Re: Strange system problem
I would suspect a mechanical bind and/or poor electrical connections. I'm leaning towerds a bad connection.
Do a resistence test on your frame and battery- Shorting to the frame could easily drop your voltage low enough to reset your controller if the nicad is not charged. That short may be in the wiring between the motors and victors, so it wouldn't show up unless the victors were supplying power. Carefully inspect all the drive motor wiring by hand, looking for abrasions and pinched wires, crimps that may be working loose or any exposed conductors. I also suggest that you remove breakers to all your drive motors, and plug them back in one at a time till you have tested each motor through the speed range individually. While you do this, use a multimeter with a clamp type ammeter to monitor the current draw of each motor. On blocks, each motor should draw something like 5 amps (thats been a typical number for my team, others may consider that high or low). If a motor is higher then others, or one side of your drive is drawing more then the other, you've narrowed your problem down to a binding or a loose connection. Also check the current draw from the battery while the robot is at rest and when the drive starts to move. Look for a high draw at rest, which would indicate a problem in breakers or associtated wiring (as opposed to the wiring from the victors to the motors). The electrical problem is easy enough to deal with, since it'll probably just need a little electrical tape or a tighted screw. If it's mechanically related, you'll need to figure out just where all the excess friction is coming from. Are you using the kit gearboxs? What motors are driving? Are all your motors moving in the right direction? Do you have a compressor on board? -Andy A. |
Along the electrical issues line of trouble shooting...
Check the screws in the lugs for the battery cable. Ours came loose at least twice during the season. We had to check them every few matches. Although I don't think this sounds like your issue, it's still a good thing to check and eliminate during the trouble shooting. Good luck finding the "ghost in the machine". |
I would say a problem with a battery - either main or backup. Try and make sure you have one of each charged and ready to test the problem if it ever happens again. You may also want to try buying new batteries as recharging them too much can drop their output voltage.
Just an idea, but in 2003 at Houston, we had a dificult Saturday morning. Everything ran fine on our robot Friday evening, and the next morning the robot only ran autonomous. When the 15 seconds were over, the robot would not respond to any operator controls. The best we were able to figure is somehow the code got corrupted (static?). Anyway, we went through two matches before we found the problem. Yes, look at all the battery problems mentioned, but also re-download your code to make sure it didn't get corrupted somehow.
The IFI representative on the field can give you a lot of information about what happened, for example, low battery, low backup battery, code errors, or loss of radio.
For anyone, if your robot acts strangely, you should ask the IFI representative immediately if they saw anything. It may save you a lot of time later on. |
#7
I'd say check all the stuff listed above with the batteries, and the shorts, and all that. And if your still having problems, track down one of the IFI guys and see what they cant do to help you. I know from talking with the IFI reps at Boilermaker and MWR and observing their software in action, they can tell alot about the control system from their handy dandy laptop, everything from disconnected modems to a dead backup is easy to diagnois for them |
#8
I suspect that the voltage isn't getting to the controller. Because we have been better about it with the 04 and 05 bots, I don't know what it would do, but the older bots (that didn't have the backup battery) would look like they were contenously reseting if the battery was low. I also know that sometimes the 120A breaker starts to cause massive resistance if used too much. it will try to disconect, but the bimatalic spring is worn out and causes more resistance. This volatage drop can cuase the controller to reset. The voltage drop could be anywere, but we found that the main breaker can go bad after extended use (don't try to break them in).
#9
Thanks! this is great info/advice. I feel much better about our prospects of resolving it quickly now. We will need to borrow a clamp ammeter from someone though.
In Reply to Andy's questions: Quote:
#10
Bill, and all teams, if you need any help or resources in the pits, check with our pit crew. We'll do our best to help get your robot back to tiptop running condition. I'll check with The Lucas tonight to see if we've packed the type ammeter you need to borrow. Good Luck at Championships!!! (Where are those Divisions? It's already 9:45 AM!! Impatient? Who, ME?) |
#11
As for your problem, I would guess you are overloading your CIM motors (only one per side) particularly in high gear. I see from your website that you are using 4 thick rubber wheels which would require a lot of torque/current to turn. You can check for breaker trips by looking at the LED on the breaker panel. If it turns yellow or red, you are tripping breakers. In the default code, the OI user byte can tell you which breaker was the last to trip if you put a serial cable from the breaker panel to the program port. I would be happy to help you diagnose the problem; I am usually in our pit. |
| Strange Auto Problem | NotQuiteFree | Programming | 6 | 20-02-2005 17:12 |
| Programming Problem: Extremely Frustrating | chantilly_team | Programming | 19 | 12-02-2005 23:00 |
| Physics Problem | Venkatesh | Math and Science | 13 | 30-11-2004 20:30 |
| control system worth more than $500 | archiver | 2001 | 8 | 24-06-2002 02:00 |
| Ok, how much is the control system worth? | archiver | 2001 | 6 | 23-06-2002 22:05 |
