| View Poll Results: Does your RC do this? | |||
| Yes |
18 | 94.74% |
| No |
1 | 5.26% |
| Voters: 19. You may not vote on this poll | |||
Hey guys, after talking with an IFI rep, this is an undocumented feature. It allows the controller to enter diagnostic mode so they can be functionally tested. The majority of users only hold the program button down until they see that the “Program State” LED is solid yellow. If you continue to hold the button longer, the controller will go into “Master Download State”. This is same as the reset and program button combo that is documented on the IFI web site. The Christmas tree = diagnostics mode.
Re: Does your RC do this?
Thanks for the info, we used to get Christmas Trees (We call it that too) here and there. |
During autonomous testing with the wheels off the carpet our r/c would sometimes pop into this mode during a high amperage fwd/rev of the 4 drive motors, however when the backup battery was used the problem was never encountered. I know the cause of this was the voltage droppng so low, but it freaked me out when it happened the first time and as with the others a simple reset cleared the problem.
I saw x-mas lights, too, associated with low power. (The OI draws more than one would think!) It was last year's controller running v10 of the firmware.
![]() On a similar note, you can actually start up the RC without a 12v battery. (This also comes with IFI.) Take a regular 9v battery (the little boxy ones) and touch it to the main power contacts (with the back-up plugged in). The RC will start up and stay on much longer than normal (5+ minutes vs. 15 seconds). This means that you can run it without 15lbs of electrical stuff to tote. Last edited by Astronouth7303 : 30-03-2005 at 16:26. |
![]() Not sure of the practicality of that, but oh well... ![]() Is it just me or does this seem to be sort of an undecided thing... IFI rep says diagnostic mode, someone else says low power, someone else says firmware uploading... Or is it really just seem to be a buggy thing that just happens at random times...? |
Maybe a future firmware update will correct the issue with going into this "diagnostic mode" sporadically (I know it's happened to us a few times, mostly on the old controller, I don't think it's happened on the 2005 one though), but like others have said... when that happens, a simple reset fixes the problem. So, keep your batteries charged and don't press the program button for too long and you should be fine ![]() |
