Go to Post And like Woodie told us in his talk, all the bad stuff we anguished over will be replaced by the memories of the achievements and good time we had this year. - Wayne C. [more]
Unread 29-03-2005, 18:54
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Code Emulator
Hey,
I'm looking for a code emulator, something kind of like roboemu but one that will let me see where on the field my robot is. Anybody have something like this?
http://www.mikesorrenti.com/
Unread 29-03-2005, 19:22
dm0ney's Avatar
dm0ney dm0ney is offline
Will Code For Food (Food Optional)
AKA: Deepak Mishra
None #0217 (The ThunderChickens)
dm0ney will become famous soon enough
Send a message via AIM to dm0ney
Re: Code Emulator
Are you looking for some program that would take encoder counts to determine where on the field the robot is? I do not think any exist at the moment, as I was going to write one a few weeks ago and then decided not to.
Alumni
Team #217, The ThunderChickens
Student, Class of 2009
California Institute of Technology
Unread 05-04-2005, 03:15
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
Re: Code Emulator
The best way to do this would be to hack up RoboEmu to calculate the angle and position based on the speed of the robot.
A really good way to do it would be to take a CAD model of your robot, hook it up into a 3d engine and allow the tetras to be separate objects. Then, make your robot's position be affected by PWM motor values (add a randomness and non-linear factor too). This project is definitely possible, and really isn't too hard, assuming you have the time to take all these different engines and attach them together.
Aside from this, there isn't any easier way to do it without cheating by using a 2d-model, and hard-coding arm positions for picking up tetras.
Just determining field positions (no arms or tetras) is really easy, and I was planning on doing that (change angle by difference of motor speeds, set velocity to motor speeds, ramping up velocity based on the pwm value), except I didn't know QT too well, and especially not the drawing part of it.
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
