Go to Post Do not under estimate the wood bots and brave little toasters! - hipsterjr [more]
Unread 26-04-2005, 21:21
Robby's Avatar
Robby Robby is offline
AKA: Kevin Beranek
FRC #0269 (Cooney Robotics)
Robby has a spectacular aura aboutRobby has a spectacular aura about
Analog and digital input question
I know that the FRC controller must be present on the robot and control radio communications etc., but is there anything in the rules that says that sensors need to be connected to the FRC controller? or can they be connected to another board?
For example, if I wanted to use a gyro and accelerometer, would I need to connect them to the FRC controller and then relay data to the other board?, or can I hook them up to the other board directly?
In addition, I would assume that the camera would be considered pretty much the same as any other sensor, but just to make sure, would it be legal to directly interface the camera with another board?
In all cases the FRC controller would be handling all radio communications and controlling all pwm/relay outputs.
Thanks,
--Robby
Unread 26-04-2005, 22:27
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: Analog and digital input question
Thanks,
--Robby
The way I see the rules, the sensors are part of the custom electronics and can be connected to any other custom electronics before the signal gets to the FRC controller. The generic rule is that only the FRC controller can control the outputs.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 26-04-2005, 22:28
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
From a mentor to a student on my team
According the Robot section of the 2005 Rules, you can connect allowed electronics to the inputs of custom circuits and then the custom circuits to the RC.
So yes and yes.
See Page 17 of http://www2.usfirst.org/2005comp/Sec...obot_rev_B.pdf
Ricky Quinones
Director of Sales - VEX Robotics
Unread 27-04-2005, 01:05
kevinw kevinw is offline
kevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to all
Yes. In fact, we had sensors connected directly to our custom electronics board this year.
Unread 30-04-2005, 09:55
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Question Re: Analog and digital input question
I am curious. What was the purpose of your custom electronics board? Our team is still developing a programming and electonics team and have mostly done a job of plug and play each year.
Thanks,
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 30-04-2005, 15:49
It is likely better to handle multiple sensor inputs on a custom circuit board since you can use a faster processor and more RAM to process a command set to send to the RC. We have used a custom circuit ever since they were allowed. We have used inputs from current sensors, wheel rotation sensors, gyros, microswitches, etc. to feed the CC. As long as the CC and sensors don't directly control the power feeding motors (see the robot rules for CC and sensors) you are open to develope alsmost anything.
Unread 30-04-2005, 15:50
Thanks,
APS
Our custom electronics board was used to calculate our heading and distance travelled. In this manner, we were able to tell where we were on the field, and where we were headed in autonomous.
We also used the board to load autonomous scripts which not only controlled the robot, but also sent arm commands to the FRC during autonomous.
Unread 30-04-2005, 20:07
Robby's Avatar
AKA: Kevin Beranek
Well, it will do positioning in autonomous, but I also have some other interesting plans that I would rather be a surprise. I'm hoping I find time to get it all working before IRI.
Accelerometer: Analog or Digital? psquared Programming 2 10-02-2005 16:38
Analog / Digital IO Connectors Aidan F. Browne Control System 4 06-02-2005 22:26
Tri-axis Analog Joystick KVermilion Control System 5 19-01-2005 00:24
Some EDURobotics Problems squide Robotics Education and Curriculum 9 20-01-2004 10:27
