Go to Post You never really graduate out of FIRST.... - Gnomegirl [more]
Unread 30-03-2005, 10:06
Re: FESTO question
Originally Posted by evilhunter
thank you guys. Sorry I ask this stupid question but when the toggle is no longer depressed it will go back down correct.
Questions are rarely stupid. In this case, however, many of the words in the question seem somewhat confused. What do you mean by "toggle" here? I don't know what it would mean for a toggle to be "depressed", I don't know what "it" you're referring to, and usually when something is no longer depressed it goes back up.
To answer the questions you asked originally: A Festo valve indeed will return to its unenergized state when it's no longer being energized. You cannot change this behavior in programming; it is just the way the hardware works. You can use programming the way Pat Fairbank suggests, but remember that when the robot is disabled all outputs are deactivated and the valve will turn off until the robot is reenabled.
Question of the Week!!! (8/24/04) Andy Grady General Forum 27 27-08-2004 19:00
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 01-07-2004 15:54
Question of the Week [05-02-04]: The Very Merry Month of May EddieMcD Rumor Mill 10 05-05-2004 14:02
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
A question about control system options computhief263 Control System 7 04-02-2004 14:46
