Go to Post However, the best responses come with patience. It might be a couple of days before you get a good answer or it could be 10 minutes. - Molten [more]
Unread 30-03-2005, 11:02
MisterX's Avatar
MisterX MisterX is offline
Alumni
AKA: Mr. X
FRC #0521
MisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to behold
Re: Java headache problem
Originally Posted by dm0ney
SellStock should not be a public class, only class. You cannot have two public classes declared in the same file.
Next, missing a semicolon on in the addValue() function.
Finally, getProceeds in println is a function so getProceeds()
I'll check for logic errors next, but those are the syntax.
Hope that helps.
yeah thanks alreayd better off then when I started. Sorry I didnt make my self clear before that is two seperate files, 1 is for the actual calculations then the second is where I put in the data to compute and print out.
Strange Encoder Problem AIBob Electrical 3 20-02-2005 22:20
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Java Books Yan Wang Programming 1 27-12-2002 16:26
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
