Go to Post FIRST, in itself, will not make you an engineer. - RogerR [more]
Thread Tools Rating: Thread Rating: 11 votes, 4.64 average. Display Modes
Unread 26-04-2005, 00:41
bblack7489 bblack7489 is offline
bblack7489 is an unknown quantity at this point
how to build a VEX programming module
After spending a good deal of time playing with the VEX kit and the people from Radio Shack over the past week, I'd like to try to build a cable to program the VEX microcontroller.
The board is basically the same as the IFI board that used to be dubbed "Isac" from what I hear. I'm not familiar with the IFI boards, but there's software out there to program them. From what I hear, that software can be used to program the VEX board. All you really need is the right pinout for the connector (and possibly a telephone chord with all 6 wires in it).
With a brief time using a DMM, I've found that the red telephone wire goes to the Vss pins of th the PIC chips. Other than that, there were no obvious (not run through a capacitor or resistor) connections to the pins of the PIC chip.
I'm sure that there's interest out there in producing this cable, so if anyone out there has any thoughts that would help, I'd really appreciate it. Thanks guys.
~Ben
Unread 26-04-2005, 14:28
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Re: how to build a VEX programming module
I intend on getting a VEX kit in the near future, and as it is driven by two PIC microcontrollor chips, the ability to create our own periphials should be easy. I too will join you in the quest for unlocking the secrets of VEX.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 26-04-2005, 14:52
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
I found that pins 1-3 are Tx1, Rx1, and Gnd, respectively, for UART 1 on the user uP. The only major difference between the Vex controller's serial port and that of the Edu controller is that there is no onboard TTL - RS232 converter. All I did to build a module is convert the TTL signals to RS232 signals with a MAX232 chip from TI and then use IFI Loader to communicate with the Vex controller. The other pins on the Vex's serial port are control lines RTS and CTS, and the actual line that puts the controller in program state (similar to what the program button does for the other IFI controllers. I used a 25' 6-conductor telethone cable from RadioShack (part #279-422) and then put a button on the module that will put the controller in program state.
Unread 26-04-2005, 21:14
coreyjon's Avatar
Flight Engineer
I have a max 232 chip already from another project I am working on. It was my PDA Bot project that seems to just be kinda stuck in limbo. Perhaps I'll find a way to merge the two projects. The goal for PDA bot was to be able to feed it exact positions, and to use a gps, and onboard navigation sensors, to get to that position. Well, the ideas are growing and I am still unable to afford the kit (will take me about two weeks before i'll have enough). So, soon, very soon, I'll have the kit, and I will be building. Soon after that I should have the resources to have a VEX team started, and start teaching some kids.
Unread 27-04-2005, 00:15
fowlerm's Avatar
AKA: Matthew Fowler
Pinout for the Vex serial port is as follows:
1 - Tx for UART 1 on the user uP - White
2 - Rx for UART 1 on the user uP - Black
3 - Gnd - Red
4 - RB0 on the master uP - Green
5 - +5v - Yellow
6 - RJ3 on the master uP - Blue
Unread 27-04-2005, 09:50
coreyjon's Avatar
Flight Engineer
Sweet, that'll save me some time. Good information to have.
Unread 27-04-2005, 15:23
If you don't mind, what pins did you use for the program button? I assume you tied either pin 4 or pin 6 to either ground or +5. Also, does the switch need to be a constant on/off or does it need a momentary switch similar to the "hotsync" button on a PalmOS pda?
I'm obviously not very familiar with the hardware, so I appreciate your help. Now that you have a working programmer, could you post a schematic of some sort?
~Ben
Additional realizations:
The color / pin number correlation depends on which end of the phone cord you're looking at. In the above pinout, looking at the end of the phone cable with the little springy catch on top, which side is the white wire?
Assuming pin one is on the left and is white, I'm also seeing +5v on pins 1, 4 and 6. Also, the "program" LED on my board is on. Is that normal?
Unread 29-04-2005, 00:04
jmcglash jmcglash is offline
jmcglash is an unknown quantity at this point
Standard telco RJ11 Connectors use is as follows:
Pin     Color   Name    Description
1       /       nc      not connected
2       yellow  ?       Telco Ground
3       red     ?       Ring
4       green   ?       Tip
5       black   ?       Aux power -48v DC
6       /       nc      not connected
   clip
1 2 3 4 5 6
Also RJ11 cables are rollover by default so what you get is:
  y - b
  r - g
  g - r
  b - y
Working at at telco has a few perks after all.
Unread 29-04-2005, 01:19
Nice. However, that doesn't clear up whether the above pinout assumes pin one is white or blue...or more clearly whether pin one is to the left or right with the little catch mechanism at the top or bottom.
Regardless, it's nice to know what color actually lines up with what pin. Thanks!
~Ben
Unread 10-05-2005, 01:06
davefowler davefowler is offline
davefowler is an unknown quantity at this point
Has anyone put any kind of more simple howto tutorial on this up? Maybe with some pictures and the tools used? Also, has anayone tried figuring out the signals to send to Rx1 and Rx2 to control the robot? I'm not really too interested in programming the microcontroller. I'd just like to hook it up so that my laptop can control its movements and be notified of the interupts.
Unread 10-05-2005, 08:24
foobert foobert is offline
foobert is a jewel in the roughfoobert is a jewel in the roughfoobert is a jewel in the rough
Unhappy Re: how to build a VEX programming module
ok. i've gotten a 7 foot six conductor straight through rj11 cable from jameco, a max232 and a couple of jacks with wires hanging handily out the back, all for considerably less than the 25 foot monstrosity available at radio shack would have cost. 'til you factor in the shipping of course. but i would have had to order the max232 and the jacks anyway.
so here's my question. which pin does the program button use? i'm guessing rb3, since that port, assuming i've pulled up the right data sheet, can trigger interrupts. also i'm guessing i should connect the switch to ground since port b has internal pull ups.
another question might be has anyone figured out the function of the pin that connects to rj3?
lastly, has anyone got a clue about the api? is it too much to hope that libraries from the other ifi controllers, (with none of which have i any experience), would work?
well, that's it for now. time to hit the shower and head to work.
thanks.
Unread 12-05-2005, 23:55
The default code for the other IFI controllers will not work for Vex, you will need the Vex default code. It's available [link removed]. This zip also includes the firmware v4 and v5 bin files and the Vex DDT code.
thanks, fowlerm.
now i've got something to read this weekend.
just wondering... is it cool to distribute this code? haven't come across licensing information, yet.
Last edited by Brandon Martus : 13-05-2005 at 09:44. Reason: please provide a link to VEX's site to download.
Unread 13-05-2005, 08:19
ouch. should have checked out the cost of the compiler before i bought the robot.
let's see.
$299.00
+ $595.00
$894.00
suddenly i don't feel so good. if the bite for the vex programming kit is going to be anything like this i can see why they released the hardware four months ahead of the development tools.
just for suckers like me.
Unread 13-05-2005, 14:52
fowlerm's Avatar
AKA: Matthew Fowler
You can use the Student Edition C18 compiler from Microchip which is free. The only difference is that the Extended Instuction set optimizations are disabled after 60 days, but the compiler is still completely functional with the standard PIC18 instruction set beyond the 60 day mark.
The download link to the Vex default code should be on vexlabs.com when it is released, or you can email info@innovationfirst.com to get it now if you really want it.
Unread 16-05-2005, 17:38
caffel caffel is offline
AKA: Charlie Affel
FRC #0423
caffel is an unknown quantity at this point
Thanks, that's a big help.
The starter kit is a little underwhelming without programming capability
Charlie Affel,
Mentor 423
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Programming for Vex robots Jeff K. Programming 4 13-11-2005 16:40
VEX Robotics vexrobotics FIRST Tech Challenge 8 30-03-2005 23:25
OCCRA Teams - where do you build? Phil 33 OCCRA 7 28-10-2004 21:41
build new programming (st.louis regional) nick_champ_2 Programming 21 23-02-2004 20:55
