Go to Post Figure out where you have to start and what end result you want, from there, all you have to fill in is the middle. - Beth Sweet [more]
Unread 29-03-2005, 00:26
s0lidMetal's Avatar
s0lidMetal s0lidMetal is offline
#0321 (Robolancers)
s0lidMetal is an unknown quantity at this point
Send a message via AIM to s0lidMetal
Searching for a Laptop
Our team had alot problems downloading code to the robot due to a corrupt serial port on an older laptop apparently, so I've been searching the web (and these forums) for hours but still haven't found any descent laptops with a serial port. I'm looking for something small, light, and with a long battery life (w/ a serial port of course). Is this realistic or will I need to use a dock? Any suggestions?
Unread 29-03-2005, 00:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Searching for a Laptop
You could try ebay
Unread 29-03-2005, 00:44
dm0ney's Avatar
dm0ney dm0ney is offline
Will Code For Food (Food Optional)
AKA: Deepak Mishra
None #0217 (The ThunderChickens)
dm0ney will become famous soon enough
Send a message via AIM to dm0ney
New laptops usually dont include serial ports. A cheaper alternative might be a USB->Serial Adapter for the current computer.
If you really want a new laptop, I'd say go for an older one say an Inspiron 4000 or so.... the adapter is probably the cheaper way to go or you can always get a brand new laptop and get the adapter for that one.
IBM hmmm X series I believe is the one which is ultra portable but IBMs are quite a bit more expensive as a whole, though my favorite kind of laptop.
PM me if you want some more advice possibly.
Alumni
Team #217, The ThunderChickens
Student, Class of 2009
California Institute of Technology
Unread 29-03-2005, 00:48
Billfred's Avatar
Billfred Billfred is offline
Be careful with these--1293's used one in the past to program from a laptop, and we've had quite the time trying to keep it functioning. Most of the time, we now use a desktop (thank goodness they still have serial ports!)
Unread 29-03-2005, 00:55
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
We have found that the USB adapters have an undue propensity to corrupt the download. We have tried loading with the USB cable, and then uploaded with a serial port to find inconsistencies between the two versions. This year HP sponsored us and gave us some laptops with serial ports on them.
A computer company is a good sponsor, another team in our area got a local computer store to sponsor them.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 29-03-2005, 00:56
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
slickdeals.net Dell has some really good coupons
You dont need a laptop with serial. You can use Serial to USB. It works well.
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
Unread 29-03-2005, 01:30
If you're looking at new laptops, the Dell 600m has a serial port, and is light (less then 5 lbs), fast (centrino), and cheap (< $1000 for barebones).
The IBM X and T series are great, but at least the newer ones don't have serial ports (I own a T 40).
As for USB-Serial adapters, some work great, some work poorly, and some don't work at all. I have an FTDI adapter that works perfectly (once I got the drivers installed properly). Joe Johnson and others recommend one by BAFO. Don't get one that is designed for PDAs, as they typically do not have all the handshaking lines that the IFI loader requires.
Unread 29-03-2005, 01:33
dm0ney's Avatar
AKA: Deepak Mishra
USB adapters can be iffy...
Our engineer has two of them... one downloads VERYYYYYY slowly while the other is as reliable as a regular serial port.
In fact, I've used one before so I can see Dashboard and Load at the same time on the same computer.
I can get the type of adapter we've had good luck with and PM you with it.
Agreed bout the HP sponsorship deal.
Although our school district does lend laptops out for the programmers that need them... I actually just get one because the more computers, the merrier so I have my own personal one plus the school one in case.... only downside is together they way a TON regardless of how light each one is.
Alumni
Unread 29-03-2005, 01:43
CJO's Avatar
CJO CJO is offline
A good option would be to email IFI. They use USB serial adapters for the radios used in the IFI scanner. Obviously, these work with the IFI setup, so, whatever they use would work.
Alternatively, I believe that one can still purchase serial port PCMIA cards.
Unread 29-03-2005, 16:30
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
Always check the cables first (use one directly to the robot instead of a really long chain).
During one competition alone, we had two programming serial cables go bad, and the tether had to be shaken around to get the "Power" LED to fully turn on.
It may seem ridiculous, but make sure to have about 5 extra (unused) serial cables at hand, because we needed all but one at the competition.
Although we haven't had bad experience with the correct USB-Serial connectors, this year we made sure to have a laptop with a real serial plug in the back.
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Unread 29-03-2005, 21:05
s0lidMetal's Avatar
#0321 (Robolancers)
Thanks for all the advise, the main reason I was going to get a new laptop was because I've read many people had such horrible luck with them but perhaps I'll go for a PCMCIA or USB serial adapter. Although I wouldn't mind getting a free laptop from a sponsor :/ Is it common for a business to sponsor multiple teams at FIRST?
Unread 30-03-2005, 16:34
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I know. I used one just for dashboard (one way). And most of the time, it wouldn't even pick up packets! It was the right port and everything, but it was corrupting data or something.
Unread 30-03-2005, 17:36
Ted Boucher Ted Boucher is offline
Its been awhile.....
FRC #0237 (Black Magic Robotics)
Ted Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond repute
Team 237 has been though this stage already and IFI website helped us out. This thread/post (read the last post) talks about the USB to Serial adapter situation and they suggest the Radio Shack Model 26-183. It is a little expensive but it works great with all of our laptops. We have used it to calibrate our CMU Cam and to program the robot with very little issues. LOL.. When you plug the RC into a laptop with that converter, Windows says, "New Hardware found: Microsoft Mouse" .. don't worry, it is nothing to be concerned about.
FRC Team 237 Alumni (04-07)
Western New England College Class of 2011
FRC Team 237 Mentor (11-?)
A Laptop Like You Eugenia Gabrielov Chit-Chat 3 28-02-2005 21:03
A Searching Tutorial Katie Reynolds CD Forum Support 5 03-02-2005 16:39
searching for sponsors n0cturnalxb General Forum 17 21-09-2004 06:14
Can I turn off the touchpad on my laptop? (Dell Inspiron 8100) Elgin Clock Technical Discussion 8 03-07-2004 13:59
Laptop Looser at Manchester Regional natebrown77 General Forum 2 31-03-2004 16:10
