Go to Post Now I want to casually slip the word [B]Hemispherical Omnidirectional Gimbaled Drive[/B] into normal conversation .... - [more]
Unread 06-04-2005, 10:37
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Useful VEX Tools
Greetings VEX teams,
From working with the Innovation First Isaac system (a.k.a. Edu Robotics kit, Robovation Robotics Kit, VEX Robotics Kit) on my own, from teaching a week long class in Taiwan using the them and from working with my wife & daughter's VEX team (FRV-23), I have listed below some suggestions concerning tools I recommend all VEX teams should buy/acquire.
I will use McMaster.com as my source, but you can easily get these tolls/parts from other sources.
For clarity, I have included links pictures in the message.
Hope this helps.
Please post other tools and tips you have on this forum.
Joe J. (a.k..a “Dr Joe” in FIRST circles)
Robotic Amusements, Inc.
Nut Driver for 8-32 Nuts:
8358A26
Hollow-Shaft Inch Nutdriver Standard, 11/32" Size, 3" Shaft Depth, Green
In stock at $4.52 Each
This tool makes it easier to tighten a nut in close quarters. You can often get this nut driver in places that the wrench just won’t go.
See picture HERE.
Hex Driver for 8-32 Screws:
5497A68
Comfort Grip Ball Driver Long Length, 5/64" Hex, 4-21/64" Blade Length
In stock at $2.33 Each
Hex Driver for 6-32 Motor Screws and Shaft Collar Set Screws:
5497A69
Comfort Grip Ball Driver Long Length, 3/32" Hex, 4-51/64" Blade Length
In stock at $2.39 Each
These two tools save TONS of time when building, repairing, etc. In the pits in Atlanta, you are almost certainly going to be taking your robots apart between rounds for this or that reason. Saving time means you will reduce the general stress level. HIGHLY RECOMMENDED.
See picture HERE.
Hi Torque Hex L-keys:
71285A151
Hi-Torque L-Key 5/64" Hex, 4" Length
In stock at $0.24 Each
71285A152
Hi-Torque L-Key 3/32" Hex, 4-13/32" Length
In stock at $0.27 Each
These L-keys have a profile that make a significant difference when you are really tightening a screw. They do a much better job of keeping the hex from stripping. These things are cheap. Buy 10 of each of them. Use them until they start to show wear and THROW THEM OUT – you’ll be glad you did. It is better to use fresh tools and not strip a screw. At about a quarter each, it is money well spent.
Regular key on left - Hi-torque key on right,
If you are going to replace motor screws…
96452A144
Torx Button Head Socket Cap Screw Alloy Steel, 6-32 Thread, 1/4" Length
In stock at $12.43 per Pack
See Print HERE
96452A148
Torx Button Head Socket Cap Screw Alloy Steel, 6-32 Thread, 1/2" Length
In stock at $13.16 per Pack
See Print HERE
If I had more time, I would find these screws in stainless steel or with a zinc finish so that it would be easier to sort the motor screws from the 8-32 construction screws, but McMaster only has black oxide finish available.
Torx Driver for Above Screws:
5756A14
Torx Driver Size T10, 3-1/4" Blade Length, 5-5/8" O'all Length
In stock at $3.20 Each
This tool will save time for building and repairs.
See picture HERE.
Torx L-key for Above Screws:
6959A41
Torx L-Key Long Arm, Size T10, 3-3/8" Length
In stock at $0.95 Each
This tool is another one that I would buy several of. Torx tools are nowhere near as likely to round out or strip, so I would perhaps only buy 5 of these where I might by 10 of the similar hex tool.
See picture HERE.
Tools for Torx Motor Screws:
37455A22
Comfort Grip Torx Ball-Point Driver T10 Torx, 2-23/32" Blade Length, 5-3/16" L O'all
In stock at $6.40 Each
This is a nice tool, more expensive, but the ball end feature makes it possible to tighten some screws at “off angles” that you just can’t get to with a normal tool.
See picture HERE.
Team #88, TJ2
Unread 11-04-2005, 06:06
White Wolf's Avatar
White Wolf White Wolf is offline
agitator
AKA: Tom Murphy
FRC #0481 (The Hitchhikers)
White Wolf will become famous soon enoughWhite Wolf will become famous soon enough
Re: Useful VEX Tools
Wow. Your list was so timely and helpful, We were just at the point of starting to look for replacements. You did a truly wonderful job. There was one additional part we ordered, also from McMaster Carr.
Replacement Drive Shafts:
8894K14
Grade W-1 Steel Square Bar 1/8" Size, 3' Length
We have scored and scratched our given drive shafts and yet were afraid to cut them to avoid the risk of making irreversible decisions we'd later regret. We bought six feet of replacement stock and will recut all shaft to size. In order to keep within replacement rules we are going to identify the lengths of all groups of shaft that were "cut" from the same piece of original stock. This will allow us to easily show we have done a correct replacement.
... Tom
Unread 11-04-2005, 09:05
AKA: Dr. Joe
FRC #0088 (TJ2)
Excellent idea.
Thanks.
Joe J.
Team #88, TJ2
Unread 11-04-2005, 12:40
White Wolf's Avatar
agitator
AKA: Tom Murphy
Excellent idea.
FVT-42 The Hitchhikers
Thanks.
Along those same lines, we have made a matrix of robotic subsystems as the columns and precious resources as the rows. It has allowed us to do a more integrative design and has fostered several "Apollo 13" Aha! moments. I suspect at some point they will be more formally cast into a spreadsheet, but for now they have lived on the white-board and on scraps of paper. Our tracked resources have been kinds of gears, motors, and servos.
... Tom
Unread 26-04-2005, 18:48
Leon my zi Leon my zi is offline
Animator/Photographer
FRC #0375 (The Robotic Plague)
Team Role: Animator
Leon my zi is an unknown quantity at this point
Send a message via AIM to Leon my zi
Thanks for this info I'm going to be getting my kit soon and its nice to know what i should get for replacements.
FRC Team 375
Winner:
2005 New Jersey Regional
2005 New York City Regional
VEX Robotics vexrobotics FIRST Tech Challenge 8 30-03-2005 23:25
VEX Kits ARRIVED!!! Joe Johnson FIRST Tech Challenge 14 28-03-2005 19:28
Operation Inspiration 2004: Who wants to read all of the WFA essays? Rich Kressly Thanks and/or Congrats 30 28-03-2005 11:21
Choosing a machine shop (Re: How important is a machine shop archiver 2001 9 24-06-2002 04:20
Raul & Joe battle for second... archiver 2001 6 23-06-2002 22:45
