Go to Post I believe that FIRST in itself is a reward. - link871 [more]
Unread 06-04-2005, 01:43
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
Re: How did you do your axles
Our team used a friction fit in alu shaft with cotter pins and spacers to keep it in place. Alu shafts fit though the holes in our alu frame. Can anyone see the issue here? We found out pretty quick that this wasnet the best idea, they were hard to remove after use, and we had alot of problems with them binding in the holes and mushrooming when we were trying to remove them. one had to be hacksawed off and nearly drilled out! We are going to design something better next year.
axles for the wheels? haverfordfords Technical Discussion 2 25-01-2005 18:30
axles? SPARKY1688 Kit & Additional Hardware 1 15-01-2005 01:26
Where can I get sprockets, drive axles, etc. SPARKY1688 Kit & Additional Hardware 1 13-01-2005 20:59
axles maxgebhardt Kit & Additional Hardware 1 15-01-2003 19:00
Are bolts to hold wheels on, and bearings, considered "fasteners"? kmcclary Off-Season Events 3 22-10-2001 23:35
