Go to Post But I suppose friendly reminders to read the manual are much better than sarcastic ones. - dtengineering [more]
Unread 30-03-2005, 10:58
dm0ney's Avatar
dm0ney dm0ney is offline
Will Code For Food (Food Optional)
AKA: Deepak Mishra
None #0217 (The ThunderChickens)
dm0ney will become famous soon enough
Send a message via AIM to dm0ney
Re: Java headache problem
Originally Posted by MisterX
feast your eyes on 31 errors of pure Java!
public class SellStock
public SellStock()
price = 0;
numbers = 0;
value = 0;
commission = 0;
rate = 0;
proceeds = 0;
public void addPrice(double count)
price = price + count;
public void addNumbers(int count)
numbers = numbers + count;
public void addRate(double count)
rate = rate + count;
public void addValue()
value = price * numbers
public void addCommission (double rate)
commission = value * (rate/100);
public double getProceeds()
return value - commission;
public class SellStockTest
public static void main(String[] args)
SellStock iSellStock = new SellStock();
iSellStock.addPrice(10.125);
iSellStock.addNumbers(11);
iSellStock.addCommission(1.5);
double totalValue = iSellStock.getProceeds();
System.out.print("This program calculates the net proceeds from a sale of stock to be:");
System.out.println(getProceeds);
SellStock should not be a public class, only class. You cannot have two public classes declared in the same file.
Next, missing a semicolon on in the addValue() function.
Finally, getProceeds in println is a function so getProceeds()
I'll check for logic errors next, but those are the syntax.
Hope that helps.
Going on to some logic / style issues.
Firstly, dont always name variables count. Good practices mean using descriptive variables, also in Java, set and get are the terms used in code, not usually add.
The program was meant to take input from a terminal window according to the description, are you just testing the class itself before implementing a user input?
Alumni
Team #217, The ThunderChickens
Student, Class of 2009
California Institute of Technology
Strange Encoder Problem AIBob Electrical 3 20-02-2005 22:20
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Java Books Yan Wang Programming 1 27-12-2002 16:26
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
