that would stop us from tipping over.
Unread 25-03-2005, 12:28
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
where'd you get the plastic tooth track from?
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 25-03-2005, 12:33
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
You could probably just machine the plastic tooth track, it wouldn't be too hard with a milling machine. And yeah thats kinda the same idea with my teams arm, except we only used 2 extrusion segments this year, last year we used 3 but had a lot of problems.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
YMTC: Can teams start cutting metal for 2005? Natchez You Make The Call 67 07-02-2006 21:55
pic: team 909's robot - pic 2 Brad Lanpher Robot Showcase 8 16-02-2005 08:34
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
