Go to Post Remember, if FIRST is your top priority, you need to look at your priorities. - Billfred [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 10-04-2005, 20:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
How wide is the river?
I'm trying to solve this problem. http://home.att.net/~numericana/answ...onal.htm#ferry I understand most of it except for one thing. With the equation method of solving, how is it valid to divide the two equations? I know you are trying to eliminate the speed variable but I have never heard of that method (dividing equations) of solving before. Can someone please explain why that works?
And for the part below in blue text, I don't understand this part
The boat which had travelled 720 yd at the first meeting has therefore travelled three times that (2160 yd) at the second meeting.
Can someone represent this graphically for me?
I have spent over two hours on this and I just can't understand. Please help.
Unread 10-04-2005, 21:09
Eugenia Gabrielov's Avatar
Eugenia Gabrielov Eugenia Gabrielov is offline
Counting Down to Kickoff
Eugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond repute
Re: How wide is the river?
Two ferry boats start at the same instant on opposite sides of the river. One is faster than the other. They cross at a point 720 yards from the left shore on their way to their respective destinations, where each one spends 10 minutes to change passengers before the return trip. They meet again at a point 400 yards from the right shore.
I tried to draw a picture but it wouldn't load...essentially what happens is...and this might be totally wrong since I am not feeilng up to reading that whole solution thing.
Boat #1 is the one on the left side of the river, and boat #2 is on the right side, so at the beginning, boat #1 travels 720 feet until it meets boat #2. Boat #2 goes "E" yards from the right side, before it first meets Boat #1. It then travels 720 feet further across the river. The length of the river is for now, r = 720 + e.
Distance = velocity * time
So, for now, in regards to their first meeting, 720 = v1 * T(a), and e = v2 * T(a). That time is the same becuase they took the same amount of time to go those respective distances. So then, Boat #2 travels 720 more yards at v2 in some more time, and thus 720 + e = v2 * (t(a) + t(b)). Looking at Boat #1, it goes that E distance at v1, at what we'll call time c. OK, so then, 720 + e = v1 * (t(a) + t(c)). Using the transitive property, we find that...
(v2)(TA) + (v2)(Tb) = (V1)(ta) + (V1)(Tc)
or
(V2)(TA + TB) = (V1)(TA + TC)
That's how far I am right now, I am deciding how to add the next factor...I hope it kinda helps...
Northwestern University
McCormick School of Engineering 2010
Computer Science
Team 461 for life!
Unread 10-04-2005, 21:14
Thanks for replying but I couldn't follow you. However, I did find this that explains is pretty well, I think. http://mathcentral.uregina.ca/QQ/dat...9.00/gil1.html
Unread 10-04-2005, 21:19
Edit: SORRY! I tried, it seems it's not followable. Maybe I just think funny.
So then, before I add the 10 minute thingy...Let's look at what happens with Boat #1 again.
To review, it goes 720 yards at velocity 1 or v1. it goes 720 + e yards (the whole river) in v1 (TA + TC).  Then it stops for 10 minutes. Then it makes it another 400 yards before it meets up with Boat #2. So the equation goes as such. But what would happen if we kinda...ruled out those 10 minutes for one second? Let's say TF is the time it takes to make those 400 yards
1120 + E = v1 (TA + TC + TF), and then we'll have to factor in those 10 minutes in a moment.
So what happens to Boat #2?
It makes it E yards. Then it makes it 720 yards. Then it makes it G yards. Forgetting the 10 extra loadage minutes for a second, let's say...
720 + E + G = v2 (TA + TB + TG)
So what exactly is G? G is R - 400, cause it's the distance traveled discluding 400 yards of river..  G is 720 + E - 400 which is equal to 320 + E. Therefore,
720 + E + 320 + E = 1040 + 2E
1040 + 2E = v2 ( TA + TB + TG), later factoring in 10 minutes of passage time, and...
1120 + E = v1 (TA + TC + TF), again, I'm still not sure precisely how to factor those next 10 minutes in.
Computer Science
Team 461 for life!
Unread 11-04-2005, 04:34
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
it is a perfectly acceptable method.
originally we would use it to see if something is true. say you have 2 equations with the same variables in both, dividing through allows you to see if its true,, as you should get 1=1 or something similar
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 11-04-2005, 11:13
Why it works is easy.
Consider that an equation means that the values on each side of the equals sign are, well, equal. It's perfectly valid to do the same arithmetic operation to each side of an equation, e.g. add 5, or multiply by 12, or subtract x, or divide by a.
Start with the equation a / u = (w-a) / v. You can accept multiplying both sides by u, right? You can also divide both sides by something more complicated, such as (w+b) / u. Here's the fun part: if you know that (w+b) / u = (2w-b) / v, you can divide the left side of the original equation by the left side of the new equation, while dividing the other side of the original equation by the other side of the new one. You're still dividing both sides by the same thing.
Unread 11-04-2005, 11:44
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
You have to be careful that you're not dividing by zero, though. (Which would happen in the above example if w = -b or if 2w = b.) Otherwise you might convince yourself that 1 = 2. (See my response too.)
Unread 11-04-2005, 14:50
Good point. However, since the above example had (w+b) / u = (2w-b) / v, dividing by zero would require both w = -b and 2w = b. That's only possible if w and b are both equal to zero.
Since the original problem had nonzero values for both a and b, we know that we're not dividing by zero.
ATTN: River Rage Spots Open Justin Off-Season Events 2 25-08-2004 22:42
River Rage Notes... Justin Off-Season Events 3 13-07-2002 21:59
No Rumor....River Rage Will Happen! archiver 2000 0 23-06-2002 23:22
River Rage Finals Results Justin Off-Season Events 0 12-09-2001 22:49
