Go to Post Corndog is the new water game. - Basel A [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 08-10-2004, 23:16
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: So many versions of Linux, what do I do!!!
I started out on Mandrake 9.2 then Upgraded to Mandrake 10. I moved to Linux so that I could host websites for fun and later for profit. My site can be found at http://nullagent.no-ip.com when my computer is on . Mandrake is great for newbies, 10 is very easy to install but will not work on all hardware. Installing a program on Mandrake is very easy when using RPM packages but next to impossible if you try to compile a program from the source. I am now finding it restrictive as it has many dependencies and I am now planning a move to Knoppix or Gentoo. Gentoo is a cool distro but I would not recommend it for the faint of heart, or those that may be tempted to go back to a M$ operating system.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 21-03-2005, 12:25
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
Its time to revive a very dead thread of mine.....
I have to finally give in, and decide how I want to run Linux. I had been working with the Live CD. However, I'm "moody" and my computer is even "moodier" so, I'd really like to not have to make it run from a CD.
a) Do I have to completely remove everything to partition my HD, in order to place Linux on the HD? When I do this, can I place the Live CD version on the HD or will I have to obtain another version? Or is it simple, and I can just keep everything the way it is (WinXP OS), and partition my Linux area.
b) I have the resources to Ghost my WinXP OS. Would this save me a lot of trouble. Then start all over. Create two partitions - but then do I need to locate another version of Linux other than the Live CD?
Pfew... thanks
Unread 25-03-2005, 19:52
gobeavs's Avatar
gobeavs gobeavs is offline
linux advocate
AKA: Ross
None #1425 (Wilsonville Robotics)
gobeavs will become famous soon enoughgobeavs will become famous soon enough
Send a message via AIM to gobeavs
No, just defrag your hard drive to try to get all of your data near the beginning, and during most linux installs you can just cut off some free space from the end of your windows partition and use it for linux. There are not gaurantee's that your windows data will still be there though.
It depends...if you really need to save windows, it may be comforting to gaurantee yourself that windows will still work by ghosting and starting all over, but I have never had any problems taking some space from a windows partitiona and using it for windows, just make sure the windows partition has the space to give.
For installing linux, the liveCD may work. Some distrobutions you can install from the liveCD (knoppix), others do not (Ubuntu). If you are still open to distribution suggestions, I now recommend either ubuntu (ubuntulinux.org) or mepis (http://www.mepis.org). They are both based off of Debian, so you get the great package management system apt-get, which makes them in my mind a lot easier to use. I have never tried Mepis, but based off of what I have read, out-of-the-box it will be easier to use than most other distributions because it comes pre-configured with various media plugins and such. With Ubuntu and other distributions you need to install those yourself. Mepis and Ubuntu both have liveCDs, but you can only install from Mepis'.
"Never in the face of human conflict has so much been owed by so many to so few."
- Winston Churchill on the RAF in WWII
Unread 25-03-2005, 20:18
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Man, it's so much simpler than that...
Buy a Mac.
Dave
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 25-03-2005, 20:21
gobeavs's Avatar
linux advocate
AKA: Ross
Buy a Mac.
Dave
A lot more expensive also ...
Unread 25-03-2005, 20:23
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Easier solution:
Back up all your data from the windows partition
Use a partitioning program like Partition Magic to repartition your drive
(or use what the distro. you're installing has, if it does)
Pop in the installation CD, and restart
Install Linux on the space you alloted for it.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 03-04-2005, 12:13
wk1989 wk1989 is offline
None #0001
wk1989 is an unknown quantity at this point
Originally Posted by Raven_Writer
Easier solution:
You have to repartition, just resize the Windows partition.
One thing though, convert your Windows partitions to FAT32 if you want to be able to write to it in Linux, otherwise leave them the way they are.
Unread 03-04-2005, 12:34
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Captive NTFS Package allows you to read/write to a NTFS partition using linux.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 03-04-2005, 12:42
None #0001
http://faq.arstechnica.com/link.php?i=1227
Read Write
Linux Yes Experimental/Dangerous
Be careful with that thing, I heard it could mess up your ntfs partitions, like making them unbootable. I prefer FAT32 over NTFS since I don't boot into Windows often.
Unread 03-04-2005, 13:39
Rookie Year: 1995
I am finally dual booting SuSe and WinXP using GRUB after a LONG week. First I was dual booting with Fedora C3, and with the struggle of finding that my video, sound, and wireless card were not installed..... I tried to switch. When using Partition Magic to rid of a partition, and start over, I LOST both partitions, as it destroyed my boot loader.
Next, I began to reload my windows partition, and at this time created a secondary partition. (I believe my WinXP is NTFS). No, swap drive as Windows will only be used on the school network as a safety precaution, and for school learning purposes. I have successfully installed SuSe Novell Corporate version, only laking my internal wireless card and frills for my touchpad.
Hmmmm... now on to tackling that wireless card. And learning how to install things in Linux.
Unread 15-04-2005, 21:02
AKA: Alan Meekins
It's handy to have a Linux live cd around like Slax or Knoppix because if you are hnady with the command line you can use it to fix your master boot record without loosing all of the data on the harddrive.
Ok for your wireless card you should take a look at the following websites.
http://www.hpl.hp.com/personal/Jean_...nux/Tools.html
http://ndiswrapper.sourceforge.net/
One the first site you will find info on the linux wireless tool package. Most modern distros will already have it installed but more than likely you need to get a driver for your card. There is a good chance that the manufactor of your WiFi card has not written a linux driver. Have no fear! If there is only a Windows driver you CAN use it. The second link will take you to the NdisWrapper homepage. This software will allow you to run Windows WiFi drives on Linux. However, this software is not perfect but it gets the job done, and if you have the option of a native Linux driver take it.
If your network uses WEP, WPA, or some other encryption method you well have a slightly more difficult time configuring you card. Theres alot of information on those two pages and should be enough to get you started.
Ok now that you have internet access I bet you want to install stuff. Well the most common why to install stuff on linux is to do it the programmer way, from the source code. There are five basic steps when installing from source. Few applications differ from these steps and when they do read the read_me file.
Don't forget to unzip the program first.
cd folder_name //Move to the folder with the program in it.
./configure //This command configures the program and prepares it to be installed
make //This compiles the program
su //Become the root user
make install //This places the compiled program files into a folder where all/most of your programs live
If you dislike the command line you may want to use RPM packages. They generally are the easiest ways to install programs and can cause the most frustration. Deepening on your distro you can simply double-click on the RPM file and it will be installed. The main source of frustration with RPMs results from dependencies or other programs/drivers that the program you want to install is reliant upon.
Another way to install programs is dependant on your distro. Most major distros have software that will allow for the easy installation of progams. Gentoo for example has a program which will download/compile/install the requested program and all programs that it is dependant on.
I hope I helped. I would hate to see a potential Linux user take the easyway out of things rather than explore Linux.
Unread 17-04-2005, 03:38
gobeavs's Avatar
linux advocate
AKA: Ross
Re: Ndiswrapper, I got it to work with a Linksys wireless "g" desktop card...refer to http://ndiswrapper.sourceforge.net/p...index.php/List and see if your card is there to see if it will work and some notes on how well it works...
Unread 26-04-2005, 01:01
jhnphm jhnphm is offline
jhnphm is an unknown quantity at this point
Using straight Debian here.
Unread 02-05-2005, 19:38
None #0001
Use a Debian based distro, apt-get is awesome.
Unread 03-05-2005, 15:51
gobeavs's Avatar
linux advocate
AKA: Ross
I don't know if I have said it before...but it is awesome. I pretty much exclusively run debian-based distros for apt-get alone.
Using Linux? Raven_Writer IT / Communications 41 05-07-2004 16:53
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
Linux: steps to program fullsize RC robot rwaliany Programming 31 14-02-2004 14:45
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
Linux file extensions rbayer CD Forum Support 5 14-11-2002 23:04
