Go to Post just a gentle reminder not to limit yourself to just one viewpoint - every problem can and should be examined from different angles - dlavery [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Unread 27-03-2005, 11:56
dm0ney's Avatar
dm0ney dm0ney is offline
Will Code For Food (Food Optional)
AKA: Deepak Mishra
None #0217 (The ThunderChickens)
dm0ney will become famous soon enough
Send a message via AIM to dm0ney
Making Debugging Easier
I've had several ideas to make debugging easier on us programmers or even just checking out the robot between matches.
Currently we have an autonomous selector switch on our robot. I inserted a special 'debug mode' that we can put any autonomous sequence in and test it and when we run out of time and cant reload code, its not a big deal.
Stemming off that, I was wondering what other ideas or solutions fellow programmers have had?
My next change to our code once the 'No Work' period is ended for our team (Nationals) is going to use a toggle switch on our OI to enable or disable printfs for pots and encoders. Those two are by far the two most used printfs on our team, so I hope to make it easier for us programmers to work.
Also, has any team used the Dashboard to read pot or encoder values? That was going to be another project on the horizon which I believe is exempt from the 'No Work' period because its not actual work on the robot.
Currently we use the dashboard to trim joysticks, although we did use it to monitor pwms before we got our robot to test code.
A few ideas in the works for later this year or next year are:
Three Pots that can plug into the OI and be used to tweak PID gains rapidly.
Utilizing the leds on the OI we have to enable us to deadband joysticks sans dashboard
Mini Dashboard viewer instead of a laptop (possibly pocketpc or the like)
Wireless programmer for use in those few hours programmers actually get the robot right before shipping it away.
These are all ideas which we have YET to get working but please add what programming easter eggs you have put into the code to make your life easier.
EDIT:
Dashbord Config of pots and encoders in although since only 4 digits, I have a call that looks somethin like this for encoders:
User_ByteX = (int) abs( (int) Get_Encoder_Counts(LEFT)) % 1000;
Trim joysticks done sans laptop using the userbytes so dashboard or OI itself, still working on a more compact dashboard display.
Alumni
Team #217, The ThunderChickens
Student, Class of 2009
California Institute of Technology
Unread 27-03-2005, 12:08
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Re: Making Debugging Easier
The best addition I ever made was to print out joystick & pot values on the OI using the user byte. Flip a switch, move a joystick up/left and the joystick value is printed in the user mode display. Flip another switch, move a joystick up/left and a pot on the robot is printed. It saved me the time of downloading debug software whenever a pot was in question or was replaced. It also allows the drivers to calibrate the joysticks before every match & get the values perfect.
Unread 27-03-2005, 16:45
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
Something that won our team an award from last year was a "debug box". It doubled as our arm control mechanism, but it had a big red button on it that said debug. When you were in debug mode you could hit a combination of 4 keys (or more) to change the way the robot operated. The changes would then be stored in the flash (?) memory so next time the controller booted, it would use the saved changes. The idea was to preprogram as much as you can to not need to recompile the program to do mundane changes.
A list of features was
- Enabling and Disabling the Right or Left motors
- Inverting the polarity on the Right or Left motors (this was useful for motor replacement)
- Changing the operator drive mode from one stick, two stick, or ultra topic secret mode
- Selecting which autonomous program to run
- Motor dampening
- Enabling and disabling specific debug statements
- Having one test autonomous program that you could hot script and save
This year we were planning on getting an rj-45 jack and hooking it into the digital ins/outs and then having a project box with LCDs on it as well as a keypad. The project box would then be able to hot plug into the robot and the LCDs would make a menu of sorts to replicate the same function as described before. They could have also been used to display output variables and such.
Suddenly being rejected from college feels right during the build season. Now I am a mentor.
Unread 27-03-2005, 17:06
Most of the pins on the programming port aren't used. I made a pair of "breakout" connectors that steal pins 7, 8, and 9 from the programming cable and provide remote control of the robot reset and program buttons. The RC end has a "pwm" cable connector for the remote switch pins, and the computer end has a two-way rocker switch with red=RESET and green=PROG sides (though a pair of momentary switches would work too).
Without this, the programmer has two options: either get up from the computer and kneel down by the robot to press PROG every time, or shout "Please press program!" and wait for someone to comply. When the robot was on our practice field, connected by a 25-foot cable, on the other side of the alliance station wall from the programmer, the remote switches were very handy.
Unread 28-03-2005, 01:32
dm0ney's Avatar
AKA: Deepak Mishra
I DEFINITELY love that... throwing this out there, any ideas why sometimes IFI Loader can put the RC into program mode and then mysteriously cannot most other times?
I'm definitely going to look into doing a breakout connector like the one shown.
I actually wrote an implementation of some code that I can drop in at a later date today to allow the printfs to become obsolete and use the dashboard instead... I suppose its on to creating a dashboard prog to run on a pocketpc, palm, or somethin else.
"If mechanical can have their labeled blocks of wood for tap and drill sets, electrical can have their helping hands to solder, us programmers can DEFINITELY have all that and more. "
~D. Mishra
Alumni
Unread 29-03-2005, 16:57
Our software read one of the otherwise unused joystick wheel inputs (yes, we used the old reliable black joysticks for the driver this year) and used its value to select among a set of User_Byte outputs to be viewed by a dashboard program. With the wheel at one end of its travel, it sent (the low 16 bits of) the three encoder wheel values. At the other end, it sent arm potentiometer feedback. Intermediate positions gave internal state information for the arm and drivebase control routines.
A separate "debug mode" switch selected between all of that and the regular "drive mode" dashboard data, which was basically monitoring the autonomous mode selection, the vision tetra detection, and a few feedback bits such as air compressor status.
Unread 04-04-2005, 11:02
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Talking Re: Making Debugging Easier
[quote=Alan Anderson]Most of the pins on the programming port aren't used. I made a pair of "breakout" connectors that steal pins 7, 8, and 9 from the programming cable and provide remote control of the robot reset and program buttons. The RC end has a "pwm" cable connector for the remote switch pins, and the computer end has a two-way rocker switch with red=RESET and green=PROG sides (though a pair of momentary switches would work too). QUOTE]
Can you provide a picture of the words above? Can you point to any IFI documentation that details the programming port?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 04-04-2005, 19:09
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
[quote=marccenter]
Yea, pinouts would be helpful, or at least what pins are not used.
Unread 06-04-2005, 22:07
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
We used primarily printf()'s (again) for debugging. (though we had some issues with overlap.)
We took the 8 most significant bits off the pots on our arm and put those in the user bytes. That was very nice, since it seemed the pots were always loosing alignment. (And we were using a 'model' control for it.)
I also opened up PWMs 13-16 for debugging. So I could use CCP2_OUT (or whatever ), etc. for digital outs and pwm13-16 to see values on the dashboard.
Unread 06-04-2005, 23:51
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
The newest version of the master code (version 10) requires that you push the Program button before sending new code. The master code on last year's RC does not have this restriction. At first I thought it was just an idiosyncracy with our new programming computer, but someone from IFI told me that it is indeed a new feature (not a bug, mind you) in version 10. My best guess is that it is intended to make sure that anything you connect to the serial port (like, say, the camera) doesn't accidentally send the data sequence that sets the RC into Program mode and corrupt your code in the middle of a match.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 07-04-2005, 10:58
Dave Scheck's Avatar
Dave Scheck Dave Scheck is online now
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
We have something similar to this. We have a 3-way switch that changes the OI mode between Driver mode, Joystick calibration, and Aux. The joystick calibration is what Mike described above. The Aux position allows us to remap any of our OI buttons/switches. For example, pressing one of our momentary switches in driver mode will trigger the pneumatics on one of our fingers while in aux mode it will toggle debug prints for the lift height encoder. Once we take it out of aux mode, the prints continue and we can move the lift to verify the state of the encoder. It is a real time saver and I would recommend it to anyone.
Unread 07-04-2005, 14:28
AKA: Jamie Bliss
Question Re: Making Debugging Easier
On a similar thing, has anyone tried something so that you can change constants w/o downloading code again? I'm thinking that's going to be my summer project.
Unread 07-04-2005, 14:54
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
This would be a cool project to work on. I sketched out a simple version but never got around to writing it. I figured the easiest way would be to implement a Get() and Put() function to read and write to the EEPROM and add a proxy layer to marshal calls through the serial port. You would need to tell the PC which EEPROM addresses represent which variables, but that can be encapsulated in a config file. If you write it I would use it.
Unread 07-04-2005, 15:20
Rookie Year: 1234
Program port pinout is at http://www.ifirobotics.com/docs/program-port-4-7-05.pdf .. pins 9, 4, 6, and 1 are free, I love the IFI support forums
Unread 07-04-2005, 15:24
Rookie Year: 1234
I set something similar to this up with our joysticks and lift.. you can reset the center values of the joysticks by pressing a couple of buttons, and set new lift heights by putting the lift where you want it, and pressing some buttons. It works nicely, and the eeprom code is on the forums somewhere..
Making your robot drive easier ufa_mike Control System 32 28-04-2004 21:35
Wiring Diagram for making a Joystick Nick Fury Control System 0 10-02-2004 23:10
Team Communication - Making it easier Balbinot Website Design/Showcase 3 10-02-2004 13:50
What's easier? Last year or this year? archiver 2001 2 23-06-2002 23:33
FIRST, BattleBots & Marketing of Robotics Mike Soukup General Forum 12 12-12-2001 18:46
