Go to Post When was the last time you heard of someone on their death bed talking about a great movie they saw? I think it far more likely to hear of their accomplishments, something they did to make things better. Well that's what FIRST is all about. - DougHogg [more]
Unread 12-04-2005, 22:13
R81Honda's Avatar
R81Honda R81Honda is offline
Team 1466 Driver
#1466
Team Role: Driver
R81Honda is on a distinguished road
Re: gocart building
Well I would say probably the most im[portant thing to have to build a go-cart from scratch is to havethe tools nedded to fabricate the chassis. Stuff such as welding, pipe bending, and other odd tools will be needed in the chassis. What would be the best matiral to work with is a metal tubing, you defiantly want to get a good blue print of the dimension of the chassis and the specifications that you want. Also you need to fab up stuff like motor mounts and steering.
Basicly building a go-cart from scratch would be fairly straight forward if you have access to a machine shop.
BTW you can never go wrong with a honda motor! There new line of lawn mower engines is quite nice, cool features such as Overhead cams, and pleanty of HP and torque to get the job done!
Unread 13-04-2005, 16:32
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Thumbs up Re: gocart building
Having experience with racing go-carts I would say that a Honda GX160 would be more than enough to power you and your friends (maybe a GX200 if they are bigger carts or such) to at least 30-40 MPH with no problems. They can be bought NEW for around $350-400 from Northern Tool and Supply but these are very common engines and could be found at garage sales (at least mine) for less. Try a Quarter Midget swap meet (should be popping up soon this time of year) these are the standard engines.
Good Luck!
If Lansing is not too far of a drive for you there is a Quarter Midget track behind some restraunt (sorry forgot name) that would be able to help you find a used engine.
MechWarriors 573
Unread 13-04-2005, 18:28
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: gocart building
I built a minibike. I tried making my on frame but it it hard to bend the tubing in the proper places and at the proper angles so the two framesides were a little off and I never was able to get the chain aligned. So, I bought a frame for $100. I used an old 2hp Briggs & Stratton horizontal shaft engine off an old rotary lawnmower. Edgers also commonly have this type of engine. It is a little slow to accelerate (with a big guy like me on it), but it'll get up to about 30mph.
Ebay is a good source for parts. A couple more places:
http://www.gokartsupply.com
http://www.gokartgalaxy.com
Unread 14-04-2005, 02:23
Babyhueyhnx's Avatar
Babyhueyhnx Babyhueyhnx is offline
Jack of all trades
AKA: Phil
FRC #0486 (The Positronic Panthers)
Babyhueyhnx is a jewel in the roughBabyhueyhnx is a jewel in the roughBabyhueyhnx is a jewel in the rough
Send a message via AIM to Babyhueyhnx
Re: gocart building
the first place to start is a chassis. i helped my friend build his cart and man that thing does wheelies with a 9 hp engine with me on it an i weigh 185 lbs. He bought his chassis but if you are looking for a custom fit i suggest you build one.
As for the engine his is a 9hp snow blower engine and it not a honda and he frequently has problems with it. SO GET A HONDA!!!
Heres a little story:
One time i took his cart out for a ride and i was doing wheelies. i was making a corner and jammed the gas by accident and did a wheelie into a truck. i fell off and it did a few 360's on the motor standing up. it was awsome. in the end we ended up making a wheely bar car it would pretty much flip if we didn't.
FIRST Topsite
Got Robot? - Team486.com
There is much pleasure to be gained from useless knowledge.
He who asks is a fool for five minutes, but he who does not ask remains a fool forever.
Not everything that can be counted counts, and not everything that counts can be counted.
Every day is a present. After all is a called "the present," and live every day like its your last.
Get Firefox!
Reclaim Your Inbox!
Unread 14-04-2005, 23:10
occra 23.
AKA: ryo
None #1481
Re: gocart building
thanks for the help guys, i have access to tools and welding stuff. but no pipe bender so we were planning to go with square steel. easier to weld and leave tweak out to start out i think. now the hard part. getting my friend's dad to agree its a fun and educational project well worth the money and risk of safety.
Unread 14-04-2005, 23:21
Re: gocart building
I think square tubing is an exellent choice. It should be very easy to work with. Do you have an abrasive blade chop saw? With steel tubing, you will probably be able to go with thin wall to save weight.
Building a gokart is extremely educational. There is little safety risk as long as you know how to operate the tools you are using and wear a helmet when you are riding. Also, don't ride on busy streets (you're probably not supposed to ride on any streets).
Everyone says get a honda engine but I wouldn't rule out a Briggs & Stratton engine like this one http://cgi.ebay.com/ws/eBayISAPI.dll...3585 503&rd=1 They are extremely reliable. Buying on eBay would cost a lot to ship unless it is local but I would try to get a used lawn or construction equipment machine of some sort (I think maybe water pumps use them too) to pull the engine from.
Unread 15-04-2005, 01:43
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: gocart building
Briggs and Stratton and Tecumseh both make strong engines. For a small engine for a go-kart I would go with one of them over a Honda any day. Honda makes reliable stuff, but I believe that the small engines made by these other companies are just as reliable if not more so. We had a Tecumseh 6 HP engine on our chopper for a long time and it had no problems. It spent a year on a go-kart getting the crap beat out of it before we put it on the chopper too, so it can withstand a beating. We recently sold the 6 HP engine to a friend of mine who is also building a go-kart. He has also started from scratch. Though I do think that you will be very limited with a $500 budget and that to make a decent kart would require about $700 and up (depending on how good you want it).
See you in DC!
Unread 16-04-2005, 12:06
occra 23.
AKA: ryo
None #1481
Re: gocart building
hmm. i searched for pocket rockets on ebay and with shipping seems i can get one for a bit over $200. 49cc, dual diskbrakes, chain driven and claims to go over 40 so i was thinking i can take that apart and then build a frame ($50ish), buy spindles, etc and wheels/tires for under $150. is there sumthing im forgetting? clutch(some pocket rockets have a "CVT" which im assuming is the belt type torque converter)... oh axles. bearings, well that cant cost too much, do you think $500s a little tight?
Unread 16-04-2005, 13:14
Re: gocart building
Pocket rocket engines are derived from Weedeaters and Chainsaws where gokart engines are derived from lawnmowers and waterpumps. 49cc is a pretty good displacement size for that little engine but one thing for sure is that you are not going to mow your lawn with a weedwhacker and you are not going to whack your weeds with a lawnmower. A pocket rocket engine is never going to put out 5 horsepower without serious expensive modifications where a gokart engine easily will. Gokart engines rev lower but have more torque where pocket rocket engines rev higher and have less torque. For a gokart, you want a big engine. Lawnmower (horizontal) style, not weedwhacker style.
Unread 16-04-2005, 14:39
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
Re: gocart building
X2 For what Sanddrag said. Get a larger engine - for 2 reasons.
1. The torque. Remember - Torque is what gets you up to that speed - Horsepower keeps you moving. I'd always go for more torque.
2. I'd personally don't feel very comfortable with an engine at 7,000+ RPMs doing only 30 mph down the road. Again - get the larger engine and you can gear it much better!
I don't know that much about the technicals on smaller engines - but it's still off the principle of a 2/4 stroke Internal Combustion engine...
And anyways - remember the saying - "There's no replacement for displacement"
That rug really tied the room together...
Unread 16-04-2005, 17:54
occra 23.
AKA: ryo
None #1481
Re: gocart building
thnx guys, but most lawnmower/waterpump engines rev only up to about 3500. which isnt too pleasing for me. as matt said, id much rather hear it running high rpms. i dont need to burn out or anything. i wouldnt care so much even if i had to push off running next to the cart if i have more top end torque. and high rpms. if i wanna start drifting with it, id like the high rpms. (and a manual clutch would help... is there a way to get a manual clutch rather than a torque converter or a centrifugal for a gocart?)
power to weight ratio with a 2 stroke or a big displacement with a big 4st. dont dirtbikes use anything as small as a 50cc? i dont know too much but say for example, a 5hp b&s lawnmower engine. whats the displacement on those?
oh and a little offtopic but whats the legality or w/e on gocarts? (michigan) anyone know off the top of their heads? save me some time looking it up
Unread 17-04-2005, 02:47
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
Re: gocart building
Originally Posted by greencactus3
thnx guys, but most lawnmower/waterpump engines rev only up to about 3500. which isnt too pleasing for me. as matt said, id much rather hear it running high rpms....power to weight ratio with a 2 stroke or a big displacement with a big 4st. dont dirtbikes use anything as small as a 50cc? i dont know too much but say for example, a 5hp b&s lawnmower engine. whats the displacement on those?
I know that B&S and Tecumseh engines rev to 3000-3500 rpm stock, but can push out close to 7000 rpm with some modifications. And the 6 HP Tecumseh engine we used on the chopper was like 150 cc...not as small as you would think. I have no idea about the legality in Michigan.
See you in DC!
How much of the field are you building? Joe Johnson FIRST Tech Challenge 7 11-04-2005 17:32
Is FIRST a robot building CONTEST? KenWittlief General Forum 25 15-03-2005 20:05
Sub Forum suggestion. (Non Robot) Team building projects. Elgin Clock CD Forum Support 3 03-12-2004 14:30
Q&A Discuss: Arena Building: Cheap Materials CD47-Bot Extra Discussion 1 22-01-2003 17:16
Qotw [11-24-02]: What your team do beside building robot... Ken Leung Rumor Mill 9 05-12-2002 07:42
