Go to Post There are times when your team will struggle and there are times when it will achieve great victories. There will be times when unknown and uncontrollable factors will intercede to provide an unexpected outcome for which your team must compensate. - Travis Hoffman [more]
Unread 30-03-2005, 15:48
evilhunter evilhunter is offline
evilhunter is an unknown quantity at this point
help programmig doble solenoids
Ok i have one more question on the programing the double solinoid
this is what i have
relay1_fwd = p3_sw_trig; //lower arm extend double solenoid
relay1_rev = p3_sw_top; //lower arm retract double solenoid
relay2_fwd = p3_sw_aux1; //upper arm extent double solenoid
relay2_rev = p3_sw_aux2; //upper arm retract double solenoid
//relay3_fwd
//relay3_rev
//relay4_fwd
//relay4_rev
relay5_fwd = p4_sw_aux1 //lift plate up festo solenoid
relay5_rev = p4_sw_aux2 // lift plate down festo solenoid
ok will this work or will it cuase it to keep going one way and back the other way. If so how would i code this. Thanks
Unread 30-03-2005, 16:20
dm0ney's Avatar
dm0ney dm0ney is offline
Will Code For Food (Food Optional)
AKA: Deepak Mishra
None #0217 (The ThunderChickens)
dm0ney will become famous soon enough
Send a message via AIM to dm0ney
Re: help programmig doble solenoids
this is what i have
//relay3_fwd
//relay3_rev
//relay4_fwd
//relay4_rev
If you set them equal to each other, it will fire only if the button is pressed continuously. If you instead put them into if statements, all will resolve!
Please note, the festo is not a double, red code reflects change.
if(p3_sw_trig)
relay1_fwd = 1;
relay1_rev = 0;
if(p3_sw_top)
relay1_fwd = 0;
relay1_rev = 1;
if(p3_sw_aux1)
relay2_fwd = 1;
relay2_rev = 0;
if(p3_sw_aux2)
relay2_fwd = 0;
relay2_rev = 1;
if(p4_sw_aux1) relay5_fwd = 1;
if(p4_sw_aux2) relay5_fwd = 0;
Another way to decrease the amount of triggers used and make it easier for the operator, have the same button do both actions by
a) setting flags and then using if statements
b) declaring a bool, using logical operators
c) writing an abs function and using a
relay = abs(relay - 1);
Alumni
Team #217, The ThunderChickens
Student, Class of 2009
California Institute of Technology
Unread 30-03-2005, 23:50
will this code still make the festo work properly. Thank you guys for all the help
Unread 31-03-2005, 09:52
You're not giving enough information for us to know what you think "work properly" means.
A double solenoid will switch states when a control signal is applied, and will stay in its current state when the signal is removed. If you wire it properly and simply copy OI button inputs to RC relay outputs, you can use one button to make the solenoid switch one way, and another button to make it switch the other way.
A Festo solenoid will sit in one state when the control signal is absent, and will go to the other state only while the signal is applied. If you wire it properly and simply copy OI button inputs to RC relay outputs, you can use one button to hold the solenoid on; releasing that button will make the solenoid turn off again.
The code posted by dm0ney does not simply copy OI button inputs to RC relay outputs. It interprets OI button inputs as desired actions and controls the RC relay outputs to cause those actions. If you don't press both buttons simultaneously, the double solenoid part of the code has the same effect as your code. The Festo part turns it on when p4_sw_aux1 is pressed and leaves it on when the button is released, and it turns it off when p4_sw_aux2 is pressed and leaves it off when the button is released.
Are your solenoids firing on their own? Mr. Lim Pneumatics 7 23-02-2005 04:19
have a question to ask about Double Solenoids to one spike programming davelu Programming 3 22-02-2005 09:52
How does your team wire your Double Solenoids? Doug G Pneumatics 14 17-02-2005 23:25
solenoids from last year Antonio Pneumatics 6 29-01-2003 22:59
solenoids zarb Electrical 1 28-01-2002 23:19
