Go to Post Just wear your safety glasses. They can be stylish, too! - Eugenia Gabrielov [more]
Unread 26-03-2005, 19:44
dm0ney's Avatar
dm0ney dm0ney is offline
Will Code For Food (Food Optional)
AKA: Deepak Mishra
None #0217 (The ThunderChickens)
dm0ney will become famous soon enough
Send a message via AIM to dm0ney
Re: PID Control
We used the 'kit' pid code for the first regional. Since then, we have migrated back to pid code written last year by our team. The switch is very easy as we have macroed 'KIT_PID.'
We only used the position loop during autonomous and we also split gains and max/min for rotate and drive.
The pid code was quite easy to tune for linear distances but until we split gains, we had a heck of a time getting spins with the same gains.
The reason we abandoned the kit pid code was eventually a robot will not drive straight (assuming it drove straight to begin with). Last year we had implemented 'go straight' code that would compensate for mechanical imperfections by engaging encoder counts and running it through pid. We tried implementing this into the new code but decided that since we already had code that works, it wasnt worth rewriting it and inserted the macros instead.
Alumni
Team #217, The ThunderChickens
Student, Class of 2009
California Institute of Technology
PID cmd_drive can't drive straight? gnormhurst Programming 4 18-02-2005 01:54
(Experimental) PID Control System jdong Programming 14 18-06-2004 15:55
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
PID control loop/Encoder question Zee Programming 18 30-01-2004 23:14
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
