Go to Post Patience is the key to FIRST. - Pavan Dave [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 07-04-2005, 11:55
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Online Engineering Tables
I'm trying to do an analysis of a frame in Pro/Engineer, and I need to enter material properties. No one in the office has an engineering handbook with the values I need, and even Google is having problems finding what I am after. I'm looking for the material properties of type 304 Stainless Steal (304SS). If anyone could point me in the right direction, that'd be great! Below is what Pro/E spit out at me...
          MATERIAL  304SS
This file may be edited using available editor.
Just type on the necessary lines appropriate values
after the "=" sign. Comments are not permitted on
lines containing material properties names.
YOUNG_MODULUS			=
POISSON_RATIO			=
SHEAR_MODULUS			=
MASS_DENSITY			=
THERMAL_EXPANSION_COEFFICIENT	=
THERM_EXPANSION_REF_TEMPERATURE	=
STRUCTURAL_DAMPING_COEFFICIENT	=
STRESS_LIMIT_FOR_TENSION	=
STRESS_LIMIT_FOR_COMPRESSION	=
STRESS_LIMIT_FOR_SHEAR		=
THERMAL_CONDUCTIVITY		=
EMISSIVITY			=
SPECIFIC_HEAT			=
HARDNESS			=
CONDITION			=
INITIAL_BEND_Y_FACTOR		=      5.000000E-01
BEND_TABLE			=
PRO_UNIT_MASS			=
PRO_UNIT_LENGTH			=
PRO_UNIT_SYS			=      millimeter Kilogram Sec (mmKs)
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 07-04-2005, 13:17
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Re: Online Engineering Tables
Matweb.com has properties for quite a few materials, including several types of 304 Stainless Steel from various vendors. I don't know if it has enough information for your purposes or not.
Unread 07-04-2005, 13:33
rachakate's Avatar
rachakate rachakate is offline
Life's Good
AKA: Kate Leipold
FRC #0340 (Greater Rochester Robotics)
rachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud of
Send a message via AIM to rachakate Send a message via Yahoo to rachakate
If you check the Pro/ENGINEER forums on mcad.com there is a file section that you can access with a free account.
They have a folder of material properties that you can import into your Pro/E.
Unread 07-04-2005, 13:47
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
EFunda: AISI Type 304
That should be most all you need. Shear modulus could be calculated, but you can probably leave it blank. The tension and compression stresses are defined by you, really. Typically you design to yield as a first iteration. Shear limit can be calculated as well. Emissivity doesn't matter unless you're doing thermal modelling, and even then is highly dependent on surface finish. Condition probably doesn't matter, nor should anything below it.
Unread 07-04-2005, 14:07
SuperJake's Avatar
No Problem!
AKA: Jake Classic
Talking Re: Online Engineering Tables
Thanks! These are really great refereces!
Engineer Survey: Engineering Vs Engineering Technology D.J. Fluck General Forum 16 27-06-2012 09:16
Introducing the Driver Strategy Database's Online Database impulse3D Rules/Strategy 17 17-03-2005 03:04
Columbia University Engineering Waynep General Forum 5 12-04-2004 02:01
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
Engineering vs. Engineering Technology archiver 2000 4 24-06-2002 00:07
