Go to Post On these forums, there are so many people that we see working all of the time to try to help teams out, and just overall good people. To everyone who does that, thanks. - miketwalker [more]
Unread 28-03-2005, 22:20
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
Autocalibrate function
I think we can all agree in saying that this years joysticks were really lousy. Ours lost calibration even with tape on the wheels.
I want to write an auto calibration function for the sticks so they we can compensate for a reasonable error (say, 10 -15). I have been programming for years but i am rather new to C and more importantly, to the default code. The way i had in mind was to use the user initialization function to grab the values of the sticks (assume they are at center) and calculate offsets that would later be applied to the drive function. I realize that issues that can come up regarding the drive curve when doing this and i have already solved them. What i need to know is if joystick values can be read AT COMPETITIONS in the user initialization function.
Thanks ahead of time!!
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Unread 28-03-2005, 22:41
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: Autocalibrate function
The joystick values should be able to be read during initialization, but just to be safe you could read them in the whole time during which the robot is disabled (by checking the disable bit).
We do almost the same thing, since our joysticks often become decalibrated, but instead of reading the joystick values at initialization or while in disable mode, we read them whenever p1_sw_top is depressed. That way we can quickly recalibrate during a match if the trim tab somehow gets moved. To calibrate before the match, we simply hit the button while the robot is on but disabled.
Hope this helps.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 29-03-2005, 21:59
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
I did it slightly differnt.
I read the joystick value at all times. If its greater then the max, or smaller then the lowest, I set either the high/low to the new value, update it in eeprom, and set the new center to (high+low)/2, after that, joystick deadbands are achieved by dividing (high-low) by 30.
I just looked through my code, and realized that I never actually used the center point. Weird, I should probably fix that.
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
a quick function question Kashi Chan Programming 3 06-03-2005 20:44
Auton + Functions ten3brousone Programming 0 27-02-2005 20:11
RoboEmu2(code simulator)--now with C! rbayer Programming 23 17-02-2005 09:17
