| View Poll Results: You Make The Call | |||
| 10 Points for Redalliance ... Redalliance is going to the Championships! |
31 | 70.45% |
| Only Two Redalliance 'bots in the End Zone! Blualliance is going to the Championships! |
13 | 29.55% |
| Voters: 44. You may not vote on this poll | |||
YMTC: Bluabot Pushes Red Vision Tetra
You Make The Call (YMTC) is a series of situations where you are the official and make the call. Please reference specific rules when applicable. The results of YMTC are not official and are for educational purposes only.
With 15 seconds remaining in the rubber match of the Magnolia finals, Redalliance is losing by 2 points when Redabot is the 3rd Redalliance 'bot in the end zone resulting in a 10 point score and an 8 point Redalliance lead. With no hope for Bluabot to score a tetra nor for all 3 Blualliance robots to go "home", Bluabot pushes a nearby red vision tetra toward Redalliance's end zone. With time running out, Bluabot manages to push the vision tetra against Redabot with the other side of the vision tetra touching the carpet outside the end zone. Based on the 2005 Game Rules, YOU MAKE THE CALL! |
Re: YMTC: Bluabot Pushes Red Vision Tetra
In a different scenario ..
The last ten seconds of a match bluabot is pushing redabot, while redabot is trying to cap a tetra. The match ends and redabots arm is still in contact with the capped red tetra. The judges would not count the red tetra and would consider it an extension of redabot. I think the judges should count the red vision tetra as an extension of redabot. Blue alliance wins. |
Redalliance gets their 10 point bonus.
The revlevant rule: Quote:
Of course...it really isn't this straight foward, is it? All this stuff about tetras being part of the robot. I'd choose to believe that it's only true regarding a human player touching the tetra. But my preferred precedent here is that of a robot starting with a tetra. Quote:
Why, when loading a tetra of course! Touching a tetra already on the robot is a violation of <S07> for touching your robot. Notice, this is a safety rule. Touching a tetra already on the bot is a bit of a safety concern. Aside from that, though, is there any other reason? |
Well, in one match at buckeye, we had every bot across the line, but one of them had brought a tetra into the end zone. From our viewpoint, it was no longer touching the tetra, it just had its manipulator inside with no contact, We didn't get the points because the judges thought it was touching. So while this situation isn't very GP, blue wins
#8
We had a sort of related problem at Portland, the pacific northwest regional semis. We lost by 2 points 39-37 in the third match, our alliance partner pulled their 3rd alliance partner out of the endzone wiht about 1 second left and they were no longer in the endzone but still touching the robot on our alliances robot. I never got clarification on exactly what the ruling was but it was definatly a close match like the one described above.
#9
ID: 1852 Section: 4.3.3 Status: Unanswered Date Posted: 4/6/2005 Q: Please identify ANY and ALL cases in which a TETRA is considered and extension of a Robot. Is it ONLY during the HP loading function, or are there other situations this applies? And also ID1849 and 1851 which ask more specific questions. Hopefully the answer comes back as per the existing rules, that a tetra is only part of a robot in the case of the (HP) loading station (I'm pretty sure that's the only case right now). The situation below me is an interesting one. I think if the robot would clearly be in the endzone if the tetra were removed, then it should count. However - let's say the robots arm is resting on top of a tetra outside the endzone. If they remove that tetra, the arm most likely falls down and hits the floor, therefore making it outside the endzone. Do the refs remove the tetra to see if that happens? I would say they should, as now it's not a matter of just touching a tetra outside (which should be fine), but now it's being supported in a manner where they shouldn't be considered in the zone. Last edited by AmyPrib : 10-04-2005 at 02:41. |
#10
As has been discussed, the only time a tetra is considered part of a robot is when it is being loaded from the human player. If the robot is holding a tetra and that tetra is touching a stacked tetra (of same color), the stacked tetra still counts because the robot is not directly touching it. As long as no part of the robot is touching the carpet outside the endzone, it is in the endzone, whether or not it is touching anything outside the endzone.
Now if the blue team managed to get the tetra under the red bot so that the red bot is supported by the tetra, which is touching outside the endzone, that is a different story - one that I would say does NOT give the red alliance three bots in the endzone. I suppose one could argue that if the tetra were removed, however, that the red bot would fall into the zone and still be counted. Hmmm...that is a situation that would be a tough call (unless I am completely forgetting about something in the rules!). Kev |
#11
The tetra is not an extntion of the robot period. Red wins.
#12
During one of our qualification matches at Detroit, the other alliance had all three of their robots behind the line. But one of them was holding a tetra that was touching outside the line. They did not get their 10 points because of that tetra.
If the rules are followed to the letter I believe that the red alliance would lose their ten points |
#13
Edit: That'd only be in terms of a any contact the bot makes, though. If the bot is controlling it, then why should it be allowed to make any contact the bot can't. Still, on this idea, you could say the tetra you're trying to score as time runs out is touching the one under it, therefore disqualifying both :/ Another reason contact after it is scored and backed away from shouldn't descore a stacked tetra. Last edited by Goldeye : 10-04-2005 at 13:39. |
#14
With the exception of when the robot is interacting with the Human Player in the Loading Zone, a tetra loaded on a robot is not considered an extension of the robot (the one exception is for safety reasons). Having a red tetra touching the Redabot does not negate the fact that Redabot is behind the End Zone line. Redabot is legal, Redateam gets the 10 point bonus, Redalliance wins! The one difficulty with this problem is that in order to satisfy the YMTC requirements (i.e. cite specific supporting clauses from the 2005 Rules to support your argument), we would have to find a rule that specifically says that an attached tetra is considered part of the robot (or not considered, if we want to prove the negative) at any other time. I do not believe that any such rule exists. At best, we must work within the definition of "Robot" provided in Sectino 4.2.1 of the rules, "ROBOT – Anything (which has passed inspection) that a team places on the field prior to the start of a match." That definition does not include any mention of a tetra. Therefore, the game must operate under the interpretation of "robot" as not including a tetra placed on the robot. That is probably as close as we can get to making this a complete YMTC response. Quote:
-dave |
#15
| YMTC: Bluabot "Descores" Red Tetra | Natchez | You Make The Call | 34 | 09-04-2005 15:02 |
| YMTC: Bluabot "Slinkys" Tetras | Natchez | You Make The Call | 15 | 08-03-2005 14:00 |
| YMTC: To Score Or Not To Score ... | Natchez | You Make The Call | 9 | 24-01-2005 19:12 |
| YMTC: Bluabot sits on Redabot | Natchez | You Make The Call | 19 | 08-04-2004 16:43 |
| YMTC: Bluabot and Redabot hanging? | Natchez | You Make The Call | 15 | 23-03-2004 01:42 |
