Go to Post If it weren't for him, I wouldn't be asking why and how, I'd be playing LoL. Now, I do both XD - faust1706 [more]
Unread 10-04-2005, 17:51
Bill Becker Bill Becker is offline
#0596 (SciClones)
Bill Becker is on a distinguished road
Strange system problem
We a very strange problem hit us in the elimination rounds at NYC. Our code and systems were working fine during all the qual matches and then in the elims, our robot appeared to continuously reset whenever the drive motors were run. This happened in autonomous and during operator control. The operator interface would report no data radio when the robot reset. It also did the same thing in the pits on the tether after we were eliminated.
After reading many of the posts in this forum, it seems like there are a few possibible problems, but I wanted to ask here because we won't have a lot of time to troubleshoot at nationals and it won't be much fun if we can't resolve it quickly. Our backup battery was pretty low on charge, but I wouldn't think that just driving the motors with the wheels free spinning on tether would cause voltage to go too low. Our programmer swears that he didn't change anything in the code. Could it be a faulty speed controller??? or could our controller been damaged? Any other possible causes?
Thanks!
Unread 10-04-2005, 18:09
vtrehan's Avatar
vtrehan vtrehan is offline
Mentor - Controls & Programming
AKA: Vivek Trehan
FRC #1241 (Theory6)
vtrehan is on a distinguished road
Send a message via Yahoo to vtrehan
Re: Strange system problem
My first guess is a poor or low on charge battery. Same thing happened to us during a practice match in Waterloo, as soon as the battery was changed, everything was back to normal. Make sure the battery is completely charged, you might be using up a completely charged battery every match.
Another possibility is a screwup in the communications between the OI and the RC, for which you will need to confer with the Innovation First.
And last and the most important thing is to keep trusting your programmer, we are all good people.
Take it easy,
Vivek.
2006-GM Industrial Design Award - Greater Toronto Super Regional
2006-Engineering Inspiration Award - Arizona Regional
2006-Regional Finalist - Arizona Regional
2005-Best Defensive Robot - Wonderland Off-Season
2005-Regional Chairman's Winners - Greater Toronto Regional
2005-Regional Champions - Waterloo (Thanks 68 and 1305)
2005-Best Website - Greater Toronto Regional
2005-Team Spirit Award - Waterloo
2005-Entreprenuership Award - Waterloo
2004-Rookie All-Star award - Great Lakes Regional
2004-Rookie Highest Seed - Greater Toronto Regional
2004-Rookie All-Star award - Greater Toronto Regional
2004-Team Spirit award - Greater Toronto Regional
2004-Team Spirit award - National Championship
Unread 10-04-2005, 18:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We had a main battery that seemed to take a good charge and get up to about 13.2V but it turned out this was only a "surface charge" and after a few seconds of use the battery voltage dropped very low. We never had reset problems because our backup battery was always fully charged but the main battery did cause slow robot movement. Use your Operator interface to see what the voltage of your main battery drops to when you drive.
Electrical Engineer
Rookie Year: 1995
Bill,
Insure that both the 12V SLA and 7.2V Ni-CAD have a full charge. Also check the integrity of electrical connections on all 6 AWG terminations (2 on SLA, 2 on 120A CB and 2 on power dist panel).
A combination of a low Ni-CAD and a high external resistance will cause the problems you have observed.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 10-04-2005, 18:23
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Low backup battery is probably causing the resetting when the main voltage dips low. The main voltage could be sagging for some of the reasons listed above. Another possibility is binding in your drivetrain that you can't see, or possibly an intermittent short somewhere tripping your main or secondary breakers and dragging the voltage low enough in the meantime to reset the robot controller.
Unread 10-04-2005, 18:26
if the main breaker trips you are out, it doesn't reset. There could be a high resistance connection somewhere, but drivetrain binding is more likely.
Unread 10-04-2005, 19:37
Andy A. Andy A. is offline
Getting old
FRC #0095
I would suspect a mechanical bind and/or poor electrical connections. I'm leaning towerds a bad connection.
Do a resistence test on your frame and battery- Shorting to the frame could easily drop your voltage low enough to reset your controller if the nicad is not charged. That short may be in the wiring between the motors and victors, so it wouldn't show up unless the victors were supplying power. Carefully inspect all the drive motor wiring by hand, looking for abrasions and pinched wires, crimps that may be working loose or any exposed conductors.
I also suggest that you remove breakers to all your drive motors, and plug them back in one at a time till you have tested each motor through the speed range individually. While you do this, use a multimeter with a clamp type ammeter to monitor the current draw of each motor. On blocks, each motor should draw something like 5 amps (thats been a typical number for my team, others may consider that high or low). If a motor is higher then others, or one side of your drive is drawing more then the other, you've narrowed your problem down to a binding or a loose connection. Also check the current draw from the battery while the robot is at rest and when the drive starts to move. Look for a high draw at rest, which would indicate a problem in breakers or associtated wiring (as opposed to the wiring from the victors to the motors).
The electrical problem is easy enough to deal with, since it'll probably just need a little electrical tape or a tighted screw. If it's mechanically related, you'll need to figure out just where all the excess friction is coming from.
Are you using the kit gearboxs?
What motors are driving?
Are all your motors moving in the right direction?
Do you have a compressor on board?
-Andy A.
Unread 10-04-2005, 19:50
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Along the electrical issues line of trouble shooting...
Check the screws in the lugs for the battery cable. Ours came loose at least twice during the season. We had to check them every few matches.
Although I don't think this sounds like your issue, it's still a good thing to check and eliminate during the trouble shooting.
Good luck finding the "ghost in the machine".
Brian Graham
Unread 10-04-2005, 20:03
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
I would say a problem with a battery - either main or backup. Try and make sure you have one of each charged and ready to test the problem if it ever happens again. You may also want to try buying new batteries as recharging them too much can drop their output voltage.
Unread 10-04-2005, 20:55
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
Just an idea, but in 2003 at Houston, we had a dificult Saturday morning. Everything ran fine on our robot Friday evening, and the next morning the robot only ran autonomous. When the 15 seconds were over, the robot would not respond to any operator controls. The best we were able to figure is somehow the code got corrupted (static?). Anyway, we went through two matches before we found the problem. Yes, look at all the battery problems mentioned, but also re-download your code to make sure it didn't get corrupted somehow.
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
Unread 10-04-2005, 21:05
The IFI representative on the field can give you a lot of information about what happened, for example, low battery, low backup battery, code errors, or loss of radio.
For anyone, if your robot acts strangely, you should ask the IFI representative immediately if they saw anything. It may save you a lot of time later on.
Unread 11-04-2005, 08:49
#0596 (SciClones)
Thanks! this is great info/advice. I feel much better about our prospects of resolving it quickly now. We will need to borrow a clamp ammeter from someone though.
In Reply to Andy's questions:
Are you using the kit gearboxs? We are using a two speed pneumatically shifted gearbox. It is possible that the pressure to the pistons got increased somehow and is causing binding.
What motors are driving?Each gearbox is powered by 1 CIM
Are all your motors moving in the right direction? Yes, they worked fine in all of our qual matches.
Do you have a compressor on board? Yes
-Andy A.
Unread 11-04-2005, 09:49
Bill Moore's Avatar
Iv2gr8sons
AKA: Be More
Look!! Up in the sky!! It's a bird! It's a plane! NO, IT'S A BIG GREEN TOWER!! !!! !!!! !!
Bill, and all teams, if you need any help or resources in the pits, check with our pit crew. We'll do our best to help get your robot back to tiptop running condition. I'll check with The Lucas tonight to see if we've packed the type ammeter you need to borrow.
Good Luck at Championships!!! (Where are those Divisions? It's already 9:45 AM!! Impatient? Who, ME?)
Unread 11-04-2005, 12:58
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
I agree with Joe, the IFI guys are all really great to work with and are always very willing to help troubleshoot your problems. And sometimes its faulty equipment, but more often then not its simple problems like bad cables, disconnected cables, poor connections, bad batteries, bad charge, disconnected battery, inefficent mechanics, shorts, or other problems on our end of the stuff.
I'd say check all the stuff listed above with the batteries, and the shorts, and all that. And if your still having problems, track down one of the IFI guys and see what they cant do to help you.
I know from talking with the IFI reps at Boilermaker and MWR and observing their software in action, they can tell alot about the control system from their handy dandy laptop, everything from disconnected modems to a dead backup is easy to diagnois for them
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 11-04-2005, 19:56
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
I suspect that the voltage isn't getting to the controller. Because we have been better about it with the 04 and 05 bots, I don't know what it would do, but the older bots (that didn't have the backup battery) would look like they were contenously reseting if the battery was low. I also know that sometimes the 120A breaker starts to cause massive resistance if used too much. it will try to disconect, but the bimatalic spring is worn out and causes more resistance. This volatage drop can cuase the controller to reset. The voltage drop could be anywere, but we found that the main breaker can go bad after extended use (don't try to break them in).
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Strange Auto Problem NotQuiteFree Programming 6 20-02-2005 17:12
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
