Go to Post Who would think 130 points would be a losing score! - Chris Fultz [more]
  #31   Spotlight this post!
Unread 21-03-2005, 20:11
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Covering your electronics
Originally Posted by Btower
2. Cover the unused I/O Pins on the RC especially when you are working on the bot. Between GLR and Detroit we saw at least 10 cases of contamination causing comm or control problems on otherwise functional bots. After the pins were cleaned, operation returned to normal.
Check the RC Hardware LED on your controller. If it is yellow, you have a short. Clean off the I/O pins immediately. It will make your sensors stop working. I saw this twice at Pitt.
Robot Inspector
  #32   Spotlight this post!
Unread 29-03-2005, 03:56
WhatevaForever's Avatar
WhatevaForever WhatevaForever is offline
FRC #0481 (The Hitchhikers)
WhatevaForever is an unknown quantity at this point
Send a message via AIM to WhatevaForever
Re: covering...
We had to mount our electronic board vertically on our arm...so the electronics would be completely unprotected if we didn't cover it with lexan. We also mounted the board itself so it acted as a wall of the arm...therefore the mount itself is lexan as well.
Originally Posted by Squeje250
how many people actually put a outside shell on there robot to protecet there electornics this year (like lexan). and if you have why do you think its nessary..... if you havent why do you think you dont need them?
  #33   Spotlight this post!
Unread 29-03-2005, 07:43
danield710's Avatar
danield710 danield710 is offline
FRC #0710 (Panthers)
Team Role: Driver
danield710 will become famous soon enoughdanield710 will become famous soon enough
Send a message via AIM to danield710
We use lexan every year to cover up our electronics and pneumatics, first off the lexan gives u protection from tetras that can fall on the electronics or if a robot rams into your side the lexan protects everything on the inside, also like many of you have said before its a good space for graphics and labels for your sponsors and team number and name
Team 710
2005 Newton Divison 6th Seed
Quarter-Finalist (thx 395&345)
2005 UCF Regional Semi-Finalist (thx 1649&312)
2005 UCF Winner of Imagery Award
2004 UCF Regional Quarter Finalist (thx 79 & 168)
2004 UCF Winner of Johnson and Johnson Sportsmanship Award
2004 Newton Division Semi-Finalist (thx 364 &48)
2003 UCF Regional Semi-finalist (thx 267&312)
www.team710.com
  #34   Spotlight this post!
Unread 29-03-2005, 08:34
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
We mounted our electronics and pneumatics stuff to a lexan board and mounted the board upside down and put it on hinges, so you can fold it up and work on it. This works really well because most of the debris falls on to the chassis of the robot and out of the electronics board. And we mounted the OI right side up with some spaces so it is under the lexan but facing up so you can see it.
  #35   Spotlight this post!
Unread 29-03-2005, 09:02
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Our electronics are exposed. Only thing really protected is the Robot Controller. We orginally has a "rib-cage" made out of lexan, but during finals...we were in too much of a hurry t remember to grab it...it didn't matter thiugh, but a tetra would easily kill our circuit box. I want to try and find some 1/8" lexan and maybe make something for nationals thats a little better.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
  #36   Spotlight this post!
Unread 29-03-2005, 11:16
Originally Posted by Bcahn836
We mounted our electronics and pneumatics stuff to a lexan board and mounted the board upside down ...
How did you guys pass inspection, IFI people need to see the lights on the RC when you compete?
  #37   Spotlight this post!
Unread 29-03-2005, 12:04
Bcahn836's Avatar
Iraq is fun.
AKA: Brad Cahn
This year we used the transmission support plate from the kit, turned it upside down and mounted the fuse panel, OI, main circuit breaker and the back up battery. To cover those components we took a piece of lexan mounted all the remaining electronics and pneumatics stuff to it and turned it upside down, making sure nothing was covering the OI. The radio was mounted on the frame, high on the arm.
ID:	3205  Click image for larger version
ID:	3206  Click image for larger version
Covering Electronics shyra1353 Rules/Strategy 6 24-02-2004 22:23
floor protection Ken Leung Off-Season Events 15 17-05-2003 07:42
Espn covering First again Todd Derbyshire Rumor Mill 34 12-02-2002 21:04
