Go to Post Long after we've forgotten that absurd pink bunny, Dave's other car is still on Mars. - Richard Wallace [more]
Unread 14-04-2005, 14:44
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
Re: protable controls w/o using teather
Can you use one of the blue rechargeable RC backup batteries? Do they have enough voltage to run the OI? They're about 7 volts or so.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 14-04-2005, 15:14
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
I asked IFI that a couple of years ago about using a 7.2 NiCd rechargeable and they said it's a bit under powered and to go get a 9.6 rechargeable from RadioShack, the kind for RC hobbies. Then just splice a barrel connector in parallel to the connector on the rechargeable battery and *poof* your ready to go and you can still easily recharge it.
Unread 24-04-2005, 00:43
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Yea, this year i powered my team's controller with the little blue batteries. Surprisingly enough the OI will operate. Our batteries were always overcharged by the charger. But as the batteries die you will notice strange OI behavior, luckily when the batteries start to die the radio is the first thing to stop working.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 25-04-2005, 08:58
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Re: portable controls w/o using tether
My team and I built a portable OI powersuppy using a recharble 9.6V nicad battery from radioshack. we built an adaptor cable to take the battery end and convert it to what the OI uses so if we find we need more batteries for longer demenstations we don't have to modify them we can just go to radio shack and buy them.
Unread 11-05-2005, 00:26
eeeeweeezeee's Avatar
eeeeweeezeee eeeeweeezeee is offline
menace to public safety
FRC #0114
eeeeweeezeee will become famous soon enough
Send a message via AIM to eeeeweeezeee
Lightbulb Re: portable controls w/o using tether
I built an OI power system into our custom operator interface with 3 9v batteries and a jack for wall power. there is even a swich to change modes. our captain, who asisted, will probably post a picture of it later. my project for next year's oi is to make a rechargeable system that autuomaticly transfers. to do this, i need to find a 9.6 volt charger that can support the drain of chargeing a battery and powering an oi at the same time. does anyone know if this has been atempted before?
EEEEWEEEZEEE
was here
Unread 11-05-2005, 01:32
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
Am I reading this right? This will essentially be a mini-UPS. That is a really neat idea!
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 13-05-2005, 02:35
FRC #0114
Attached is the OI power system the captain and I made. It has a wall jack for 9v input and the transfer switch is near by. in the lower right corner, three 9v batteries are visible. In my previous post, I mentioned that I was making another one. It's still under construction because I discovered the charge controller I was going to use from a backup battery charger wasn't in use for a good reason (It smelled like a burnt victor and, upon further inspection, I discovered one of the IC's had violently lost half it's mass at some point).
EEEEWEEEZEEE
was here
Unread 11-05-2005, 08:52
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
If you do this, you'll need to limit the current flowing into the battery pack, otherwise you could damage it.
Otherwise it would be totaly possible to do. Just use 2 schottky diodes that can handle the current into and out of the battery, and a resistor on the one that will be used during charging. That will make sure you have enough current to power the OI, but don't toast the battery.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Tether heating up! Shu Song Electrical 10 03-02-2005 01:14
Rumor or Real: RF Tether product joe_balint Control System 20 26-01-2005 00:27
[FVG]: Controls Round C1 Mike Ciance FIRST-related Organizations 18 29-07-2004 20:44
Jump Start RC w/o Exide 12v battery Mark McLeod Control System 3 12-01-2004 12:42
Entanglement at Bash Rick Rules/Strategy 31 06-11-2002 21:30
