Go to Post "And that right there is the Sharpie line between right and wrong. Guess which side you cut on?" - Cypher [more]
Unread 17-04-2005, 15:19
occra 23.
AKA: ryo
None #1481
Re: gocart building
Originally Posted by tkwetzel
I know that B&S and Tecumseh engines rev to 3000-3500 rpm stock, but can push out close to 7000 rpm with some modifications. And the 6 HP Tecumseh engine we used on the chopper was like 150 cc...not as small as you would think. I have no idea about the legality in Michigan.
what are those modifications you mention? is it something to be done in a garage? or do i have to take it somewhere and have it professionally done?
so seems everyones against the 50cc engines. how about pricing? is a lawnmower engine worth the money over the small engine?
How much of the field are you building? Joe Johnson FIRST Tech Challenge 7 11-04-2005 17:32
Is FIRST a robot building CONTEST? KenWittlief General Forum 25 15-03-2005 20:05
Sub Forum suggestion. (Non Robot) Team building projects. Elgin Clock CD Forum Support 3 03-12-2004 14:30
Q&A Discuss: Arena Building: Cheap Materials CD47-Bot Extra Discussion 1 22-01-2003 17:16
Qotw [11-24-02]: What your team do beside building robot... Ken Leung Rumor Mill 9 05-12-2002 07:42
