Go to Post They may call us geeks and nerds, but deep down under that prejudice they know they want to be the hard-core, sleep-deprived, hand drill-toting, robot builders we know we are! - vijay24 [more]
Unread 12-04-2005, 23:08
dachickindapit dachickindapit is offline
AKA: Gina Sweet
FRC #0033 (The Killer Bees)
dachickindapit is a name known to alldachickindapit is a name known to alldachickindapit is a name known to alldachickindapit is a name known to alldachickindapit is a name known to alldachickindapit is a name known to all
Send a message via AIM to dachickindapit Send a message via Yahoo to dachickindapit
Update 19 has been released
Team Update 19 has been posted by FIRST. It addresses "flop-down" robots and how they can touch the loading zone, and that additional people can be on the floor for robot support during the eliminations.
http://www2.usfirst.org/2005comp/Upd..._Update_19.pdf
2017-??: Team 33 -- The Killer Bees
2001-2016: Team 67 -- The Heroes of Tomorrow
1997: FLL Pilot Program
**Controls and Electrical Systems for who knows how many years now**
Unread 12-04-2005, 23:16
Re: Update 19 has been released
Thanks for posting this. There aren't very many flopping robots this year, but there has been some discussion of their use and loading zone placement. This should end most of that discussion.
Unread 12-04-2005, 23:21
AKA: Dr. Brooks
no team (WRRF)
It is good to see the "three additional team member" access rule for the elimination rounds. This is great if repairs need to be made. It would be nice if this were the uniform operable rule for all regionals.
Unread 13-04-2005, 10:44
Mark Garver's Avatar
Mark Garver Mark Garver is offline
AKA: Garver
Mark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to behold
Send a message via AIM to Mark Garver
Q: We designed and built a robot that would tip from 38x28 to 38x60. The “new” base and drive train is “blatantly obvious that our robot is in the LZ” and ”has a load bearing surface in contact with the HDPE”. Is our robot in the LZ?
Revised answer 4/11/2005: If we understand your question correctly, yes. Robots that "flop" must declare a 28" x 38" section of their robot to be the "robot base." The declared section must be a portion of a 60" long surface of the robot that was nominally vertical prior to the start of the match. This is the section that the referees will always use to determine if your robot is in the loading zone.
Original answer: If we understand your question correctly, yes. Robots that "flop" basically must declare a 28" x 38" of their robot to be the "robot base." This is the section that the referees will always use to determine if your robot is in the loading zone.
Well I am surprised that there hasn't been more discuss on this topic; this is a pretty big change in rulings over all of the regional competitions this season. Teams that had relied on whiskers now could possible need to rebuild their entire arm in order to reach the loading stations. This to me just doesn't sound at all right. Teams built robotics based on the rules they were given and now they may need to rebuild entire assemblies in the pits in order to compete at the Championship event. I believe that FIRST should have taken care of this way back in the beginning of the competition season as soon as it was observed, so that teams could possible take care of this problem during the "Fix-It" window. Just my two cents.
Unread 13-04-2005, 12:54
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
Let me see if I understand this right. I think rule is addressing our "wiskers" that in our starting position are considered part of the base, but stick out in front of the robot after we "flop". Now they're saying we have to define our base in a vertical plane, so our wiskers sticking out the front don't count. This really isn't a problem for us since at our first regional we changed the positioning of the arm so part of our base is above the loading zone when we get tetras from the auto loader, we just never changed the whiskers. If it aint broke don't fix it right?
Have I missed something about a "load bearing surface" having to contact the zone? Normal whiskers that go straight down from your base are still fine right?
How does this new version of the rule apply to teams with "wheelie bars" (portions of the robot that fold out to help stabilize themselves)? Apparently those "wheelie bars" shouldn't count as touching the loading zones? Is this how it's being enforced? If my memory is correct team 65 uses these very effectively.
I think this whole "touching the loading zone" thing is ridiculous to begin with. It seems this whole rediculous rule was designed around preventing people from using a weight on a string to gain a permanant "don't touch me" rule. They're currently not enforcing the rule unless you are trying to retrieve a tetra anyway. Why couldn't they just extend this loading zone up 3" above the ground and say you have to have a structural (rigidly attached) part of your robot in that zone?
Unread 13-04-2005, 14:32
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by Jim Meyer
...<snip>...
We will have plenty of time to think about future rules for future years. But... ...I can't resist one more suggested way to implement what they wanted without some of the wiskier side affects.
If I were king (and I clearly am not) I would have had an IR transmitter (aka a beam of light) at the tip of the loading zone triangle and a receiver just above the fence line on the side of the field. When you break the beam a light goes on in the associated zone and you are IN. From that time, you get 6 seconds on the autozone, 10 seconds at the human zone load. After that, the light goes off and you're OUT. When the light is on you're safe. When it off, you're fair game. I think we'd still have to have something to make sure it is the robot base that is blocking the light and no an arm, but I think a manual override button and a ref watching could handle those cases. The visual light could make it simpler to judge and simpler for teams to know when a team is not to be touched.
Just another idea for next season...
Joe J.
Team #88, TJ2
Unread 13-04-2005, 14:57
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Better yet, why not a pressure pad that is calibrated for a specific weight (to distinguish between a robot and a scoring object)?
Unread 13-04-2005, 15:05
PURPLE! PURPLE! is offline
Safety Bit... I mean Captain....
AKA: Megan
FRC #0624 (CRyptonite)
Team Role: Marketing
PURPLE! is on a distinguished road
Send a message via AIM to PURPLE! Send a message via Yahoo to PURPLE!
So has there been any news on the caution tape on the field being legal or not?...
It's a coke with lime thing...
Unread 13-04-2005, 15:07
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Well I have added update #19 to FIRSTsearch...
...I really need to add a cronjob for Updates too...
- from B B frank
Unread 13-04-2005, 15:14
AKA: Dr. Joe
FRC #0088 (TJ2)
That could work too. I have not had good experience with pressure pad switches period, yet alone calibrated ones, but if they exist and we can get them working, I'm all for it.
Joe J.
Team #88, TJ2
Unread 13-04-2005, 17:40
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
That'd be tough though, what do you calibrate it to? Different amounts of force are pushing down in different areas (or not at all in the case of "whiskers"). If I have one wheel w/ 130 lbs over it, it "weights" differently on the pad then 130 lbs spread over four wheels, no? The pad would have to be big enough to capture the entire base, etc. I think an IR beam would be better.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 13-04-2005, 18:08
I thought about that after I originally posted. Calibrating it to any weight greater than a couple of scoring objects (but less than the weight of a robot) *should* work.
I think I agree with the statement about the weight distribution and that you would have to make the pad large enough...but you still might be able to make it work. As long as the size/weigh requirement was known up front, doesn't that just become a design criteria?
Team Update #18 (Let's Try This Again) Travis Hoffman General Forum 11 30-03-2005 22:18
Latest Update Released!! New Rule <PCL 1.1> Rich Kressly General Forum 3 30-03-2005 18:22
Team Update 17 Released. Joe Ross General Forum 2 25-03-2005 19:03
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
phpBB 2.0.13 released - Critical Update JohnBoucher IT / Communications 0 27-02-2005 20:26
