Go to Post Recently my wife and I met some mentors from Michigan with their wives at Disney World. It seems that I'm not the only mentor who needs to bribe their wives with vacations before they sign up to mentor FRC for another year... - Mark Holschuh [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 11-04-2005, 11:13
Re: How wide is the river?
Originally Posted by sanddrag
With the equation method of solving, how is it valid to divide the two equations? I know you are trying to eliminate the speed variable but I have never heard of that method (dividing equations) of solving before. Can someone please explain why that works?
Why it works is easy.
Consider that an equation means that the values on each side of the equals sign are, well, equal. It's perfectly valid to do the same arithmetic operation to each side of an equation, e.g. add 5, or multiply by 12, or subtract x, or divide by a.
Start with the equation a / u = (w-a) / v. You can accept multiplying both sides by u, right? You can also divide both sides by something more complicated, such as (w+b) / u. Here's the fun part: if you know that (w+b) / u = (2w-b) / v, you can divide the left side of the original equation by the left side of the new equation, while dividing the other side of the original equation by the other side of the new one. You're still dividing both sides by the same thing.
Unread 11-04-2005, 11:44
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
You have to be careful that you're not dividing by zero, though. (Which would happen in the above example if w = -b or if 2w = b.) Otherwise you might convince yourself that 1 = 2. (See my response too.)
Unread 11-04-2005, 14:50
Good point. However, since the above example had (w+b) / u = (2w-b) / v, dividing by zero would require both w = -b and 2w = b. That's only possible if w and b are both equal to zero.
Since the original problem had nonzero values for both a and b, we know that we're not dividing by zero.
ATTN: River Rage Spots Open Justin Off-Season Events 2 25-08-2004 22:42
River Rage Notes... Justin Off-Season Events 3 13-07-2002 21:59
No Rumor....River Rage Will Happen! archiver 2000 0 23-06-2002 23:22
River Rage Finals Results Justin Off-Season Events 0 12-09-2001 22:49
