Go to Post I heard a Lou Holtz quote as an answer to the question of "how do you motivate the unmotivated". He said " You eliminate those who are not motivated." - Scott Ritchie [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 01-04-2005, 11:43
steven steven is offline
steven is an unknown quantity at this point
How to use Generate_Pwms() ?
Hi,
I've been playing around with the Mini First Robotic Controller kit recently and haven't been able to get pwm 01 ~ 04 (USER control) to Generate Pwms (setting the Setup_PWM_Output_Type(IFI_PWM, ......) ). Does anyone have more details on how to use the Generate_Pwms() ??
void Generate_Pwms(unsigned char pwm_1,unsigned char pwm_2,
unsigned char pwm_3,unsigned char pwm_4,
unsigned char pwm_5,unsigned char pwm_6,
unsigned char pwm_7,unsigned char pwm_8);
also, if i intend to use the pwm01 ~ pwm 04 as I/O, which pin are they reffering to? I know there are CPP1 to CPP4 pin on the 18F8520 Chip.
Cheers!
