Go to Post Quoting Fred Durst--"Bring it on." - Billfred [more]
Unread 22-04-2005, 16:10
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Master Code 11?
Originally Posted by devicenull
I plan on taking the "If it ain't broke, don't fix it" approach on this.. I have yet to see this problem at all, and even if it happened to us, the only pwm effected won't hurt anything at all.
Unless its a requirement, I won't be using it.. I don't want to have to diagnose a problem between it and our code at nationals.
I think it's a requirement to use v10, since last year's versions (6 and 7) won't work with the new OI. If you're using the 2004 RC, you'll need to upgrade. If you're using the 2005 RC, you're ok.
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Master Code? HolyOne207 Programming 4 12-01-2005 22:32
2005 RC Master Code or yaniv Programming 8 12-01-2005 12:05
