Go to Post Brace yourselves, reality check incoming. - EmileH [more]
Unread 08-04-2005, 15:09
savage's Avatar
savage savage is offline
FireFighter Paramedic
AKA: Ben White
FRC #1368
savage will become famous soon enough
Send a message via AIM to savage
servos
how much weight can the servos take on them
how much can they move
Unread 08-04-2005, 15:17
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: servos
http://shopatron.com/product/product_id=RCD33322J/110
http://www.mikesorrenti.com/
Unread 08-04-2005, 16:12
savage's Avatar
AKA: Ben White
FRC #1368
Re: servos
do you thingk they are strong enough to hold back 7 kg
iam making a catapult and going to use it as a trigger.going to use a servo i have that is the same that came in the kit
Unread 08-04-2005, 18:09
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: servos
No, but it might (and I say might) be strong enough to pull out a small pin that is holding the 7 kg.
Unread 08-04-2005, 18:16
Matt Reiland's Avatar
'The' drive behind the drive
Re: servos
You could mount the pin such that it is supported on some rollers or bearings so that there is only a very small force required to pull it out.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 09-04-2005, 20:52
savage's Avatar
AKA: Ben White
FRC #1368
Re: servos
thanks guys i will consider it
i might use an old fiser price that i have
ill put a pic of it up when iam done
hoe full it will work
Hooking up 2 Servos kutty18 Programming 7 04-02-2005 09:26
questions about the servos Alex Golec Motors 1 23-01-2005 20:05
using older servos pryoplasm Kit & Additional Hardware 4 24-01-2004 20:22
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
servos, chapulas, cylinders and Skyway...in other words... Jessica Boucher Motors 7 14-01-2002 19:36
