| Thread Tools |
Rating:
Display Modes |
CAD files for elevator design
This is my first year in robotics and working with Inventor. I would like to see some elevator design to prepare for next year's robot. Does anyone have any cad files they can send, or descriptions of elevator systems that worked really well?
Re: CAD files for elevator design
The tower we used for our robot works pretty well (my very humble opinion, of course!).
(This assumes you have Autodesk Inventor 8 or later): The CAD files are pretty large, and the assemblies consist of quite a few files, so your best bet is to download them from Autodesk's Streamline Site [username "(public)" , include parentheses, but not quotes, leave password blank]. If you go to the Student Upload area, you can download the Inventor files from our team's entry (0103). |
Are you looking for how people did it in Inventor or how teams did it on their robot? You could peruse the picture arcives and teh robot showcase section for pics.
As far as how they did it in Inventor, it dependes on the setup. It looks like petek used prefab Alumium angle with holes in it on the robot, so made an extrustion to the right length and patterened a hole on the sides to make it heve the holes. (this is how I would do it, atleast). Our bot's arm was made out of sheet metal (Here) and I used the sheetmetal tools that Inventor provides. Each section came in 2 parts (so they could be bent and assembled correctly). If it is a prefab part (like those crazy extruded alumium pieces that are so nifty and my team won't use) you might be able to find it at First CAD Library . It hasn't been updated for a while, so check CD to see if the new site I got people started with will pan out. |
We used an elevator system on our robot this year and should have some CAD models at school somewhere. I will get with the CAD leader and see what he can do for you.
We (team 343, Metal in Motion) have designed one that is working quite well. You can see it in our Autodesk Inventor entry on our site, www.metalinmotion.com. Our CAD files are also on the Streamline site at Autodesk.
#7
We used a similar design as Petek described. 1x2 80-20 with some linear brackets and a chain drive. As for the chain drive on our bot, we needed the space between the uprights to be clear so we moved the chain to the outsides. A van door motor drives a chain that is fixed at one point to the lower extension. (see our gallery) A shaft spans the towers to allow an even force to be exerted on each side. A window motor is mounted in a similar fashion to the smaller, 1x1 80-20 upper extension, except it drives a sprocket that travels up and down a fixed chain, rather than the chain moving around a stationary sprocket. The result is an extremely stable, relatively quick forklift mechanism that can go from as low as 16" to as high as 11-12'. It's not as cool as 173's awsomazing teloscoping arm, but we still won the GM Industrial design award in large part due to this mechanism.
#8
| Camera CAD files | hopkins | Inventor | 1 | 12-03-2005 10:38 |
| Converting Cad Files | ufa_mike | Robot Showcase | 4 | 29-10-2004 17:51 |
| CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) | Elgin Clock | Inventor | 0 | 30-08-2004 23:06 |
| Bosch Drill Motor CAD Files | Madison | Inventor | 10 | 09-12-2001 00:14 |
