Re: [moderated]: Champ. Head Refs now accepting your questions
Will penalties or disablement be called for tetras that are going over the drivers station wall / plane of the wall or is that no longer an issue due to the new protective covering mentioned in update #20?
Re: [moderated]: Champ Head Refs accepting your ?'s
Can the coach take picture froms behind the player station as long as he doesn't cross the drivers line?
Can the coach cross the drivers station line? If so, as the clock resets to 120 or when the music sounds?
Please clarify how the Update 20 of G15 will be enforced in the case where Blue is blocking (sitting outside zone, not moving) Red from leaving their LZ, and Red bangs into stationary Blue....
or... if Blue is driving by to go somewhere else, and Red bangs into them when leaving their zone.... does anyone get a penalty? Will it always be enforced as per the "source" of interference/contact, since Blue is not the "source" in these cases? |
Will a robot be considered behind the endzone line in a case where the robot base, or arm, is supported by a tetra (and therefore not touching outside the white line) such that the robot would otherwise be touching outside the white line?
Along the same lines, if the robot is clearly and fully behind the endzone line, and a tetra touching outside the line gets pushed into the robot, will the robot be counted as behind the line? |
Do the refs at each field have a copy of all rules and updates available to them at any time in cases of "questionable" calls?
#7
Regarding Q/A 1852, or Update 20, if Blue is holding a tetra and knocks off a tetra from their own loading station (while not in LZ), is that a 10pt penalty? This specific case is not defined in the answer.
#8
Can you give us a few clear examples of what will be considered "overly aggressive play"? On the same token, can you give us some clear examples of what acceptable defense is?
i.e. Can I bump into another robot from 2-3ft away, a few times in a row, to disrupt his stacking position? |
#9
Suppose by any means, you have made a call and realize it was wrong after someone pointed it out to you[Don't mean to be ungracious at all]. Will you change the score? Will you change it if the scores have already been put up?
#10
Can we place tetras out side the playing field? Just say we steal a tetra from an opponent and we want to make sure that the opposing alliance cannot use it.
#11
Is the 3-ft line in the players station (the starting line) a line or a plane? In other words, can the driver's hand or head cross the line without incurring a penalty? Assuming that the driver does not touch the controls, of course.
#12
What is the timeline that can be expected for reloading the auto-loaders by the field attendants? (At some regionals it was virtually instant, at others it took a while)
#13
Will a video camera be allowed on the control board, where we have the OI and the joysticks, behind the glass with the drivers and coach?
#14
Thanks all for the questions! We'll see you on Thursday with the answers.
Travel safe. Benge, Paul, Larry, Lisa, Ron and Aidan |
| [moderated]: A call for an end to inconsistency (sticking up for G25) | Travis Hoffman | General Forum | 48 | 28-03-2005 14:14 |
