Go to Post When we design these systems ask " would I want my Mom (or daughter) standing next to this thing when it goes off? - Mike Betts [more]
Unread 16-04-2005, 17:20
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: DeWALT Transmission After Action Report
931 built two NBD units using 2004 FP motors and 10-tooth #35 sprockets, following the white paper recipe almost exactly. We did adjust the pinion hole diameter slightly to get an easier press fit. Based on gage pin tests I think we ended up with about 0.1255".
One NBD-FP is on our robot actuating the arm pivot chain, the other is a spare that we have not needed yet. Arm radius measured sprocket-to-hook is about 4 ft. Sprocket reduction is two stages for 36:1 and then the XRP gearbox in low. Motor current measurements while lifting a vision tetra indicate less than 25A average draw [note: motor current is discontinuous with instantaneous peaks to about 45A, chopped at Victor modulation frequency], and our PWM code limits the average motor voltage to about 9V max. So far no problems, but we did have to remove the anti-backdrive pins to permit stable lowering; having the pins out makes our arm operator much happier while capping.
I'll report again after the championship.
Richard Wallace
since 2003
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
Slickest drive transmission yet... dlavery Technical Discussion 58 10-01-2005 19:33
A report on off season competitions Ken Leung Off-Season Events 2 17-10-2003 13:30
Using an action register? blueWarrior General Forum 4 14-10-2003 21:07
