Go to Post FIRST is not about robots or which roller coaster we get to ride... it is about people. - Andy Baker [more]
Unread 14-04-2005, 02:23
Babyhueyhnx's Avatar
Babyhueyhnx Babyhueyhnx is offline
Jack of all trades
AKA: Phil
FRC #0486 (The Positronic Panthers)
Babyhueyhnx is a jewel in the roughBabyhueyhnx is a jewel in the roughBabyhueyhnx is a jewel in the rough
Send a message via AIM to Babyhueyhnx
Re: gocart building
the first place to start is a chassis. i helped my friend build his cart and man that thing does wheelies with a 9 hp engine with me on it an i weigh 185 lbs. He bought his chassis but if you are looking for a custom fit i suggest you build one.
As for the engine his is a 9hp snow blower engine and it not a honda and he frequently has problems with it. SO GET A HONDA!!!
Heres a little story:
One time i took his cart out for a ride and i was doing wheelies. i was making a corner and jammed the gas by accident and did a wheelie into a truck. i fell off and it did a few 360's on the motor standing up. it was awsome. in the end we ended up making a wheely bar car it would pretty much flip if we didn't.
FIRST Topsite
Got Robot? - Team486.com
There is much pleasure to be gained from useless knowledge.
He who asks is a fool for five minutes, but he who does not ask remains a fool forever.
Not everything that can be counted counts, and not everything that counts can be counted.
Every day is a present. After all is a called "the present," and live every day like its your last.
Get Firefox!
Reclaim Your Inbox!
Unread 14-04-2005, 23:10
occra 23.
AKA: ryo
None #1481
Re: gocart building
thanks for the help guys, i have access to tools and welding stuff. but no pipe bender so we were planning to go with square steel. easier to weld and leave tweak out to start out i think. now the hard part. getting my friend's dad to agree its a fun and educational project well worth the money and risk of safety.
Unread 14-04-2005, 23:21
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: gocart building
I think square tubing is an exellent choice. It should be very easy to work with. Do you have an abrasive blade chop saw? With steel tubing, you will probably be able to go with thin wall to save weight.
Building a gokart is extremely educational. There is little safety risk as long as you know how to operate the tools you are using and wear a helmet when you are riding. Also, don't ride on busy streets (you're probably not supposed to ride on any streets).
Everyone says get a honda engine but I wouldn't rule out a Briggs & Stratton engine like this one http://cgi.ebay.com/ws/eBayISAPI.dll...3585 503&rd=1 They are extremely reliable. Buying on eBay would cost a lot to ship unless it is local but I would try to get a used lawn or construction equipment machine of some sort (I think maybe water pumps use them too) to pull the engine from.
Unread 15-04-2005, 01:43
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: gocart building
Briggs and Stratton and Tecumseh both make strong engines. For a small engine for a go-kart I would go with one of them over a Honda any day. Honda makes reliable stuff, but I believe that the small engines made by these other companies are just as reliable if not more so. We had a Tecumseh 6 HP engine on our chopper for a long time and it had no problems. It spent a year on a go-kart getting the crap beat out of it before we put it on the chopper too, so it can withstand a beating. We recently sold the 6 HP engine to a friend of mine who is also building a go-kart. He has also started from scratch. Though I do think that you will be very limited with a $500 budget and that to make a decent kart would require about $700 and up (depending on how good you want it).
See you in DC!
Unread 16-04-2005, 12:06
occra 23.
AKA: ryo
None #1481
Re: gocart building
hmm. i searched for pocket rockets on ebay and with shipping seems i can get one for a bit over $200. 49cc, dual diskbrakes, chain driven and claims to go over 40 so i was thinking i can take that apart and then build a frame ($50ish), buy spindles, etc and wheels/tires for under $150. is there sumthing im forgetting? clutch(some pocket rockets have a "CVT" which im assuming is the belt type torque converter)... oh axles. bearings, well that cant cost too much, do you think $500s a little tight?
Unread 16-04-2005, 13:14
Re: gocart building
Pocket rocket engines are derived from Weedeaters and Chainsaws where gokart engines are derived from lawnmowers and waterpumps. 49cc is a pretty good displacement size for that little engine but one thing for sure is that you are not going to mow your lawn with a weedwhacker and you are not going to whack your weeds with a lawnmower. A pocket rocket engine is never going to put out 5 horsepower without serious expensive modifications where a gokart engine easily will. Gokart engines rev lower but have more torque where pocket rocket engines rev higher and have less torque. For a gokart, you want a big engine. Lawnmower (horizontal) style, not weedwhacker style.
Unread 16-04-2005, 14:39
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
Re: gocart building
X2 For what Sanddrag said. Get a larger engine - for 2 reasons.
1. The torque. Remember - Torque is what gets you up to that speed - Horsepower keeps you moving. I'd always go for more torque.
2. I'd personally don't feel very comfortable with an engine at 7,000+ RPMs doing only 30 mph down the road. Again - get the larger engine and you can gear it much better!
I don't know that much about the technicals on smaller engines - but it's still off the principle of a 2/4 stroke Internal Combustion engine...
And anyways - remember the saying - "There's no replacement for displacement"
That rug really tied the room together...
Unread 16-04-2005, 17:54
occra 23.
AKA: ryo
None #1481
Re: gocart building
thnx guys, but most lawnmower/waterpump engines rev only up to about 3500. which isnt too pleasing for me. as matt said, id much rather hear it running high rpms. i dont need to burn out or anything. i wouldnt care so much even if i had to push off running next to the cart if i have more top end torque. and high rpms. if i wanna start drifting with it, id like the high rpms. (and a manual clutch would help... is there a way to get a manual clutch rather than a torque converter or a centrifugal for a gocart?)
power to weight ratio with a 2 stroke or a big displacement with a big 4st. dont dirtbikes use anything as small as a 50cc? i dont know too much but say for example, a 5hp b&s lawnmower engine. whats the displacement on those?
oh and a little offtopic but whats the legality or w/e on gocarts? (michigan) anyone know off the top of their heads? save me some time looking it up
Unread 17-04-2005, 02:47
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
Re: gocart building
Originally Posted by greencactus3
thnx guys, but most lawnmower/waterpump engines rev only up to about 3500. which isnt too pleasing for me. as matt said, id much rather hear it running high rpms....power to weight ratio with a 2 stroke or a big displacement with a big 4st. dont dirtbikes use anything as small as a 50cc? i dont know too much but say for example, a 5hp b&s lawnmower engine. whats the displacement on those?
I know that B&S and Tecumseh engines rev to 3000-3500 rpm stock, but can push out close to 7000 rpm with some modifications. And the 6 HP Tecumseh engine we used on the chopper was like 150 cc...not as small as you would think. I have no idea about the legality in Michigan.
See you in DC!
Unread 17-04-2005, 15:19
occra 23.
AKA: ryo
None #1481
Re: gocart building
what are those modifications you mention? is it something to be done in a garage? or do i have to take it somewhere and have it professionally done?
so seems everyones against the 50cc engines. how about pricing? is a lawnmower engine worth the money over the small engine?
Unread 17-04-2005, 23:51
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
Re: gocart building
The modifications can get exspensive, but our stock 6 HP Tecumseh 4-stroke engine cost $225 brand new and we did not modify it. I am unsure about how much each modification affects the power and RPM range, but I know that 7,000 RPM can be achieved (it will probably cost you at least $500 to do it though).
Modifications range from putting a high-lift camshaft in, to boring the cylinder out, to changing the timing. Many of these things can be done in a home garage, but boring the cylinder out would require the use of a machine that I doubt anyone has in thier home garage. These small 4-stroke engines are very simple and easy to take apart and could be rebuilt with new parts within a day if you spent the whole day working on it.
Some people that use the 5 HP B&S engines for go-kart racing end up spending up to (if not more than) $1000 on them, but those are all out racing engines, which is more than you are looking for. A stock engine would suit you well for a home-made go-kart just to fool around with (unless you really want to hear the thing wind out several thousand RPM's).
See you in DC!
Unread 18-04-2005, 18:39
occra 23.
AKA: ryo
None #1481
Re: gocart building
yea. thats the prices ive been seeing on ebay for those motors. but ive heard tecumseh is unreliable? how was yours? anyone think different? and the ones on ebay some have alternators. think thats useful? or does it like reduce performance even? headlights sure would be cool but no need for them. if we wanted, we can always stick a battery on.
so prolly no mods are gonna happen other than maybe change the timing a bit if sumone knows what they're doing. i know timing on electric brushes but for valves and such nope.
i have a friend who really races shifter carts and yea, i know how money can get you speed lol. but dont wanna spend too much. BUT i do like high whines.
Unread 18-04-2005, 19:00
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
Re: gocart building
got to agree with everyone else, chassis is the first place to start.
then move on the the drive train (steering and motor)
the engin and differentials really depend on wut kind of driving ur ognna be doing so just experiment with that
hope it all comes together good for ya. if u have any questions cantact. glad to help out
How much of the field are you building? Joe Johnson FIRST Tech Challenge 7 11-04-2005 17:32
Is FIRST a robot building CONTEST? KenWittlief General Forum 25 15-03-2005 20:05
Sub Forum suggestion. (Non Robot) Team building projects. Elgin Clock CD Forum Support 3 03-12-2004 14:30
Q&A Discuss: Arena Building: Cheap Materials CD47-Bot Extra Discussion 1 22-01-2003 17:16
Qotw [11-24-02]: What your team do beside building robot... Ken Leung Rumor Mill 9 05-12-2002 07:42
