Go to Post ... my most important lessons in life all came from one place, Sesame Street. - Karthik [more]
Unread 11-04-2005, 20:20
Dave.Norton Dave.Norton is offline
FRC #1157
Dave.Norton is an unknown quantity at this point
Re: Transmissions
Originally Posted by Max Lobovsky
We have a omniwheel holonomic drive with no feedback. It is likely one of the most difficult to control FIRST drivetrains that exists)
We used the same wheels, and after looking at your site it looks like we had an identical layout. One difference though, ours was very easy to control. When we prototyped it the drive wouldn't go in a straight line to save itself, problem with 3 points defining a plane, and four being over constrained. Which is to say every time it hit a bump it would steer into a new direction. By adding a rotational accelerometer and suspension to the platform we got it under control (little joke there) and now it is fun to drive.
Unread 18-04-2005, 00:23
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: Transmissions
Team 1072 (Harker Robotics Team) used a TechnoKat style dog shifter this year. Two speeds, two CIMS, geared to go 6 feet and 11 feet per second. Man.. what a beauty. Of course we totally ignored the white papers and designed everything ourselves... just to improve even more on an already very good design. We first of all did not use a flex coupler, instead we put a chain sprocket directly onto the output shaft of the transmission. We also made the whole thing with .25" and .125" plates screwed together, you could literally take the shifter OUT by unscrewing 5 bolts. And the thing was sturdy... even thought the transmissions were tiny they could pack a punch. For the record, or robot in low can push TWO other robots with the kit transmission. And we did this during competition. That is how we know..
As for shifting, it was very smooth and quiet, no jolt or sudden lurch of the robot. I was thinking about putting sycros on if shifting was too rough, but we tested it and they shifted fine. I highly reccomend any teams with access to a mill and lathe with the proper tooling and the urge to make a 2 speed transmission to consider a dog-style shifter like this.
Looking for pictures of shifting transmissions that slide gears sanddrag Technical Discussion 3 23-12-2004 07:41
Dewalt Transmissions Joe P Technical Discussion 9 09-09-2004 21:07
Off the shelf transmissions CharlieWilken Technical Discussion 0 15-01-2004 01:58
A little tip about those drill transmissions and bearings archiver 2001 6 24-06-2002 00:22
drill motor transmissions nwagers Motors 16 29-01-2002 10:54
