Go to Post Patience, grasshopper. They'll get to it. - Rick TYler [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 07-03-2005, 19:07
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Halo 2 Tournament
Hey, I've heard rumors of a halo 2 tournament during the Championships... any truth to it? If not, anyone wanna help me set one up?
http://www.mikesorrenti.com/
Unread 07-03-2005, 21:48
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Re: Halo 2 Tournament
Hmm, there will be, I'm sure of it. Last two years i've set up entire networks at the hotels i've stayed at. Let me tell you, airport secuity was perplexed when they saw I had over 1k feet of cat5 and network switch gear + xbox in my carry on. (some things are more important to carry on). we stayed at the westin last year, and I had cat5 running in the stairwells to other floors to play against other teams. This year I'm staying Mariot Marquis, not the west in, which was an awesome place, but the time it took to get any where do to the crowding was nuts. Great rooms though. No doubt i'll have enough cat5 and switch gear to set up some massive multiplayer bouts.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 07-03-2005, 22:42
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
I know we've been thinking of having some games.. wireless network of course.. provided I can get my laptop to bridge the wireless and ethernet networks. We're in the Holiday Inn, and it will be a 802.11b network
Anyone else staying there that wants to have some games? We would need another xbox
I'm actually hoping to go get a 500ft box of network cabling, so that would work
Unread 14-03-2005, 15:23
coreyjon's Avatar
Flight Engineer
500ft or so should do ya, no need to go crazy like me. Wireless is nice, I think I have a wireless router lying around somewhere, Got it for free for buying something else at comp usa a while back, now just to remember where it is. I wonder how far away your hotel is from ours....I;m experimenting with building long range yagi antennas. (12+ Db gain) and more at night, which is when we would probably be playing anyway...so we could probably create a long range wireless network, if you had an antenna, and I had one, and we pointed them at each other, assuming some type of line of sight, it may work. I'll research where your hotel is and I'll compare it to where my hotel is, if by some chance there could be a line of sight, we could create a network for lan gamming, might be a fun experiment. if we have a good line of sight, we should be able to carry more than enough bandwidth over the short distance. This setup would work for about ten miles under ideal conditions.
which holiday inn are you staying at? The one on intl' blvd? We are staying at the marriot marquis, so once I know which one your staying at, I can determine if it would be possible.
Unread 14-03-2005, 16:21
Hokie4Life's Avatar
Hokie4Life Hokie4Life is offline
AKA: Warren Rodgers
#0401 (Hokie Guard)
Hokie4Life is an unknown quantity at this point
You could ad hoc between two or more x-boxes using the game wireless adapters. That would seem to be easire than lugging around lots of Cat5 cable.
Thats my $0.02
Winner-VCU Regional 2005
Captian of 3rd seed-VCU regional 2005
Motorola Quality Award-VCU regional 2005
5th seed-VCU regional 2004
Semifinalist-VCU regional 2004
Unread 14-03-2005, 20:53
coreyjon's Avatar
Flight Engineer
yea, but in the past the cat 5 has worked great, as long as we manage to keep it out of the way (hide it) no one bothers with it, and we do it late at night, and clean it up before anyone is the wiser. That way not everyone has to have a wireless adapter. right now I'm experimenting with a Yagi antenna built from a Pringle's can to increase the gain by 12 DB's or more. So, if we wanted to play against other people in the other hotels...we could. I'm even testing passive repeaters to get the signal around corners, but I doubt I'll lug everything down to Atlanta, I may bring two Yagi's, so if I had to I could set up a long range wireless link to another hotel. We'll see, I'll bring enough gear to get up and running, I'm sure others will bring gear, and I'm sure there will be some LAN gaming. Idk, maybe if you interested in building your own Pringle's can Yagi antenna, scope out this link.
http://www.oreillynet.com/cs/weblog/view/wlg/448
Unread 14-03-2005, 21:06
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
I have waited for this thread for um....SO LONG
I am in... I have about 40 feet of cat 5 heh.
I will bring my box and all the goodies like halo1+2 and 4 controllers
Maybe we should get some cell phone numbers around through IM's or PM's or w/e to organize it once we get to the hotel.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 14-03-2005, 21:24
Rookie Year: 1234
I have to wait until I get a replacement MB for one of my computers.. then I can start trying to see if my laptop can bridge a wireless and wired network. Otherwise I'll have to think of something else
Unread 14-03-2005, 21:50
Masterfork's Avatar
Masterfork Masterfork is offline
Joshua Hunnings
AKA: Fork
FRC #0233 (the pink team)
Masterfork is a jewel in the roughMasterfork is a jewel in the roughMasterfork is a jewel in the rough
Send a message via AIM to Masterfork Send a message via MSN to Masterfork
Cool Re: Halo 2 Tournament
well have a router and a 20ft. etherenet cable and can get a 100 or 50 but i can't bring my x-box
2007 World Championship Finalist thank you 71 and 179
2007 Archimedes undefeated Champions thanks 179 and 71
2007 Florida regional semifinalist thanks 180 and 1889
2007 Florida regional Spirit Award
2006 Archimedes Division Finalist
2006 Boston Champions
2005 UCF Regional champions thanks 1592 and 179
2005 Colorado Regional champions thanks 118 and 935
2005 Colorado Regional Chairmans Award
IRI 2005 - Champion thanks to 33 and 868 - it was a GREAT event
2005 World Championship - GM Industrial Design
Unread 14-03-2005, 22:03
coreyjon's Avatar
Flight Engineer
Looking at a map, it shows my hotel, and the holiday inn about 1/3 of a mile away. My hotel is a 50 story beast, so line of site is still passable if my room is somewhere close to the south west corner of the building. The distance is so short that I'm not even worried about creating a network, I would still be interested in finding hotels farther away to establish a network with. Halo LAN game here we come. The games will probably be held late at night cause I'm sure we will all have things to do. Like swimming in the pools, enjoying the hot tubs, and hanging out with friends. Getting everyone's cell phone numbers is a good idea, I think that should be done in email or PM's as well.
Unread 17-03-2005, 21:44
neilcooper neilcooper is offline
neilcooper will become famous soon enough
we would need xbconect to do 32 people over wired/wireless and my comp has wireless in it and i am in embasy sweets
Unread 18-03-2005, 13:54
Rookie Year: 1234
I don't believe so. It really depends on the range of the wireless networks. I'm actually hthinking about buying a 5db antenna for my laptop.. instead of my current one which has an integrated card and antenna.
If the wireless reaches, we would be able to form an ad-hoc wireless netowkr, meaning the xbox's would be going over the lan, not the internet. Its the same thing if you take 2 xbox game adapters (which are nothing more then wireless bridges) and use them to link the system.
Unread 23-03-2005, 13:55
Don Vito's Avatar
Don Vito Don Vito is offline
#1279 (Cold Fusion)
Team Role: Human Player
Don Vito will become famous soon enough
If a game gets going, myself and two other team mates will gladly participate. To be an egotist, I think we're pretty good too. I'll try to keep updated about it.
Winner of 2004 Rookie Inspiration Award at Trenton
Winner of 2005 Trenton Competition. Allianced with 375 and 103, good job guys.
Placed Second Seed at Trenton 2005
Placed First Seed at VCU 2005, quarterfinalists with teams 1545 and 384.
Unread 31-03-2005, 00:30
wilshire's Avatar
wilshire wilshire is offline
OSNAP. a gear flew out of the robot
wilshire is just really nicewilshire is just really nicewilshire is just really nicewilshire is just really nice
Send a message via AIM to wilshire
yeah I am going to try and bring one maybe two xboxs and all the networking gear I can possibly find. I am certain I have one wireless bridge. Not sure where the other one is. also if any of you play on xbox live please send me a FR at wilshirepossey. not sure where I am staying but I will garuntee their will be Halo action at my hotel.
Unread 01-04-2005, 22:55
Padfoot Black's Avatar
Padfoot Black Padfoot Black is offline
Former Fearless Leader!
AKA: Justin Judkins
FRC #0350 (Timberlane Robotics)
Padfoot Black is an unknown quantity at this point
Send a message via AIM to Padfoot Black
team 350 is planning on having three xbox's bridged to a wireless network at the Holiday Inn Downtown, and we would love to play with some other teams!!!
Justin Judkins
Captain
Timberlane Robotics (Team 350)
2005 BAE Regional Champions w/ teams 121 and 126!!
We are forever grateful to 121 and 126 for choosing us.
Halo 2 Tournament @ Sac. Regional blue_crew Regional Competitions 31 07-03-2005 16:25
3rd Annual Tournament of Rosie Golf Scramble Rosiebotboss General Forum 0 10-06-2004 14:59
Halo 2 @ the Canadian SUPER Regional Yan Wang Chit-Chat 7 01-02-2004 13:56
Is the tournament still on? wbhsAndy OCCRA 0 13-11-2003 10:10
HALO for PC September 17, 2003 Ryan Albright Chit-Chat 3 17-07-2003 09:00
