Go to Post In order to change the world and make it a better place we must start with ourselves. - wendymom [more]
Unread 13-04-2005, 12:37
halomaster69 halomaster69 is offline
halomaster69 is an unknown quantity at this point
Question portable controls w/o using tether
yo, Team 1505 here, one question, is it possible to walk with your robot and drive it at the same time with out using teather cables. the only issue is getting power to the user interface and the radio
if anyone has a solution to this problame let me know
Unread 13-04-2005, 12:40
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: protable controls w/o using teather
You can safely power the OI from a robot battery or something smaller, as long as its in the 9-12 V range. We have done this many times. Just destroy an OI AC adapter and hook up the wires to your battery, paying careful attention not to reverse the polarity.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 13-04-2005, 12:42
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Yes there is a way, Very Simple as well
http://www.chiefdelphi.com/forums/sh...light=Portable
It's one of the many things that us FIRSTers have put together to make life easier. =)
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 13-04-2005, 16:49
Electrical Engineer
Rookie Year: 1995
Powering the OI is only one half of the problem as originally posed... You still need the tether for communications. Use of radios in the pits is forbidden...
Mike Betts
As easy as 355/113...
Unread 13-04-2005, 20:14
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
As stated above you can infact run your OI off of batteries, its quiet simple, you dont have to butcher a power supply if you dont want, you should be able to buy the connector as its a standard size, although that size espaces me right now, and just connect a batter to it.
As stated that is only half your battle as FIRST forbids the use of radio communication during competition. If your talking about just doing this for a demonstration or a parade, then your fine, but this wouldn't be possible at competition due to the radio restrictions.
Hope this helps.
Josh
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 13-04-2005, 20:20
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
Yes, you can buy the right sized barrel connectors at Radio Shack or your favorite electronics store, or if you have some old adapters laying around (that have the right size end) just chop off the adapter and you have a nice long wire attached to the barrel.
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 13-04-2005, 20:25
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Thanks for posting that thread.
Here is the link mentioned in that thread to my white paper on how to make a Portable Power Pack for the OI:
http://www.chiefdelphi.com/forums/pa...le&paperid=362
If you have any questions just let me know
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 13-04-2005, 23:11
mtaman02's Avatar
Your welcome and my fault for not mentioning that if your gonna do this at competition that you MUST use a tether so that the robot doesn't interfere with other robots in the pits or on the field - sorta like a direct link to the robot with out the use of channels =)
Volunteer Resume:
Unread 14-04-2005, 14:44
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
Can you use one of the blue rechargeable RC backup batteries? Do they have enough voltage to run the OI? They're about 7 volts or so.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 14-04-2005, 15:14
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
I asked IFI that a couple of years ago about using a 7.2 NiCd rechargeable and they said it's a bit under powered and to go get a 9.6 rechargeable from RadioShack, the kind for RC hobbies. Then just splice a barrel connector in parallel to the connector on the rechargeable battery and *poof* your ready to go and you can still easily recharge it.
Unread 14-04-2005, 17:55
yea, we just need it for a convention at the salt palace in salt lake city in a few days
Unread 24-04-2005, 00:43
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Yea, this year i powered my team's controller with the little blue batteries. Surprisingly enough the OI will operate. Our batteries were always overcharged by the charger. But as the batteries die you will notice strange OI behavior, luckily when the batteries start to die the radio is the first thing to stop working.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 25-04-2005, 08:58
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Re: portable controls w/o using tether
My team and I built a portable OI powersuppy using a recharble 9.6V nicad battery from radioshack. we built an adaptor cable to take the battery end and convert it to what the OI uses so if we find we need more batteries for longer demenstations we don't have to modify them we can just go to radio shack and buy them.
Unread 11-05-2005, 00:26
eeeeweeezeee's Avatar
eeeeweeezeee eeeeweeezeee is offline
menace to public safety
FRC #0114
eeeeweeezeee will become famous soon enough
Send a message via AIM to eeeeweeezeee
Lightbulb Re: portable controls w/o using tether
I built an OI power system into our custom operator interface with 3 9v batteries and a jack for wall power. there is even a swich to change modes. our captain, who asisted, will probably post a picture of it later. my project for next year's oi is to make a rechargeable system that autuomaticly transfers. to do this, i need to find a 9.6 volt charger that can support the drain of chargeing a battery and powering an oi at the same time. does anyone know if this has been atempted before?
EEEEWEEEZEEE
was here
Unread 11-05-2005, 01:32
Pierson's Avatar
Am I reading this right? This will essentially be a mini-UPS. That is a really neat idea!
Pierson
Three Worded Story
Word Association
Tether heating up! Shu Song Electrical 10 03-02-2005 01:14
Rumor or Real: RF Tether product joe_balint Control System 20 26-01-2005 00:27
[FVG]: Controls Round C1 Mike Ciance FIRST-related Organizations 18 29-07-2004 20:44
Jump Start RC w/o Exide 12v battery Mark McLeod Control System 3 12-01-2004 12:42
Entanglement at Bash Rick Rules/Strategy 31 06-11-2002 21:30
