Go to Post The animation is just a pretty tool to help outsiders understand the game; the manual is for me, the animation is for my grandmother. - JVN [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 18-04-2005, 21:32
JamesBrown JamesBrown is online now
Back after 4 years off
FRC #5279
QUICK WIRELESS HELP
This is a stupid question but is there an easy way to tell wheather or not i have a wireless card (other than opening the comp and looking inside) with out having acess to a wireless net work.
The reason i ask is that i was going to buy a usb wireless adapter for use in atlanta. The lap top isnt mine. THe person who gaveme the laptop insists there is a wireless card in it but i havent seen any proof and dont have a network at home to connect to. I looked in the device manager under network adapters and all I found was "3COM EtherLink XL 10/100 PCI TX NIC 3C905B-tx" I believe this isd just my network card that i use for my home netork ( not wire less)\
Please help so i can save some money if there is a card in this already
Unread 18-04-2005, 21:39
Enterprize's Avatar
Enterprize Enterprize is offline
Ubergeek
AKA: Joshua
#0269 (Cooney Robotics)
Enterprize has a spectacular aura aboutEnterprize has a spectacular aura aboutEnterprize has a spectacular aura about
Send a message via AIM to Enterprize
Re: QUICK WIRELESS HELP
Nah, no stupid questions, only stupid answers. XP
Well, off the top of my head I can say that I would severly doubt a wireless network card would be in a laptop that you would not be able to see with a quick glance. Namely, the antenna will need to be visible to be at all practical and all laptops I've seen use an expansion slot (usually on the sides, about twice as tall as a floppy but half the width. It's a port you can pop things in and out for quick mobility) for wireless connection.
If the computer recognises it as installed, it should be in the device manager. It's POSSIBLE that its in there and the drivers just werent installed at all/correctly, but very unlikely.
Again, you should be able to see a wireless card as it should have a small but visible antenna.
Though, I could be wrong, and the best solution is to ask the guy in person where the wireless card he has in it is.
I have [a buncha] gmail invites, if you want one PM/Email me ^^
Eat donuts - Save the Planet. Do your Civic Duty.
Unread 18-04-2005, 21:44
FRC #5279
well there is nothing in the expansion slot and what you said is what i thought so now i pose another question wireless card or USB?
Unread 18-04-2005, 21:48
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Wireless Card, USB has cables...isn't getting rid of cables the point of wireless?
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 18-04-2005, 21:50
Billfred's Avatar
Billfred Billfred is offline
Incorrect--my laptop has an internal card, with no antennas poking out anywhere. (Hence I can chill here outside Preston and still get my CD fix.) And I've seen USB wireless adapters that can be used sans antenna--just plug and go. My brother used one on his desktop that he didn't want to crack the case on with no problems, but YMMV.
In every laptop I've seen, pressing (Fn)+F2 will normally enable or disable the wireless if it's installed internally. If that doesn't do anything, then odds are you don't have wireless.
Unread 18-04-2005, 22:20
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
Why don't you just search the internet for your laptop brand/model and see if a wireless network card was even an option.
Also, if you do not see some kind of indication on the keyboard, either by a key to turn the card on/off or some sort of wireless symbol or status light as an indication on if the card is on/off.
Some thing similar to this .
You could even look in the Control Panel and there would probably be something in there to change settings if a wifi card existed.
Unread 18-04-2005, 22:23
FRC #5279
Well i have decided i dont have a card perhapse it was removed at some point. I am thinking about getting a wireless usb adapter because it would also work with my desk top and the computers at school If any one can think of a problem with this let me know. If you think this may not be the best choice againlet me know
Thank you
James
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
That's incorrect also, I just tried mine and it didn't do anything
To see if you have an internal wireless card, go to Start--Run.
type "cmd" press enter.
Type "ipconfig /all" and hit enter.
If you see a blurb about "Ethernet Adaptor Wireless Connection" you have one.
If not, you don't.
2001-2004: Team 100
2006-Present: Team 254
Unread 18-04-2005, 22:42
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
The (fn + F2) is actually true; however, it may be just Dell specific.
My Dell laptop has a little blue radio tower with waves coming off of it on the F2 key.
Also, If I want to disable my wireless I simply push both of those buttons and I get a disabled or enabled icon on my screen.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 18-04-2005, 22:48
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
Cory's way is a good way. Sometimes "ipconfig" isn't in the path and doesn't work though. It will give you an error if it doesn't work. If it says wireless you are definetly good though.
Other things:
You could look in Device Manager (Start, Settings, Control Panel, System, Hardware tab, Device Manager button, then expand Network adapters.
The wireless card may have to be enabled in the BIOS.
Unread 18-04-2005, 23:00
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
If not, you don't.
That would only work if the device is enabled. If it's in there and it's disabled, then it wouldn't display on it.
Unread 19-04-2005, 01:33
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Did you ask the person you got it from how to enable it/where it is? The person who owns the laptop will likely be able to better help you then we can with the limited information you are giving us.
Wetzel
Viva Olancho!
Unread 19-04-2005, 09:06
Andy A. Andy A. is offline
Getting old
FRC #0095
Assuming it hasn't been removed, any laptop that comes with an internal WiFi card will have an FCC warning/ID sticker on it, usually the bottom. It will be a bit more lengthy then the usual 'this device must accept any interference yadayadayda', and go on to include a FCC ID number. If you have an FCC ID number, your capable of broadcasting something.
Also, every wireless adapter I've ever seen comes bundled with some software, usually some sort of GUI that lets you browse available networks and configure security options .etc. Normally, that software loads on boot, and will at least yell at you that it can't find any open networks in range. It sounds like the laptop does not have a wireless card.
On the topic of USB adapters, I've had great luck with
This guy from Belkin. But, I suspect that just about all the little wireless USB hubs are pretty much the same. It shouldn't cost you more then 20, if that.
-Andy A.
Unread 19-04-2005, 16:42
Enterprize's Avatar
Ubergeek
AKA: Joshua
Ah, well internal cards are nifty. I didn't think about that ^^;
As for USB adapters, you'd still be able to tell if there was one in there.
Unread 19-04-2005, 17:44
Rohan_DHS Rohan_DHS is offline
AKA: Kayla's big bro...
FRC #1620 (Robolution)
Rohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of light
Send a message via MSN to Rohan_DHS
Thank you
James
hey man, i dont kno if this is going to help you or not...but from my experience (and i've heard about this too) SMC routers hav a hard time with other brands wireless cards/access points, etc for whatever reason. Myself, as well as my school is having problems with Wireless Routers by SMC, but i am not sure wether their NIC's (network interface card) are the same way, or not, but watch out for that...just a friendly word of advice
Good luck with your purchase,
Rohan
Rohan K
2008: Alumni, Helper
2007: Webmaster, Alumni
2006: Team Captain, Driver, Electrical/Electronics Head
2005: Safety Captain
Boilermaker Regional Wireless Scouting System. Josh Hambright Regional Competitions 4 21-03-2005 19:48
2 Wireless routers MattK Chit-Chat 7 02-06-2004 20:46
Wireless network at compitition. ArJubx General Forum 37 17-03-2004 08:52
Q&A Discuss: wireless camera CD47-Bot Extra Discussion 3 16-01-2003 18:09
Did you use the 802.11b wireless LAN at EPC@T? soap108 Championship Event 21 04-01-2003 11:03
