Go to Post I can't really think of a bad FIRST experience, really, I can't. - Joshua May [more]
Unread 30-03-2005, 10:52
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: Java headache problem
Originally Posted by MisterX
I am having problems with this program any help would be much appreciated:
I would post my program for you to decipher but at last compilation it had 31 errors so it is best to just treat it as a blank slate :0
Don't just treat it as a blank slate because you have 31 errors, have had programs that had many errors that have been caused by small little errors, like forgetting to define a constant or including a library.
It is also a good idea to learn from your mistakes, so you do not make the same mistakes again..
If you post the code, I am sure someone would be able to spot the errors within just a small amount of time.
EDIT: I see you posted the code while I was typing.
- from B B frank
Strange Encoder Problem AIBob Electrical 3 20-02-2005 22:20
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Java Books Yan Wang Programming 1 27-12-2002 16:26
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
