Go to Post And people laugh at me when I suggest 14" wheels. - Munchskull [more]
Unread 13-04-2005, 01:02
SusanM SusanM is offline
FTC #0050
SusanM will become famous soon enough
Twitching Robot
Has anyone noticed uncommanded motor movement?
Our bot often has random motor movement. We have tried a new location to check for household interference. We have tried multiple transmitters. We are in the process of swapping micro controllers.
Anyone else with this issue or a solution to it?
Thanks,
Susan
FRV-50
Washington
Unread 13-04-2005, 01:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Twitching Robot
Is it with motors (continuous rotation) or servos (hold position)?
Unread 13-04-2005, 01:07
FTC #0050
Re: Twitching Robot
It is with motors.
We are also going to try a tether to check for interference with the radio frequency. We are currently testing in a fairly high density residential neighborhood.
Thanks,
Susan
FRV-50
Washington
Unread 13-04-2005, 11:35
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Twitching Robot
We've had issues with twitching when the batteries go low. Perhaps that is the issue.
Joe J.
Team #88, TJ2
Unread 13-04-2005, 16:52
E.L.V.I.S.'s Avatar
E.L.V.I.S. E.L.V.I.S. is offline
The king is back!
FTC #0033 (E.L.V.I.S)
E.L.V.I.S. will become famous soon enough
Re: Twitching Robot
we've had that problem only once, and that was because another team had their controller turned on at the same time as ours, other wise, twitching motors has not been a problem.
E.L.V.I.S: Eliminating Lesser Vexers In Style
WPI VEX Scrimmage 2005 Champions.
Unread 13-04-2005, 20:50
jamesgecko's Avatar
jamesgecko jamesgecko is offline
Linux Guy.
AKA: James D
FTC #0040 (Grep Lurch Grab)
jamesgecko is an unknown quantity at this point
Send a message via AIM to jamesgecko Send a message via Yahoo to jamesgecko
Re: Twitching Robot
We had this problem when we installed 4WD on our robot. It turned out that the batterys were drained and after a recharge, everything worked fine again.
Unread 24-04-2005, 13:27
Rabid_Llama Rabid_Llama is offline
Rabid_Llama is on a distinguished road
Re: Twitching Robot
only time i have seen this problem is when i dont have the controller on at all. btw, on the subject of radios, anyone else notice that it kills television signals that are in the area you are operating in?
Unread 19-02-2011, 11:01
Peragore's Avatar
Peragore Peragore is offline
CEO of Black Magic
AKA: Philip Mulford
FRC #3373 (Team Robohawk)
Peragore is an unknown quantity at this point
Re: Twitching Robot
We are having the same problem. Our robot motors twitch whenever the motor is enabled, including when our robot is running under commands (joysticks giving robot commands,) and when at rest. We programmed a dead zone on the joysticks when at rest, so there are literally no inputs. We are using a fully charged battery and there are no networks with the same IP nearby. Any ideas?
Edit: Never Mind, Doing FRC, not FTC
while (life){
  frcObsession = true;
  obs.ProgramAndObsess();
if (!life) life = true;
Unread 20-02-2011, 13:35
electron's Avatar
electron electron is offline
Former Team Overdrive member
AKA: Joseph
FTC #2753 (Team Overdrive)
electron is just really niceelectron is just really niceelectron is just really niceelectron is just really nice
Re: Twitching Robot
could you post your code that controls the motor?
if you are setting the motor to 0 in more than one location in the code, the motor will twitch.
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
I may be one of the few people that has moved from FRC to FTC, and enjoyed it
Unread 21-02-2011, 10:57
l0jec l0jec is offline
l0jec has a spectacular aura aboutl0jec has a spectacular aura about
Re: Twitching Robot
We ran into a twitching issue related to using a USB hub on one of our laptops. For whatever reason, when using a USB hub to plug in an extra joystick, the thing would quickly cycle dropping connectivity with both joysticks. We only saw the issue on the one laptop and only if using a USB hub.
Note that our experience should not rule out a coding issue, but wanted to share it as you as your issue may be similar and if so, a real pain to troubleshoot.
VCU NASA Regional Collmandoman Regional Competitions 83 10-03-2005 13:20
2005 FRC Team Update 14 Jeffrafa General Forum 43 01-03-2005 15:52
Manual placement of tetras Petey Rules/Strategy 7 22-02-2005 18:04
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
