Go to Post I think we need to take away your hammer privileges. - Katy [more]
Unread 26-03-2005, 21:49
Revolverx7's Avatar
Revolverx7 Revolverx7 is offline
Ninja
AKA: Sanders
Team Role: Driver
Revolverx7 is on a distinguished road
Send a message via AIM to Revolverx7
Pushing into goals, and pinning
First, is there a penalty for pushing someone int a goal?
Second, If a robot pins you and then rides up on you getting stuck on you so they can't get off should that still be called for the pinning penalty?
2006 SBPLI Regional Champions (with 271 & 870)
2006 UTC Finalist (with 181 & 585)
2005 SPBLI Regional Chairmans Award
2005 SBPLI Regional Champions
2005 Philly Regional Finalists
Unread 26-03-2005, 21:51
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Re: Pushing into goals, and pinning
I am pretty sure there is no penalty for pushing someone into a goal, unless they call aggresiveness. And for pinning the rule is 10 seconds then back up. If they get stuck on you chances are if it is a safety hazard they would disable someone if not both robots, usually you get a chance to untangle.
Penn Class 08
Unread 26-03-2005, 21:54
TonzOFun TonzOFun is offline
AKA: Chris
FRC #0555 (Montclair Robotics)
TonzOFun is on a distinguished road
Send a message via AIM to TonzOFun
As far as I know, there is no penalty for pushing a team into/under a goal as long as you do not pin them. I wouldn't recommend it though because you could possible push some of your own tetras out from underneath in the process if you are not careful.
In NYC, several teams were pushed under scoring goals and a penalty was never given out.
Name: Chris Noll || Position: Alumni
Areas of Knowledge: Design, Fabrication, Pneumatics
2005 Awards
Arizona Regional Winners || New York Regional Finalists
New York Regional Website Award || New York Regional Sportsmanship Award
Championship Sportsmanship Award || Brunswick Eruption: Mike's Favorite
Unread 26-03-2005, 21:58
Revolverx7's Avatar
Ninja
AKA: Sanders
Team Role: Driver
I knew that after 10 seconds there was a pinning penalty, but it seems somehow the refs missed when a robot decided to pin us and then sit their robot on top of our robot for the last 30 seconds of a match. I'm not sure how you don't see something like that; Can you?
Unread 28-03-2005, 19:07
Best Available Data
FRC #1778 (Chill Out!)
It is only considered pinning if you are pushed up and held against a field element IE the diamondplate. If the got of top of you it would not be a pinning penalty. Same thing if you where pinned between two robots.
Unread 28-03-2005, 21:48
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
<G21> mentions one or more field elements, So diamond plate, the side walls, and the scoring goals should be considered field elements. Pin for not more than 10 seconds, back off three feet and re-pin and the 10 second clock starts again.
Unread 29-03-2005, 15:02
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
I may be wrong, but i don't think there is a penalty for pushing a bot under the goal...we did it as a defense move against the dirty birds in one of our semi's. the only thing to watch is g25...don't be overaggresive
Unread 29-03-2005, 16:50
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
No, there is not a penalty for pushing under goals. But, many robots can drive in and out of goals. Also, if the robot is particularly tall (or fully extended beyong the top of the goal at that moment) you may end up tipping them while trying to shove them in. This would come quite close to aggressive play.
