Go to Post No amount of sleep beforehand will make up or prepare you for the lack of sleep you will receive during build season. - Dan Petrovic [more]
Unread 15-04-2005, 23:41
dawonn's Avatar
dawonn dawonn is offline
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
Arrow Save a variable
Is there a way to save a value in a program after the power had been lost and then recover the value after the power is reaplied?
Thanks ^_^'
Unread 16-04-2005, 00:06
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Save a variable
Yes, you can use the EEPROM on the RC. Check out this thread for details and code that will let you do it. Be aware that you can't write to the EEPROM every loop in the RC or you'll wear it out.
Unread 16-04-2005, 01:43
RyanMcE RyanMcE is offline
Still Learning...
FRC #0492 (Titan Robotics)
RyanMcE will become famous soon enough
EEPROM Lifetimes
As far as I know (not an expert by any means), most EEPROMs are good for at least a million write cycles. So don't go writing to it every cycle, but every second should be fine.
Titan Robotics Club (Team 492) Co-Founder, Alumni & Mentor
#1 in the Northwest: 2001 Silicon Valley Regional Rookie All-Star Award || 2001 Galileo Incredible Play Award || 2002 Southern California Regional Judge's Award || 2002 Pacific Northwest Regional Finalist || 2003 Silicon Valley Regional Entrepreneurship Award || 2003 Pacific Northwest Regional Website Award || 2003 Pacific Northwest Regional Finalist || 2003 Pacific Northwest Regional Engineering Inspiration Award || 2004 Pacific Northwest Website Award || 2004 Pacific Northwest Regional Champions (#1 seed) || 2004 Galileo Semi-Finalist || 2005 Pacific Northwest Regional General Motors Industiral Design Award || 2005 Pacific Northwest Regional Champions (#1 seed) || 2005 Galileo Finalist
"We'll do better next time" -- Team Motto
Unread 16-04-2005, 12:11
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Re: EEPROM Lifetimes
Ok lets do the math, 1,000,000/(38cycles/sec*3600 seconds/hr)=7.3 hours. not a lot of time.
Once per second gives 277 hours, longer, probably longer than you will need for the robot. But depending on the variable, it could be longer.
How often does the variable change? if it is not that often, you could detect when it changes, and then save it.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 16-04-2005, 13:45
Still Learning...
Good points - it seems to me) that 277 hours is longer than most robots are on, in their lifetimes. Nevertheless, you are right - only writing when you need to is a better solution than writing periodically.
What I had in mind, however, was a variable that is constantly changing (like position, for example), but you don't want to exhaust your EEPROM. So you write only every second. That gives you reasonably up-to-date information, but many fewer write cycles, greatly extending the life of your EEPROM.
Unread 17-04-2005, 15:50
Kyle T Kyle T is offline
waiting for next season...
FRC #0810 (Mechanical Bulls)
Kyle T is an unknown quantity at this point
honestly, i think your best bet would be to have a button to save the value that you should press before you turn it off-- that saves a lot of writes, even though it requires user intervention
Unread 22-04-2005, 16:07
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I would say to save it if the main battery voltage dips below a certain point. As long as the backup is installed, you should be OK with this.
Unread 23-04-2005, 08:30
Software Engineer
Rookie Year: 1995
I wouldn't recommend this. If your battery dies while writing to EEPROM you could corrupt it. Using the voltage dropping as a trigger will greatly increase the odds that you're trying to write as the power dies, obviously. Plus, if you suddenly cause a large current drain on your robot (for example, at the beginning of the match with both sticks forward), you could end up trigger ing your write routine, which personally I wouldn't want running at all during a match in case something goes wrong with it and because it wouldn't get the same level of testing as the rest of your code.
How do I save a quicktime .mov file? Elgin Clock IT / Communications 20 18-03-2005 17:39
Program for variable speed cabbagekid2 Programming 5 12-01-2005 13:20
Interrupt Handlers and Variable Scope kaszeta Programming 2 14-02-2004 18:30
Pic Block (save server space) Jack CD Forum Support 3 22-09-2002 01:05
what teams have a variable transmissions? Greg Perkins Technical Discussion 4 06-03-2002 06:10
