Go to Post I want to win, but I want to beat my opponent when they are at their best. - wilsonmw04 [more]
Unread 06-04-2005, 08:23
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: How to measure low velocity
Originally Posted by nobtiba
ADXRS150's resolution is 0.004 degree/s but when I rotate the table by hand slow enough (still can observe by eyes) the gyro seems not to reaction. So how can I do?
How are you measuring the signal? Are you using and oscilloscope, or are you using the FIRST controller to integrate a heading?
If you are using the FIRST controller, the resolution is less than said. The ADXRS150 measures approximately +/-150 deg/s, which means it measures a total range of 300 deg/s. The FRC has a 10-bit A/D which means you have 1024 A/D counts. Therefore, your resolution is 300/1024 = 0.293 deg/s.
Do defensive, low scoring tactics work? haverfordfords Rules/Strategy 37 18-02-2005 12:25
Rotating the motor cage to lock in LOW sanddrag Motors 3 10-03-2004 07:23
How to measure execution time? And code size? gnormhurst Programming 17 17-02-2004 08:06
Bug: Login Problems - Session timeout value too low? DanL CD Forum Support 4 09-01-2004 16:33
Tape measure proboscus tito General Forum 24 29-04-2002 15:56
