Go to Post Mentors learn from, are inspired by, and emulate each other. A team with a great lead mentor leads to a productive, inspired, and ultimately successful group of mentors. - Jared Russell [more]
Unread 24-04-2005, 19:49
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Yellow Rotation Sensors ?
Quite a few robots at the championship were using small yellow plastic encapsulated sensors to read wheel rotation (presumably reflected light based). Who makes them and where do you get those and what are their interfacing (to the RC) requirements ?
Thanks
Unread 24-04-2005, 20:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Yellow Rotation Sensors ?
If you mean orange not yellow then they were Grayhill quadratrure encoders from Digikey. You can check out some code at www.kevin.org
Unread 24-04-2005, 20:45
de_ de_ is offline
AKA: Dave Edwards
No, I'm 99% certain they were yellow. They were not directly attached to any rotating part. I am sure they were using reflected light. If I remember properly, Busy Bee used them aimed against black and white disks attached to their wheels. I believe they could be installed at least 0.5" or more away from the wheel.
Unread 24-04-2005, 21:32
Kevin Watson's Avatar
La Caņada High School
FRC #2429
From the description, they're probably Banner proximity sensors. Try doing a search on QS18VN6LV, the part number.
-Kevin
Kevin Watson
http://kevin.org
Unread 25-04-2005, 00:11
FusionDude364's Avatar
FusionDude364 FusionDude364 is offline
Official Team Fusion Robot Pimper
AKA: Daniel Odom
FRC #0364 (Team Fusion)
FusionDude364 is an unknown quantity at this point
On 364 we used some of the Banner sensors as limit switches for the arm. The sprockets were black and we put white tape on the spots we wanted to stop the arm. We thought the normal limit switches were slightly flimsy, and the banner sensors were fairly easy to mount, wire, and program.
Team #364 (Team Fusion) Alumni
Proud MS State Bulldog and AFROTC Cadet
Unread 25-04-2005, 07:57
Many teams are using the Banner light sensors from previous year's kits for wheel encoding. They work very well at "seeing" a light and dark alternating wheel. You can easily make an encoded wheel using a drawing program and a printer to make an insert for your own wheel design.
Unread 26-04-2005, 15:40
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
you can use the line tracking sensors from last years kit to read a disk. it makes you wheels run more uniformly when you can record wheel rotation rate.
Arm design - rotation mechanism? n0cturnalxb Technical Discussion 6 16-01-2005 18:28
Yellow card / Red card usage at 2004 IRI Andy Baker Rules/Strategy 53 02-08-2004 00:35
Getting Fancy with Sensors FadyS. Programming 30 10-03-2004 15:02
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
Interrupts and rotation sensors kor Programming 3 12-02-2004 11:05
