Go to Post I'm going to go out on a limb and say that we have to displace objects and/or robots in order to score points. - pfreivald [more]
Unread 10-04-2005, 18:59
Billfred's Avatar
Billfred Billfred is online now
One for you audio folks...
Alright, so I'm plotting and scheming up the Next Big Thing (tm) in college radio. And one element of that is the ability to record things out in the field.
I've got the ability to record something to my laptop, with an arrangement that looks like this:
Source -> Mic port -> Audacity (audacity.sourceforge.net)
However, since I'm all for taking it to the next level, here's my current plan:
Sources -> ??? -> Mic port -> Audacity
What I'm trying to figure out, in a nutshell, is how to do ??? on the cheap. Given my experience with headphones (and high school physics taught me they're related) and the slider some have on them to control volume, I believe a potentiometer in series with a source could do the job. Put a few in a nice and neat project box, and I think it could work for the job.
Thus, I have three questions:
1) Will such an arrangement fry my laptop?
2) Will such an arrangement deliver audio I can play on the air without flinching?
3) Is there a better solution for this?
Unread 10-04-2005, 19:03
Re: One for you audio folks...
what other sources do you want to record, besides a microphone?
what you need is a mixing board. Most have at least one stage of amplification built into each channel for isolation, so one input is not back-feeding the others.
You probabally can get a small battery powered mixer that is all analog. I cant recommend any off the top of my head.
Check ebay.
Unread 10-04-2005, 19:11
Andy A. Andy A. is offline
Getting old
FRC #0095
What exactly did you want this box to do? Did you want to mix multiple sources into your mic port?
What exactly is it that you want your final product to be? If all you want is to have multiple tracks playing at once, you could easily do it in audacity with out any additional hardware. If you wanted to have something like multiple microphones recording onto the same track at once, you can buy splitters that will run any number of devices into the one line-in. You can wire one your self, but my experience with audio wiring is that it doing it right requires a great deal of skill and probably more money then just buying something prewired.
I guess I would just like to know a bit more about what it is your trying to record.
-Andy A.
Unread 10-04-2005, 21:06
Billfred's Avatar
The idea is to record from multiple sources (essentially one or more mics, plus probably a CD or MP3 player) into Audacity at the same time. I'm adding an external music source, as opposed to just putting it in iTunes, to the mix for control purposes. Unless I'm missing something, Audacity only lets me get the whole mic input or the whole sound card output--and controlling the levels in software, where I only get one finger (the cursor) is a bit more cumbersome than being able to use the ten I was born with.
The simplest solution would be to use the splitters (I actually have one sitting on my desk right now), but since I can barely do an entire show without fiddling with levels in a controlled environment (the WUSC studio), it'd be hopeless out in the real world.
Of course, this would be a case where I forgot Dave's old adage of stealing from the best and inventing the rest. (smacks forehead)
I went on eBay, and I found a possible candidate for a mixer:
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Should I be looking for something similar, or am I not even close?
Thanks!
Unread 10-04-2005, 21:40
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
I am still unsure of what you are trying to record, so this may not apply. The "best" way to do it would be to record each source independently then mix them later in an audio editing program (I assume Audacity is one). This especially makes sense because it sounds like some of your sources are already digital (CD, MP3) and it would make no sense to play them back into a mixer then redigitze them. You will have better quality and more freedom to tweak the sound after the fact instead of trying to get it right at the time.
Team 1257
Unread 10-04-2005, 22:22
Getting old
FRC #0095
Bill-
I think I see what you want to do. That ebay item does look like something that could be useful to you- assuming it has an output for the mixed channel. If not, you would need to do some wiring of your own to get the mixed channel that is feeding into the cassette to run to the laptop. It's doable, but like I said before, custom audio work usually is poor compared to a professional.
-Andy A.
Unread 10-04-2005, 22:27
Billfred's Avatar
Here's another listing for the same item--I believe it has an output for the master channel:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=41480&item=7313239 123&rd=1&ssPageName=WDVW
And Max, the software's just to capture it so I can play it back. I'm not terribly worried if I screw up as I record, just as I'm not terribly worried if I punch the wrong button once in a while on the air. It's the beauty of college radio--keep it clean, and everything will work out in the end (not that I don't try to do a good show).
Unread 10-04-2005, 22:51
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Check out sites like musiciansfriend.com and the likes.
You can get usb digital audio interfaces that allow the hookup of many different sources and connection types, and some have built in mixers and other features. One of these would probably accomplish what you want.
You can also buy a small mixer, like a 4 channel one for under 100 bucks.
Hope this helps.
Josh.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 12-04-2005, 01:09
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
were you planning on doing this on battery power, or can you plug things into the wall?
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 12-04-2005, 02:27
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
That's a good question. A few more....what type are your inputs and outputs? Are they RCA, 1/8", 1/4", XLR? Are they line level (coming out of CD players and ipods and stuff)? Do you want to mix a mic too? How many sources do you want to mix? Do you want to crossfade between the inputs?
That mixer looks a little elaborate for what you want to do, unless you want to record on cassettes too.
It sounds like you want a DJ mixer, that will give you RCA inputs and outputs, a headphone output, and usually a mic input.
For the most part, Behringer will give you the best bang for your buck. Here's one to watch: http://cgi.ebay.com/ws/eBayISAPI.dll...4531 885&rd=1
Here's a couple new Geminis that are pretty cheap...
2 channel
4 channel
AND finally, if you aren't gonna be doing any mixing, and you can get away with switching between the devices, just get one of THESE and just disregard the yellow video plug (only plug in the red and white).
Let me know about those questions and I should be able to help you more
-Paul
Unread 12-04-2005, 08:04
Billfred's Avatar
Batteries would be great--but if push comes to shove, I can haul around an extension cord. (I'll probably do so anyway--recording is kinda battery-intensive for my laptop.)
By default, the plugs I've got are 1/8", line level. However, there's always adapters. Mixing a mic will be a must--for starting out, it will probably be a good computer mic due to cost. All told, I can't imagine needing more than four sources (two music, two mic). I can do without crossfading--never used it in the studio, so I doubt I need it now.
Thanks for all the help!
Unread 12-04-2005, 11:35
Paul H's Avatar
Renegade of Funk
AKA: Paul Huston
http://cgi.ebay.com/ws/eBayISAPI.dll...3759 354&rd=1
That's the only battery operated one I can find
http://cgi.ebay.com/ws/eBayISAPI.dll...4937 595&rd=1
That would be nice if you didn't need batteries
Although I'm sure there's probably a cheaper/more ghetto way of doing all of this too.
-Paul
Unread 12-04-2005, 13:47
Bill,
You should have started with me. I install broadcast audio for a living. The Tascam devices you are looking at on Ebay are really old, they are wrapped around a cassette recorder that in some models was confiqured as a four track device, only one side of the cassette. Depending on what you budget is, Mackie makes great little boards that have headphone outputs and lot's of features like solo and sub-mixing. Behringer also makes some great gear as well. I would recommend you check out Muscian's Friend, Sweewater or Full Compass. They all sell stuff for computer audio and there are many USB control surfaces that will turn you laptop into a powerful post production surface. There is one device from Digidesign that has two mic pre amps, and two line inputs and comes with ProTools software for I think about $400. Anything you might want is out there, and new is way better than used unless you know exactly what you want.
Unread 12-04-2005, 17:53
Billfred's Avatar
$400 is slightly out of the price range, but I think I've found a combination that should do the job for around $125:
http://www.musiciansfriend.com/srs7/...se_pid/180617/
http://www.musiciansfriend.com/srs7/...se_pid/700714/
It'd require a power outlet, but the more I think about it, the more I'd probably need it to keep from killing my laptop batteries anyway.
Am I getting warmer?
Unread 12-04-2005, 18:39
Bill neither of these devices have a mic preamp. They will only mixe line level signals like tape decks, CD players, etc. You can't go wrong with the MBox or the Lexicon Omega package. There are other devices on this page...http://www.musiciansfriend.com/srs7/.../search?c=9115
At $59 bucks this little mixer could get you what you want with no software just a simple little mixer. http://www.musiciansfriend.com/srs7/...se_pid/631237/
This one has faders for $119 http://www.musiciansfriend.com/srs7/...se_pid/631235/
DSK Roadie and FOH mixer
audio quality? syntaxers 3D Animation and Competition 0 21-02-2005 22:56
Audio to Inventor daramana Inventor 6 31-01-2005 02:44
Streaming quality audio over a phone line? Billfred Chit-Chat 0 09-12-2004 00:26
Car Audio on a Cart - Alternatives to Battery Power? DanL Electrical 28 04-02-2004 11:56
How 'bout those folks from Quincy! archiver 2001 2 24-06-2002 03:33
