Go to Post I like anything that is designed to bounce for up to 10 minutes. Expecially if it lands right side up :) - GregT [more]
Unread 11-04-2005, 12:58
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Re: Strange system problem
Originally Posted by Joe Ross
The IFI representative on the field can give you a lot of information about what happened, for example, low battery, low backup battery, code errors, or loss of radio.
For anyone, if your robot acts strangely, you should ask the IFI representative immediately if they saw anything. It may save you a lot of time later on.
I agree with Joe, the IFI guys are all really great to work with and are always very willing to help troubleshoot your problems. And sometimes its faulty equipment, but more often then not its simple problems like bad cables, disconnected cables, poor connections, bad batteries, bad charge, disconnected battery, inefficent mechanics, shorts, or other problems on our end of the stuff.
I'd say check all the stuff listed above with the batteries, and the shorts, and all that. And if your still having problems, track down one of the IFI guys and see what they cant do to help you.
I know from talking with the IFI reps at Boilermaker and MWR and observing their software in action, they can tell alot about the control system from their handy dandy laptop, everything from disconnected modems to a dead backup is easy to diagnois for them
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 11-04-2005, 19:56
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
I suspect that the voltage isn't getting to the controller. Because we have been better about it with the 04 and 05 bots, I don't know what it would do, but the older bots (that didn't have the backup battery) would look like they were contenously reseting if the battery was low. I also know that sometimes the 120A breaker starts to cause massive resistance if used too much. it will try to disconect, but the bimatalic spring is worn out and causes more resistance. This volatage drop can cuase the controller to reset. The voltage drop could be anywere, but we found that the main breaker can go bad after extended use (don't try to break them in).
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Strange Auto Problem NotQuiteFree Programming 6 20-02-2005 17:12
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
