Things to do with vex?
Hey, some friends of mine are gonna chip into buy like 2 sets of vex to just mess around with. hwat are some things we can do with them? (sorry not very creative) in the instruction book theres things like playing soccer, technically we can go 1 v 1 since we're getting two starter sets, but just kinda wondering what else we can do. or anything random we can build just for fun
side note, what different kind of kits are there exactly? |
Re: Things to do with vex?
Well, you can theoretically do anything you want with them.
The challenge they're trying this year in Atlanta is essentially a shrunken FIRST Frenzy: Raising the Bar. If you're up for a challenge (and have a few bucks lying around afterward), there's always recreating such classics as Stack Attack or Maize Craze--FIRSTwiki should have information on both. |
yeah just looking for mini challenges we can do, pretty tight budget since we're funding this ourselves so dont know if we can actually build our own mini fields and such
Quick question: does VEX include Gyros? I think a Segway mini would be a cool summer project....
From what I've seen so far the VEX is a work in progress. The programing part has not yet been reveled. The programing environment will show how far the VEX platform can go. This is a tough problem for the developers. To throw the Microchip IDE and c compiler at a mass marketing effort will lead to low sales. A scripting language like the Lego's will leave the real power of the controller untouchable and risk loosing the advanced user. This summer should show more of the capabilities of the platform. I may be flamed for saying this but, I believe a well done basic interpreter would be a good compromise.
Or, why not do both? Have scripting for the newer folk, then a way to access the whole schimaymay for that set? Then you get the best of both worlds.
#7
#8
Here's two pictures of 228's BlockBlitz robot: |
#9
For the root post, there should be challenges updated on the www.vexrobotics.com website periodically, though the one up there right now pretty much blows.
for those of you worried about programming, dont be shocked if you see a C compiler with an optional lego-style programming shell. probably a split-screen of both. |
#10
i think that the split screen of both will be awesome for those of us who dont know C very well. Start out with the GUI and keep an eye on the code, then eventually you can graduate to using mainly the code and use the GUI if you need a little help, then just use the C code all by itself. Its going to rock for newbies. |
#12
I own a lego mindstorms set, and I can definetley say the interface is not very satisfying for someone who's programmed an FRC bot... But I'm glad they came to the comprimise including the C compiler. After messing with the VEX bots at the RadioShack social, I'm hoping to get a VEX kit when I can.
#13
Another idea for a competition is the VEX Pit challenge they were running in the vex pit area and the VEX party on friday. It was a bunch of ping pong balls and 2 Nerf footballs that were supposed to be pushed behind lines (end zone thingys) or placed in boxes for even more points. The bots were almost always just the basic "square-bots" with small herding attachments.
Also, according to the VEX people I was talking to on friday the programming module should be realised in August, and it will have multiple ways to program. There is a system similar to the Mindstorms that you create a flowchart with, straight C, and a split screen, where you see what each item that you add to the flowchart does to the C coding. |
#14
The development software is being created by a company called Intelitek and will be called easyC. You can program using easyC or MPLAB using C18 or assembly. For those of you that have a kit, code can be downloaded to the controller now using IFI Loader if you build a cable. You don't have to wait until August.
#15
Hmm..things to do with vex..=) Well while I was not a VEXpert, I did help them out a tad bit, and spent some of my free time bugging one of the experts. Most of the time I was fixin tetras and the I such, but I did managa to learn a lot and come up with some good ideas. I've been building robots too long to stick to the stock bits. The VEX kit runs the motors and the servo's via pwm...what other favorite devices run from pwm signals....mainly victors come to mind. I was thinking about creating a smaller robot, bigger than the VEX kit can produce, but smaller than the standard FIRST robot. I plan on using the inexpensive controllor to my advantage, and use it to run a higher voltage system. Some other things I was thinking about was how about a cvt on a vexbot? How crazy can we get, I plan on starting a team, and I will really be reading the rules closely =)
| Useful VEX Tools | Joe Johnson | FIRST Tech Challenge | 4 | 26-04-2005 18:48 |
| Vex Robotics | Vex | FIRST Tech Challenge | 0 | 14-04-2005 13:48 |
| VEX Robotics | vexrobotics | FIRST Tech Challenge | 8 | 30-03-2005 23:25 |
| VEX Kits ARRIVED!!! | Joe Johnson | FIRST Tech Challenge | 14 | 28-03-2005 19:28 |
| things to keep in mind while in the pits.. | coreyjon | Technical Discussion | 20 | 25-10-2004 15:25 |
