Go to Post Come on baby, do the logomotion with me. - JaneYoung [more]
Unread 05-04-2005, 17:28
Re: use of electrical sliprings
And it's going, going, it's out of here! Yes that is the answer I was looking for. If you think about the forces involved, a fast acceleration or a hit form any side transfers the forces through the fulcrum created by the gearbox directly to the upper joint and there is virtually no way to compensate without a prohibitively large bearing surface. A ring at the bottom of the assembly that mates with a stationary assembly on the robot frame, transfers all lateral movement directly to the frame and very little to the the upper bearing. Side movement is reduced to a fraction of an inch, an nothing in the gearbox is sacrificed. Good practice also dictates your first statement. Without cross bracing, (I assumed it was left out for clarification) the gearbox pulls easily out of alignment, shooting frictional losses in the bearings through the roof. An enclosed gearbox or one with bracing prevents bearing and gear misalignment and keeps the drivers happy.
Unread 06-04-2005, 01:52
dradius's Avatar
dradius dradius is offline
breakdancaz
AKA: ryan
FRC #0624 (CRyptonite)
dradius will become famous soon enough
Send a message via AIM to dradius Send a message via MSN to dradius
Ah, now THAT makes more sense! Sorry, running on no sleep and hating baseball doesnt seem to help my problem solving and analytical skills too much.
we pretty much did that already though...best of my knowledge. I'd have to pull the robot out of jesse's....garage? I don't even remember where it is anymore. Oh dear.
pessimist: glass is half empty
optimist: glass is half full
engineer: glass is twice the size it needs to be
--bringing green spikes and fishnets back in to style, baby--
Unread 06-04-2005, 12:18
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Originally Posted by Matt Reiland
Well we have done 4 wheel steering also in the past, based on the picture I would either:
:: Listed great ideas::
Is this what you are looking for Al?
geeze Matt, you're making me look bad! Last time I ever try to wander into the electrical forums... even if it's about something mechanical!
Now I need to try to redeem myself with another fancy pants work of art...
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 06-04-2005, 23:25
MasonMM's Avatar
MasonMM MasonMM is offline
AKA: Mason Markee
FRC #0118 (Robonauts)
MasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond repute
Originally Posted by dradius
so, what do you suggest from a personal standpoint instead of using bevel gears? we made a prototype, and there didnt seem to be too many issues. we were originally concerned with the amount of play in the gears, but it didn't seem too bad. then again, i havent made a fully functional robot with those kind of wheelbases.
A little late but anyways. We've used bevel gears the last two years in our crab drive. And now this year in our turret. In the wheel boxes for our crab drive we locked them in tight and haven't had any negative effects like slipping or coming out of place. The wheel boxes use 1:1, and our turret uses 2:1 this year, and i must say they are grand for our purposes.
Easy to swap out electrical controls? cbolin Electrical 13 25-12-2004 11:37
Electrical Tips for Rookies Anne Shade Technical Discussion 15 03-12-2004 12:08
[OCCRA]: Electrical box #1Transgirl1140 OCCRA Q&A 1 24-09-2004 18:54
Looking for team 217 Electrical mikey1126 Electrical 15 21-04-2004 22:10
How does your team organize its electrical supplies? Josh Hambright Electrical 8 28-11-2002 13:01
